Looking for Elapsed_DN.bas by Darrel Taylor
Results 1 to 3 of 3
    Jul 2010
    Default Looking for Elapsed_DN.bas by Darrel Taylor
    I know he passed away, but I'm looking for a file he had for using his Elasped timer for counting down rather then
    counting up.
    This is the demo code for it but it needs Elasped_DN.bas
    ' Define LCD connections
    DEFINE LCD_DREG PORTC   ' Set LCD Data port
    DEFINE LCD_DBIT 4       ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTC  ' Set LCD Register Select port
    DEFINE LCD_RSBIT 2      ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTC   ' Set LCD Enable port
    DEFINE LCD_EBIT 3       ' Set LCD Enable bit
    DEFINE LCD_BITS 4       ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2      ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    DEFINE  OSC 4
    INCLUDE "Elapsed_DN.bas"  ; Elapsed Timer Routines
    ZERO_LED   VAR PORTB.3
    ANSEL = 0                 ' All Digital
    ANSELH = 0
    LOW ZERO_LED              ' start with LED OFF
    OPTION_REG.7 = 0          ' enable PORTB pull-ups
    PAUSE 250
    LCDOUT $FE,1              ' Initialize LCD
    PAUSE  250
    Days = 1                  ' set initial time
    Hours = 1
    Minutes = 3
    Seconds = 10
    GOSUB StartTimer          ' Start the Elapsed Timer
    CountDown = !PORTB.0
      IF SecondsChanged = 1 THEN
         SecondsChanged = 0
         LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
      IF ZERO_LED != ZERO THEN ZERO_LED = ZERO
    GOTO Main
    If would be greatly appreciated is someone has this file they can share.
    Thank you
    Jan 2013
    Texas USA
    Default Re: Looking for Elapsed_DN.bas by Darrel Taylor
    TABSoft
    Jul 2010
    OK, I got it.
    Thanks again
  1. Darrel Taylor 18f interrupts
    Last Post: - 8th March 2015, 22:20
  2. Darrel Taylor Interrupts and MultiCalc
    By AvionicsMaster1 in forum General
    Last Post: - 14th February 2012, 07:18
  3. To Mr. Darrel Taylor once again
    By atwoz in forum mel PIC BASIC Pro
    Last Post: - 10th December 2009, 20:10
  4. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 02:22
  5. @Darrel Taylor Interrupt ;-)
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 01:59
