Play & Record PWM audio?
Results 1 to 9 of 9
    Aug 2003
    Default Play & Record PWM audio?
    Hi Guys,
    I’m wondering if anything has been done in the way of converting audio directly to PWM
    and playback with hardware PWM? Or am I on my own?
    Recording either analogue input, or digitising to 1 bit and counting frequency directly.
    I’m going to try the latter first.
    I know about RB’s pic sound playback, but IIRC the PBP implementation could not be fast enough.
    Cheers, Art.
    Default Re: Play & Record PWM audio?
    It can be done and it sounds decent.
    Norm
    Aug 2003
    Which method and at what speed are you talking about?
    Even at 10MHz with midrange pic I can:
    loop:
    outputpin = inputpin
    goto loop
    and that starts to get somewhat intelligible, but you couldn’t do anything with it.
    If I sample the audio frequency for a period, then set the HPWM,
    I find the more often I set the HPWM, the less gate time I get to count the input.
    Art
    I used a 18F26K20 hardware PWM and a timer interrupt to set 10 bit data read from an SD card WAV file to an audio amp at a 44.1K data rate.
    If I remember right that's CD mono quality.
    There are very few components i.e. PIC, SD card, audio amp and a speaker.
    Norm
    Aug 2003
    If the CD player had a 1 bit DAC.
    I’ve used RB’s audio reading from EEPROM fine in projects, the slow down is processing incoming audio as well.
    I’ll wait for a faster crystal to continue, but might be better off measuring the width of an audio wave rather than counting zero crossings,
    so then there is more time to do something with the data.
    HPWM command is a bit crook as well trying to update it fast. I’m sure it has to figure out,
    and write all four registers associated with HPWM each time it’s called.
    I got it smoother by limiting the frequency range and only altering the PR2 value.
    Still I don’t think it can be saved to EEPROM, even if interleaved to avoid the 10ms wait.
    I have so far kind of a voice controlled PWM, some fun could be had there, so I’ll look at making that faster.
    Yeah, the HPWM command adds a bit of overhead (write configuration register, period register, duty register) so if you need fast duty cycle updates just configure the CCP module manually and write the duty register each update.
  1. Port indexing & PWM for LED fade
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2013, 22:56
  2. Pwm & dac
    By J. Mark Wolf in forum mel PIC BASIC Pro
    Last Post: - 24th October 2010, 12:59
  3. Audio Record/Playback Circuit
    Last Post: - 12th February 2010, 18:58
  4. 4 Low Speed PWM & HSERIN
    By MasterSparky in forum mel PIC BASIC Pro
    Last Post: - 8th October 2007, 19:12
  5. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 02:24
