16 bit conversion - AM2302
Results 1 to 13 of 13
    Oct 2009
    Default Re: 16 bit conversion - AM2302
    tabsoft thanks for the detailed explanation of how the section works, and for the modified code to include the temperature readings as well.
    The project that I'm developing uses DT's interrupts and DS18B20 include files to control the PID routines for the thermostats. Using the temperature element in the AM2302 would be better as it saves having multiple sensor probes going to the snakes enclosures. I'll try out your suggested code so that it works with the existing variables to see how it works. My main concern is that as the code uses DT's interrupts it continues to drive the heaters whilst the pic is doing other things such as entering the menu options.
    Thanks once again fo your help, and for explaining what you did in such detail. It makes the learning process a lot simpler :-)
    Jan 2013
    Texas USA
    Noticed I made a small mistake on using the correct variable (used j instead of k) during the Humidity/Temperature Pulsewidth-to-Bit value conversions.
    dht_data var PORTA.1
    dht var byte[40]    'Holds pulsewidth counts of sensor data
    fHum var byte       'Final humidity value integral and decimal place
    fTemp var byte      'Final temperature value, integral and decimal place degC
    checksum var byte   'Checksum of payload data from sensor
    chkError var bit    'Flag for checksum error
    j var byte          'Generic counter
    k var byte          'Generic counter
    chkError = 0
        gosub read_dht
        if !chkError then
            'Print out sensor values
            LCDOut $FE,$80,"T ",dec fTemp/10, "." dec fTemp //10
            LCDOut $FE,$80+9,"RH ",dec fHum/10, "." dec fHum //10
            'Print out checksum error
        pause 2000
    read_dht:
        '*** NOTE: You should disable interrputs during this subroutine.
        '***       Sensor communications are timing sensitive
        TRISA.1 = 0 ' Make the sensor data pin an input
        '**Intialization sequence to sensor**
        high dht_data   '250ms High on data pin to sensor
        pause 250
        low dht_data    '20ms Low on data pin to sensor
        pause 20        ' send 20ms low
        high dht_data   '40us High
        pauseus 40
        'Read the sensor's acknowledgment of init sequence
        PulsIn PORTA.1, 1, dht[0]  'Read a High pulse from the sensor data line
        if dht < 20 then goto badresponse   'Not a good signal, maybe noise? Changed this to < 20
        '**End of Initialization sequence"
        '**Load the data from the sensor into the dht byte array
        for j = 0 to 39 step 1  'Record the bits in correct order (not reverse order)
            PulsIn PORTA.1, 1, dht[j]  'Read data High pulses (bits) from the sensor and store them as pulsewidth counts in individual bytes in the dht byte array.
        next j
        '**End of Load Data**
        '**Convert the Humidity dht byte array to a 16bit word variable
        'Stuff values into hum word variable based on the pulsewidth value in dht byte array
        'Use "fHum.0(j)" to select a specific bit position in the fHum word variable.
        '0.[j] is treated as an bit-offset into the hum variable. E.g. 0.[0] = fHum.0, 0.[1] = fHum.0+1, 0.[2] = fHum.0+2, etc
        fHum = 0 'Clear fHum word variable which holds the final 16bit humidity value
        k = 0  'Used to select the correct bit in the fHum word variable
        for j = 0 to 15 step 1   'Read the 16 bytes for humidity in the dht byte array (humidity pulsewidth values)
            if dht(j)>=35 then fHum.0[k] = 1 'If the pulsewidth is => 35us then the value is a "1".
            'otherwise, the value is a "0", so we do not need to do anything, all bits in "hum" were initialized to "0" with "hum = 0"
            k = k + 1
        next j
        '**End Conversion**
        '**Convert the Temperature dht byte array to a 16bit word variable
        fTemp = 0   'Clear fTemp word variable which holds the final 16bit temperature value
        k = 16  'Used to select the correct bit in the fTemp word variable
        for j = 16 to 31 step 1   'Read the 16 bytes for temperature in the dht byte array (temperature pulsewidth values)
            if dht(j)>=35 then fTemp.0[k] = 1 'If the pulsewidth is => 35us then the value is a "1".
            k = k + 1
        next j
        '**End Conversion**
        '**Convert the Checksum dht byte array to a 16bit word variable
        checksum = 0   'Clear Checksum word variable which holds the final 8bit checksum value
        k = 32  'Used to select the correct bit in the fTemp word variable
        for j = 32 to 39 step 1   'Read the 8 bytes for checksum in the dht byte array (checksum pulsewidth values)
            if dht(j)>=35 then checksum.0[k] = 1 'If the pulsewidth is => 35us then the value is a "1".
            k = k + 1
        next j
        '**End Conversion**
        'Test the checksum
        chkError = 0    'Reset checksum error flag
        if checksum <> fHum + fTemp then
            chkError = 1
    badresponse:
        LCDOut $FE,$80+9,"RH N/C"
    TABSoft
  1. DHT22, AM2302 and pic18F2320
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 15th November 2015, 01:42
  2. Replies: 10
    Last Post: - 8th March 2015, 20:26
  3. Replies: 17
    Last Post: - 22nd May 2014, 20:58
  4. Bit conversion
    Last Post: - 5th November 2006, 12:11
  5. Conversion of 10-bit word into ASCII
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 16th January 2005, 15:26
