HERSOUT2 (Weird problem)
Results 1 to 18 of 18
    Nov 2009
    London
    Default Re: HERSOUT2 (Weird problem)
    When using STR, maximum number of bytes is 255. It is only one byte counter.
    Darrel already give simple workaround:
    HSERIN2 [STR MESS1\255, STR MESS1[256]\255]
    Thanks for the detail. What does this (bold highlighted) code do?
    Jan 2013
    Texas USA
    What PIC are you using?
    TABSoft
    Sep 2009
    Megahertz,
    MESS1[256] point to 256 byte in array. So you can receive next 255 characters.
    Nov 2009
    London
    Megahertz,
    So, can I write it as:
    HSERIN2 [STR MESS1[0]\255, STR MESS1[256]\255]
    Secondly, what will happen when it receives a $00 byte? and how do I convert this received data (512 bytes) back to hex format
    http://www.picbasic.co.uk/forum/showthread.php?t=272
    Data is stored in binary format. How you display or transmit is up to you.
  1. Pulsin weird problem
    By allenf in forum mel PIC BASIC Pro
    Last Post: - 18th September 2013, 19:33
  2. Weird problem with Debugin
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 4th June 2013, 07:18
  3. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 12:16
  4. Weird Problem
    By isaac in forum General
    Last Post: - 22nd September 2008, 20:30
  5. PIC18F got some weird problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 17:18
