Play & Record PWM audio?
Results 1 to 9 of 9
    Default Re: Play & Record PWM audio?
    Hi guys,
    This is a very interesting topic.
    Does anyone has a sample code so we can try?
    Rui
    Aug 2003
    It’s really a matter of reading a pin for a period and outputting that frequency.
    You could probably use PULSIN for a period after sorting out mic hardware to trigger the pic input.
    I used an LM358 op-amp to drive a condenser mic.
    I’m using DT’s timer, and most assembler now, but still a simple program.
    On interrupt, a frequency value is written to hardware PWM one way or another (that I haven’t settled on),
    then the frequency variable cleared before returning to main program.
    The main program only counts audio transitions with the frequency variable in a loop.
    Tonight I got desperate and connected a 64.5 MHz crystal to the pic 16F628A and it works fine!
    I don’t know if it’s actually clocking at that frequency, but I have used 24/25 MHz crystals which have always gone fine,
    and it’s now much faster than them.
    Aug 2003
    The example where it’s the loudest in the video (quite an obvious one),
    I think I would have 80’s style speech recognition down.
    That variation of the code was very repeatable for words/phrases.
  1. Port indexing & PWM for LED fade
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2013, 22:56
  2. Pwm & dac
    By J. Mark Wolf in forum mel PIC BASIC Pro
    Last Post: - 24th October 2010, 12:59
  3. Audio Record/Playback Circuit
    Last Post: - 12th February 2010, 18:58
  4. 4 Low Speed PWM & HSERIN
    By MasterSparky in forum mel PIC BASIC Pro
    Last Post: - 8th October 2007, 19:12
  5. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 02:24
