RCSTA1 issue?
Results 1 to 10 of 10
Thread: RCSTA1 issue?
    Default Re: RCSTA1 issue?
    Does it matter where the define goes?
    no defines can go anywhere but for readability most keep them altogether and before the main code begins
    you have not specified the version of pbp used it may mattter
    DEFINE HSER_CLROERR 1 is definitely a pbp3 define I'm not sure if it applies to pbp2.xx maybe someone else can verify or maybe even rtfm , my pbp2.6 book has been misplaced (again)
    As far as I know DEFINE HSER_CLROERR 1 (for the second USART it's DEFINE HSER2_CLROERR 1) is available in PBP2.x as well. But, remember that it only "works" when you're actually using HSERIN, if you "drive" the USART manually (like when you do DAT_IN1 = RCREG1) it won't do anything and you'd need to check/clear the overrun flag manually. It all it does is clear the overrun error flag (if set), it won't do anything to actually prevent the overrun condition in first place.
    The main issue here is most likely the overall structure of the program. The data needs to be read from the USART buffer before the next byte comes in, the "best" way to handle this (if you don't know when data is about to come in) is usually to use interrupts. I don't know how you're handling it in your program (I may have missed it).
    New Jersey
    Overruns aren't really a problem, except when that condition locks up the device. More importantly, you pointed out something I never caught onto. So there is a HSER@2_CLOERR 1 define.
    I use HSERIN/HSERIN2 to get all data and I use interrupts to get it. If I understand your post correctly, I can remove this:
    IF RCSTA1.1 = 1 THEN
           RCSTA1.4 = 0
           RCSTA1.4 = 1
           DAT_IN1 = RCREG1
           IF PIR1.5 = 1 THEN DAT_IN1 = RCREG1
    And just use this:
    Is that correct?
    Hi Christopher,
    Yes I believe that's correct. I Think what that define does is add code "in front" of the actual HSERIN code so that it checks the overrun flag and, if set, takes care of it.
  1. IF-THEN issue
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 12th February 2014, 23:09
  2. TMR1 issue
    By Lestat in forum General
    Last Post: - 29th August 2012, 16:41
  3. Timing issue
    By gadelhas in forum mel PIC BASIC Pro
    Last Post: - 29th November 2011, 15:13
  4. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  5. 16F877A issue
    By DynamoBen in forum Off Topic
    Last Post: - 31st August 2007, 05:15
