10 bit PWM 16F1824
Results 1 to 4 of 4
    Default 10 bit PWM 16F1824
    Hi all
    amazing how fast the rust grows when you put this stuff down for a little bit
    i thought for sure there was a PBP high level command for PWM that would do 10 bit, but it seems not, just wanted to confirm that is true, 8 bit only ?
    i guess i banged the registers when i did 10 bit but it was quite a while ago and i don't even know which of many projects
    my chip for new project is 16F1824
    (yes i saw the recent post about 16F1509)
    any other tips, code snpis or pitfalls to watch for ?
    i did a search for 10bit PWM but did not see much, maybe i did not do the search right
    thanks
    Default Re: 10 bit PWM 16F1824
    Darrel wrote a 10 bits PWM code snippet ...
    may be yes ...
    wow, thanks a lot Alain
    this exactly what i was hoping for
    i got it to compile fine using PBP 3.0.7.4 and MPASM 5.49
    i won't know if it works for about a week when the hardware is ready
    as mentioned the chip is 16F1824, in the config section Darrel commented something about 18F only, should i be concerned about that ?
    and if so is it a big deal to alter the code ?
    i only need one channel of PWM (at least i think so, you know how these things grow though)
    the test program was tested (!) aboard a pic 18F ...
    that's the one and only reason of those lines here.
  1. 10-Bit PWM using PIC16F1509
    By Aussie Barry in forum mel PIC BASIC Pro
    Last Post: - 17th February 2020, 10:28
  2. DMX512 Reception + 3 * 8-Bit PWM Outputs
    By JEC in forum Code Examples
    Last Post: - 16th February 2015, 16:21
  3. 16 bit PWM using CCP1
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 09:13
  4. manual hardware PWM setup on 16F1824
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 31st January 2011, 19:34
  5. 10 bit pwm as dac
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 16:12
