decimal input on portB
Results 1 to 9 of 9
    Apr 2015
    Question decimal input on portB
    Hello from french wine town !
    I'm newbie : it's first post here and I work on my second program
    Thanks to Dogan's books and this forum to show what can be done with pbp.
    Today I would like to divide portB inputs in two groups of 4 bits and get the two numbers in order to use them in branch loop.
    Help would be appreciated.
    have a nice day
    Default Re: decimal input on portB
    Sancerre, I would:
    1. read the port of choice into a single BYTE size variable.
    2. AND port read variable with $F0 and place into separate variable to separate the upper nibble. (4 bits)
    3. AND port read variable with $0F and place into separate variable to separate the lowerr nibble. (4 bits)
    There you have it. I am assuming you are talking about BCD when you are talking about decimal?
    EN82fn
    Jan 2013
    Texas USA
    One way to accomplish this is this way.
    This will copy the upper 4 bits of the value of PORTB into a new byte variable in the lower 4 bit positions and will copy the lower 4 bits of the value of PORTB into another byte variable in the lower 4 bit positions.
    myPortB var byte
    HighNib var byte
    LowNib  var byte
    myPortB = PortB
    HighNib = myPortB >> 4   'Right shift myPortB 4 bits, (moves bits 7:4 to bits 3:0 and then set bits 7:4 to 0)
    LowNib  = myPortB & %00001111   'Mask off bits 7:4 to 0, Only get bits 3:0
    So if PortB = %10010110 '$96
    Then
    HighNib = %00001001 '$09
    LowNib  = %00000110 '$06
    TABSoft
    Apr 2015
    Question Re: decimal input on portB
    Hi all,
    Decimal or Hex ? It's depend of BRANCH syntax. Can I write something like
    BRANCH PORTB [dog, cat,fish] ???
    For nibbles, I can choose between
    initial:
    TRISB = 111111
    SWVAR VAR BYTE
    SWVAR1 VAR BYTE
    SWVAR2 VAR BYTE
    code1:
    SWVAR = PORTB
    SWVAR1 = SWVAR & $0F
    SWVAR2 = SWVAR & $F0
    or code2:
    SWVAR1 = SWVAR >> 4 'Right shift myPortB 4 bits, (moves bits 7:4 to bits 3:0 and then set bits 7:4 to 0)
    SWVAR2 = SWVAR & %00001111 'Mask off bits 7:4 to 0, Only get bits 3:0
    switches will be active when pulling down... Do I change something in my code ?
    Thanks for your time. Have a nice day. Oleg
    Jan 2013
    Texas USA
    What version of PBP are you using?
    TABSoft
    Apr 2015
    Bonjour
    Quote Originally Posted by Tabsoft View Post
    PBP 2,5.
    Have a nice day.
    Jan 2013
    Texas USA
    Yes, you could use the BRANCH command as you have described, "BRANCH PORTB [dog, cat,fish]".
    That being said, I don't think I would use it that way.
    The BRANCH command has the following syntax, "BRANCH Index,[Label{,Label...}]"
    One issue in using the BRANCH command this way is that using a byte variable or Port Alias for the "Index" means you can have 256 possible values (0-255).
    Which might require you to create 256 Labels and add them to the Label list in the BRANCH command.
    The "Index" is just a number pointing to the list of "Labels" in the BRANCH command. E.g. BRANCH Index, [Label_0, Label_1, Label_2, ...]
    If Index = 0 then the program will Branch to Label_0, if Index = 1 then the program will Branch to Label_1, etc.
    If you are using the value of PORTB, there can be up to 256 different values which would make for one very long Branch command.
    "BRANCH Index,[Label_0, Label_1,... Label_255]"
    If it were me I would do something like this.
    myPortB var byte
    myPortB = PORTB
    if myPortB = 1 then GOTO Label_1
    if myPortB = 2 then GOTO Label_2
    etc.
    Label_1:
        'Do something
    Label_2:
        'Do something
    This gives you the power to pick and choose which values of PORTB you want to act on.
    You could also replace the GOTO portion above with GOSUB, which will jump to the Label_x, then at the end of your subroutine (Label_x) the "Return"
    command will cause the program to return back to the next instruction after the GOSUB.
    if myPortB = 1 then GOSUB Label1
    if myPortB = 2 then GOSUB Label2
    etc.
    Label_1:
        'Do something
    Label_2:
        'Do something
    You could similarly use the Select Case command.
    TABSoft
    Aug 2003
    This wouldn’t be needed if shift shifts in zero values which I think it does:
    Apr 2015
    Hi all,
    thanks for your valuable help. Following your advices, my code can look like :
    TRISB = %11111111
    TRISA = %00000
    SWVAR VAR BYTE
    SWVAR1 VAR BYTE
    SWVAR2 VAR BYTE
    SWVAR = PORTB
    IF SWVAR1 <>0 THEN GOTO SUITE
    if SWVAR2 = 1 then GOTO sound1
    if SWVAR2 = 2 then GOTO sound2
    if SWVAR2 = 3 then GOTO sound3
    SUITE:
    if SWVAR1 = 1 then GOTO sound1
    if SWVAR1 = 2 then GOTO sound2
    if SWVAR1 = 3 then GOTO sound3
    sound1:
    FREQOUT PORTA.0,4000,500
    sound2:
    FREQOUT PORTA.0,4000,1000
    sound3:
    FREQOUT PORTA.0,4000,1500
    sound4:
    FREQOUT PORTA.0,4000,2000
    Have a nice day.
    Oleg
  1. Decimal variable input with HSERIN command
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2013, 15:14
  2. PORTB.3 Input not working as expected.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 5th March 2013, 10:58
  3. Replies: 6
    Last Post: - 12th March 2011, 14:11
  4. portb input problems
    By lockjawz in forum mel PIC BASIC Pro
    Last Post: - 15th February 2011, 16:18
  5. Decimal value
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 7th April 2005, 17:39
