Does variable value change being transferred to code running in interrupt loop?
Results 1 to 28 of 28
    Default Re: Does variable value change being transferred to code running in interrupt loop?
    Yes, but program should not be terminated, it should be "paused" while another part is executing. Let me illustrate by this simple "CODE"
    Conventional BASIC:
    DO:
    FOR A=1 TO 10
    PRINT "A=";A
    NEXT A
    FOR B=1 TO 10
    PRINT "B=";B
    NEXT B
    LOOP
    The above program will print value of A first, and then it will print value of B.
    But I need a output like this:
    A=1
    B=1
    A=2
    B=2
    A=3
    B=3
    and so on.
    I need to somehow "multiplex" two different parts of code in a such way, that they would run in "parallel" If you have heard about Parallax "propeller" chip, which has 8 "cores" but they being executed sequentally, at high speed, so user gets feeling of multi-core system. So I want basically to emulate something like that.
    CuriousOne, The Parallax Propeller is truly a multicore processor. You would need multiple Pic's to do the same.
    I don't see the difference in your code next to what I am suggesting? The way your's is written it will not produce the output you require.And what do you mean terminated? How about this for an interrupt example:
    a = 1
    MAIN:
    if Interrupt = 1 then
    Interrupt = 0
    if PROG = 0 then
    gosub program 1
    gosub program 2
    a = a + 1
    if a > 10 then a = 0
    Program1:
    PRINT "A=";A
    Program2:
    PRINT "B=";B
    This will produce the output you require.
    Or without interrupts, Your way..
    A=1
    B=1
    DO:
    PRINT "A=";A
    PRINT "B=";B
    A=A+1
    B=B+1
    IF A > 10 THEN A = 1
    IF B > 10 THEN B = 1
    LOOP
    This will produce the same output you require.
    EN82fn
    Aug 2003
    If you’re going that way it would make more sense to do the PWM in your main code and handle button pushes in the interrupt.
    So you’d interrupt on port change and change some variables in the ISR and don’t have to run a loop polling buttons.
    Either way unless the PWM is timer driven, it’s still not “emulating something like that”. Even though you might get the job done.
    Simply saying, windows is multi tasking OS, and can do multi-tasking even on single core CPU. How to do it similar way on PIC ?
    Aug 2003
    With a hardware timer. ie. Time slice, time splitting.
    The same way other platforms and threading languages (C) do it.
    a = 1
    MAIN:
    Interrupt = 0
    if PROG = 0 then
    gosub program 1
    gosub program 2
    a = a + 1
    Program1:
    PRINT "A=";A
    Program2:
    PRINT "B=";B
    A=1
    B=1
    DO:
    PRINT "A=";A
    PRINT "B=";B
    A=A+1
    B=B+1
    LOOP
    The main difference is that I need it to work like this:
    advance code 1
    advance code 2
    loop
    The "PRINT" was just an example, of course if I want to print two variables at same time, I know how to do this
    And doing it in both way means that I have to prematurely exit from FOR/NEXT loop, and I can't return to inside it.
    Let me explain once again what I need.
    In above example, I have two for/next loops, each with 10 steps. Is there a way to execute them like one step from code a, one step from code b and so on. Execute by not modifying code as you did (because it works for this certain case, but in real life it might be totally impossible to do like you did), but just distributing processor time between two codes ?
  1. Can not change variable while using DT_INT?
    By hvguy0 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2013, 00:05
  2. Altering a variable in a loop.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 18th September 2012, 07:24
  3. Change a variable to the opposite?
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st June 2012, 08:00
  4. Change variable allocation to save code space
    By aberco in forum mel PIC BASIC Pro
    Last Post: - 5th September 2011, 02:28
  5. 16f84a running interrupt PICBASIC code
    By divaker in forum mel PIC BASIC Pro
    Last Post: - 31st July 2008, 16:49
