Does variable value change being transferred to code running in interrupt loop?
Results 1 to 28 of 28
    Default Re: Does variable value change being transferred to code running in interrupt loop?
    Just checked, sorry, I've pasted ENDIF at wrong place. It should look like this
    SOFTPWM:
    IF A=1 THEN
    HIGH LED1
    PAUSE 100
    LOW LED1
    PAUSE 100
    GOTO SOFTPWM
    and so on, for all LEDS and cases.
    I want to run this code in background of main task, so this is why I wanted to use interrupt. Seems like it is impossible?
    You mean you want to run the above lines of code as an interrupt? I don't think so.... The pauses will kill you.... What is your anticipated interrupt period?
    By the way, What processor are you using and at what frequency?
    EN82fn
    I want to run this task in a way, that main task won't interfere with it, nor it execution will affect main task.
    Processor can be any of 16F family at any possible frequency.
    Aug 2003
    It’s not the pauses, the loop never ends:
    SOFTPWM:
    code
    GOTO SOFTPWM
    Only your main program can do that.
    This ISR doesn’t allow your main program to ever run once it’s called.
    Aug 2003
    If you get this going I’ll do the rest from there.
    The code to flash one led on/off per second is only needed
    to prove the include file is being included from the right directory and everything works.
    At the speeds you’re talking about you can have up to eight software PWM channels
    who’s rising and falling edges are synchronised to the clock cycle fairly easily.
    especially easy if the frequency of the outputs are the same.
    DEFINE OSC xx
    ‘ tell PBP the clock frequency you’re using
    DEFINE NOCLRWDT
    ‘ this only means the program has it’s own clrwdt instruction
    ‘ you can still set the watchdog timer on at programming time
    include “Elapsed.bas”
    ‘ DT’s Elapsed Timer code from PBP forum
    ‘ drop the Elapsed.bas file in the PBP folder
    ‘don’t bother declaring SecondsChanged variable,
    ‘it should already be accessible because it’s declared in the include file
    ‘CMCON = 7
    ‘uncomment to set analogue ports digital if the device has analogue ports
    ‘and the led is connected to one of them
    trisb.1 = 0
    ‘ set led output whichever pin you have the led connected
    ledstate var bit
    gosub ResetTime		'reset time 00:00:00
    gosub StartTimer	'start timer
    cycle:
    @ clrwdt
    if SecondsChanged = 1 then
    SecondsChanged = 0
    ledstate = ledstate + 1
    portb.1 = ledstate
    ‘ use your led pin of course
    goto cycle
    Below is the actual code which currently runs on 16F870 @ 4mhz:
    FOR F=1 TO 8
    A=F
    C=F
    B=9-F
    FOR E=0 TO 10
    IF A=1 THEN PORTC.0=0
    IF B=1 THEN PORTC.1=0
    if c=1 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>1 THEN PORTC.0=0
    IF B>1 THEN PORTC.1=0
    if c>1 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>2 THEN PORTC.0=0
    IF B>2 THEN PORTC.1=0
    if c>2 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>3 THEN PORTC.0=0
    IF B>3 THEN PORTC.1=0
    if c>3 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>4 THEN PORTC.0=0
    IF B>4 THEN PORTC.1=0
    if c>4 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>5 THEN PORTC.0=0
    IF B>5 THEN PORTC.1=0
    if c>5 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>6 THEN PORTC.0=0
    IF B>6 THEN PORTC.1=0
    if c>6 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    IF A>7 THEN PORTC.0=0
    IF B>7 THEN PORTC.1=0
    if c>7 then PORTC.2=0
    PAUSE LODINI
    PORTC.0=1
    PORTC.1=1
    PORTC.2=1
    NEXT
    NEXT
    It smoothly dims in-out leds, as needed. Here I'm imitating external change of A,B,C by introducing variable F and altering it's value in loop. Imagine there's no that FOR/NEXT loop, and values of A,B,C are updated elsewhere, but this code runs in interrupt. Will it work?
    Aug 2003
    Depending on what your main code does, the answer might be yes.
    Just remembering that the ISR is tied up for any of those pauses that could happen.
    So maybe you’d have the first one, but I wouldn’t say you have the second one.
    The idea is to realize multichannel software PWM using interrupt.
    I want to run this code in background of main task.
    Because it’s not done in a way you could forget about it.
    If you sent a serial, LCDOUT, I2C, etc. command from your main program,
    and it got interrupted part way through for the above, the command in the main program wouldn’t work
    .. unless those pauses were extremely small maybe.
  1. Can not change variable while using DT_INT?
    By hvguy0 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2013, 23:05
  2. Altering a variable in a loop.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 18th September 2012, 06:24
  3. Change a variable to the opposite?
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st June 2012, 07:00
  4. Change variable allocation to save code space
    By aberco in forum mel PIC BASIC Pro
    Last Post: - 5th September 2011, 01:28
  5. 16f84a running interrupt PICBASIC code
    By divaker in forum mel PIC BASIC Pro
    Last Post: - 31st July 2008, 15:49
