Replacing dtdp relay with mosfets
Results 1 to 3 of 3
    Feb 2012
    PERTH AUSTRALIA
    Default Replacing dtdp relay with mosfets
    Hi Guys
    i would like to replace a DTDP relay with some descrete mosfets N and P pairs
    , but am having some issues with the cct i have made so far
    Description
    CCT A : works
    Q20 , Q18 pairs ensure polarity of the battery is correct as the battery charger modules dont have polarity protection
    Q19 isolates the bat charger MOD1 from the 7.2v when USB PWR is not on
    RLY1:B N/C connects the bat:B to bat:A when no USB PWR
    RLY1:B N/O connects bat:A to gnd so that MOD1 charger can charge it
    RLY1:C N/C uses the battery power when no USB Pwr
    RLY1:C N/O - connect USB to pwr cct , and charges battery
    Relay activated by USB pwr at 5v
    Note: USB power can be connected prior to batteries been installed in cct , as such incorrect battery polarity must be isolated , until corrected
    CCt B: does not work
    q100 = q20 IN CCT A
    q103 = q18 IN CCTA
    q101A works same as Q19 as described in cct A
    q102A: NCH replaces RLy1:B N/O in CCTA
    Q102B: Pch replaces Rly1:B N/C in CCtA
    Q101:B Pch replaces Rly1:C by isolating the 7.2v when USB PWr is on
    Problem:
    when q102A has USB_pwr = H , q102B remains on
    when q101:B remains on when USB_pwr is on
    suggestions ?
    power ccta.pdfpower cct b.pdf
    Default Re: Replacing dtdp relay with mosfets
    I keep thinking about the "chicken or the egg".
    I'm trying to wrap my head around circuit B but can't find the exact problem.
    Feb 2012
    PERTH AUSTRALIA
    i think it has to do with the voltages on q102b , gate vers drain voltage
    gate has 5v when usb_pwr is on , Drain has 3.7v , so differance is - 1.3v and is still on as a result ???
  1. Replies: 6
    Last Post: - 8th August 2013, 11:36
  2. MOSFETS and Solenoids
    By Tobias in forum Off Topic
    Last Post: - 30th September 2009, 08:49
  3. Mosfets versus Transistors
    By Security in forum Off Topic
    Last Post: - 22nd September 2008, 17:35
  4. How to find complimentary mosfets???
    By manumenzella in forum Schematics
    Last Post: - 27th June 2007, 05:27
  5. replacing chips
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 25th February 2005, 19:01
