DT’s Elapsed Timer Magic Trick
Results 1 to 22 of 22
    Aug 2003
    Default Re: DT’s Elapsed Timer Magic Trick
    That’s awesome. I just need to make a YouTube video right now 10 hours ahead UTC.
    This should be a pretty good April Fool’s joke.
    Aug 2003
    I’m disappointed
    I guess I’ll have to spill the answer tomorrow.
    Apr 2011
    Welches, Oregon
    I am a total noob, but I feel such cleverness deserves a guess - even if only to prove how far superior your skills. I am unwilling to just shrug and wait for you to reveal your skill without so much as voicing the consideration I have given - not so much a joke, but puzzle - you have provided.
    I will guess that there is some capacitance in the circuit and that you use some application of the RCTime constant as a reference; different clocks would, I think, reveal the clock speed by the timer values measured when charging and discharging a capacitor from a known voltage. I take my guess from watching the LED (which, I believe has a capacitance associated - and conveniently a resistor in series) which is slow to start - I'm hoping, because it is busy measuring...
    Aug 2003
    Interesting idea, but not tested by me so I don’t know if it would work
    The virtue in what I’m doing is someone might come up with a better way,
    and at the moment I would appreciate that.
    It’s not genius trust me, you’ll find out. Someone is close on another forum.
    2015 nominee for best computer generated animations.
    628A has two internal clocks
    Aug 2003
    I know of the 4MHz RC clock. What’s the other?
    Aug 2003
    It got figured out on another forum. A better way actually, without writing to the on-chip EEPROM at all.
    '*                    Microchip Pic 16F628 @ 8,16 or 24MHz                         *
    '*                                  Art 2015                                       *
    '*                          [email protected]                               *
    DEFINE OSC 20								'
    DEFINE NO_CLRWDT							'watchdog is cleared manually
    INCLUDE "Elapsed.bas"							‘modified to take a variable
    ' execution time!
    percount var byte							'
    wrtcount var byte							'
    clkvalue var byte							'
    xdata var byte								'
    'oscfreq var word							‘this is declared in Elapsed Timer file
    notreset var bit							'
    CMCON = 7									'set ports digital
    trisb.4 = 0									'set led output
    portb.4 = 0									'
    percount = 0								'
    clkvalue = 0								'
    notreset = status.bit4						'check wdt reset occured - 0 is did reset
    if notreset = 1 then						'was not reset by watchdog
    portb.4 = 1									'turn led on
    for percount = 0 to 255						'do eeprom writes until wdt reset
    pause 100									'
    write percount,$00							'
    next percount								'
    makereset:									'failsafe to make reset occur
    @ nop										;
    goto makereset								'
    else									'was reset by watchdog
    @ clrwdt									;clear the watchdog from now on
    wrtcount = 0								'reset write counter
    countwrites:								'count eeprom writes
    read wrtcount,xdata							'read byte
    @ clrwdt									;
    pause 10									'
    if xdata != $00 then						'
    goto donecount								'exit counting loop
    endif										'
    wrtcount = wrtcount + 1						'increment count
    goto countwrites							'
    donecount:									'
    for percount = 0 to 255						'erase the eeprom for next time
    pause 10									'
    @ clrwdt									;
    write percount,$FF							'
    next percount								'
    endif										'
    'gosub flashout								'for testing only
    oscfreq = 0									'reset oscillator frequency
    if wrtcount > 8 then						'11
    oscfreq = $B1E7									'set oscillator frequency
    endif										'
    if wrtcount > 18 then						'21
    oscfreq = $63C7								'set oscillator frequency
    endif										'
    if wrtcount > 27 then						'30
    oscfreq = $15A7								'set oscillator frequency
    endif										'
    gosub ResetTime								'reset time 00:00:00
    gosub StartTimer							'start clock timer
    cycle:
    @ clrwdt
    if Ticks > 49 then
    portb.4 = 1
    portb.4 = 0
    goto cycle
    flashout:									'flash out the count of eeprom writes before wdt reset
    for percount = 0 to wrtcount				'with the red led
    portb.4 = 1									'flash rate will still depend on oscillator frequency
    pause 250									'at this stage
    @ clrwdt									'
    pause 350									'
    @ clrwdt									'
    portb.4 = 0									'
    pause 250									'
    @ clrwdt									'
    pause 350									'
    @ clrwdt									'
    next percount								'
    pause 500									'
    @ clrwdt									'
    pause 500									'
    @ clrwdt									'
    pause 500									'
    @ clrwdt									'
    return										‘
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. Compiling error on Elapsed timer
    By tacbanon in forum General
    Last Post: - 9th September 2012, 14:09
  3. SPWM and Elapsed Timer
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 04:16
  4. Darrel Taylor Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 02:22
  5. DT Elapsed Timer
    Last Post: - 10th March 2008, 00:17
