The 3rd post down is a much clearer post of what I am having problems with:
http://www.picbasic.co.uk/forum/showthread.php?t=1997
This is a repost, but I am hoping that you guys might see one of these.
I am working on a delay project which uses 2 buttons one for increasing the delay and one for decreasing the delay. I am using the PIC16F84 and have a button connected to PORTB pin 5,6. LED on PORTB 3,4,7 and PORTA pin 3.
PORTB pin 4 is for showing the length of the delay, pin 3 for showing when both buttons are pushed that it saves the delay to EEPROM, 7 for showing when IncreaseButton is pushed, and PORTA pin 3 for when DecreaseButton is pushed.
The problem I am having is when I program the PIC16F84 it is starting at a delay of what I believe to be 30s when it should be 15s. This is according to this line:
data word (0),(1500) 'Save 1.5s delay to EEPROM at programming
Also, it doesnt seem that the buttons are changing the delay. What I dont understand is that everything worked until I added this above line.
Here is the code that I am working on:
''Increase/Decrease Delay with Buttons
Delay var word 'Declare Variables
x var word
IncreaseButton var PORTB.5
DecreaseButton var PORTB.6
read 0, Delay.BYTE0 'Save value in EEPROM to delay
Read 1, Delay.Byte1
Loop:
high PORTB.4 'Turn LED on
low PORTB.3 'Turn on LED from "saving" delay
for x = 1 to Delay 'For loop to run delay/ Allows button to be
'read without interrupt
pause 1 'Pause 1 ms
if IncreaseButton = 1 then 'When IncreaseButton is pressed
high PORTB.7 'Turn LED on to show button is pushed
pause 50 'Pause for 50 ms
if DecreaseButton = 1 then'If both buttons pushed then write delay
write 0, Delay.BYTE0 'to EEPROM
write 1, Delay.BYTE1
high PORTB.3
SetDelayCycle1:
'Loop to wait until buttons are released before going on
if DecreaseButton = 0 or IncreaseButton = 0 then
goto Loop 'Restart the delay
goto SetDelayCycle1
Delay = Delay + 500 'increase delay
if Delay => 30000 then 'If delay is equal to or greater than 30 sec
Delay = 30000 'then keep delay at 30 sec max delay
pause 100 'If at max delay length flash LED
low PORTB.7
high PORTB.7
IncreaseButtonCycle:
'Loop to wait until button is released before going on
if IncreaseButton = 0 then
LOW PORTB.4 'Turn LED off
pause 500 'Pause to show LED off before restarting delay
low PORTB.7
goto loop 'Restart the delay
goto IncreaseButtonCycle
if DecreaseButton = 1 then 'When DecreaseButton is pressed
high PORTA.3
if IncreaseButton = 1 then'If both buttons pushed then write delay
write 1, Delay.Byte1
high PORTB.3
SetDelayCycle2:
if IncreaseButton = 0 or DecreaseButton = 1 then
goto SetDelayCycle2
Delay = Delay - 500 'decrease delay
if Delay <= 500 then 'If delay is equal or less than 0.5 sec then
Delay = 500 'keep delay at 0.5 sec min delay
low PORTA.3
high PORTA.3
DecreaseButtonCycle:
if DecreaseButton = 0 then
low PORTB.4 'Turn LED off
low PORTA.3
goto DecreaseButtonCycle
next x
low PORTB.4 'Turn LED off after full delay cycle
goto loop 'Restart the delay (Infinite Loop)
end 'End of program
This probably is not a very efficent piece of code, but it was doing the job until I tried doing the DATA command. I tried using different values other than the 1500 such as.. 100, 500, 3000 and all of the values were causing the same thing to happen with a delay of what I believe to be 30s the max delay that I have for the piece. I also tried the EEPROM command with the same conclusion. Any help would be appreciated.
Michael
