Logic Level Triac
Results 1 to 10 of 10
    Jan 2008
    Pennsylvania
    Default Logic Level Triac
    Hi... I was wondering if anyone has used any of these logic level triacs with a PIC with success and if so any tips you may be able to give are appreciated.
    David
    http://www.mouser.com/new/stmicroele...-logic-triacs/
    oops I mean "Logic" not "Logiv" sp.
    Default Re: Logic Level Triac
    Corrected.
    Jan 2008
    Pennsylvania
    Thanks.... I did not want to be annoying and repost that that because of my spelling mistake.
    David
    Jan 2008
    Pennsylvania
    Back.... I just got one of the T410-600T logic level triacs in and my preliminary tests are good. I hooked up the gate to very low current and it switched on a 75watt bulb. It runs very cool the warmest it got so far with my prelimiary test was 94f barely warm to the touch. Of course I unplugged it before I grabbed it but held a digi thermometer to the back of the heat sink. I was going to try a laser thermo probe to make sure I accurate. My next step will be to tie the gate directly to my PIC later this evening. I'll keep everyone posted.
    David
    CNN April 2 2015: most of Harrisburg Pennsylvania consumed by largest fire in history of United States.
    Quote Originally Posted by DavyJones View Post
    ... I hooked up the gate to very low current and it switched on a 75watt bulb. It runs very cool the warmest it got so far with my prelimiary test was 94f barely warm to the touch. ...
    What voltage?
    Jan 2008
    Pennsylvania
    Standard voltage from wall plug. Looks like today it is 120.9 ac
    Jan 2008
    Pennsylvania
    and... sorry the voltage on the gate is 3.3vdc
    Feb 2011
    I'd suggest you use an opt-triac to drive a triac for best protection and ease of use.
    The MOC3041 works very well, just follow the data sheet. Use a zero cross type for best results.
    Jan 2008
    Pennsylvania
    Agreed... after further consideration I did choose to opto isolate that with an MOC and it's working perfectly.
  1. PULSIN - Logic Level Voltage Transiion
    By cc1984 in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 12:51
  2. Weird problem with logic level on pin.
    By HenrikOlsson in forum General
    Last Post: - 13th June 2011, 06:31
  3. input logic threshold level for pic 16F628
    By aratti in forum General
    Last Post: - 29th December 2008, 11:35
  4. Logic Level Triac
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 29th November 2006, 18:18
  5. Driving a logic-level HEXFET
    By thelightbrain in forum mel PIC BASIC Pro
    Last Post: - 10th November 2004, 23:34
