Hello Leonel,
I am going to assume what I posted was correct...Here is some code to look at...Using my code, I added just a few things to allow for all your switches.
Switching var byte;
Counter1 var word
  Counter2 Var word
  Loop:
  Counter1=0
  Counter2=0
  Loop2:
   if Counter1< 20
     if Counter2 <1000
     if switching=1 then Pause 1  'Pause 1/1000 of a second to make 20
     if switching=0 then Pause 2  'Pause 1/500 of a second to make 40
     if Portb.0=1 then
            turn on switch.
            goto Loop
      if Portb.1=1 then
            turn on switch.
            goto Loop
      if Portb.2=1 then
            turn on switch.
            goto Loop
      ....    (for each of your eight switches)
        Counter2=Counter2+1;
     Endif
     if(Counter2>=1000)
       Counter1=Counter1+1;
       counter2=0;
   if Counter1<20 goto Loop2
  Portb=0;  'turn off ALL of the switches!
  Blink light = on
  Pause 200  'pause 1/5 of a second to light up the light.
  Blink Light = off
  goto Loop:
The above code will take care of your switches, but the problem comes with your Blinky light every 20 seconds. If a person keeps pressing switches, your light will not blink every 20 seconds. Thus some kind of internal timer is needed to take care of your blinky to have it blink every 20 seconds.
Dwayne
