Timer PIC16F57
Results 1 to 26 of 26
Thread: Timer PIC16F57
    Feb 2005
    Portugal
    Default Timer PIC16F57
    Hello.
    Iīm trying to write a simple example that will make my ledīs flash every 20s.
    I understand timerīs in PIC16F872 because they have interrupts associated (TMR1), but iīm using PIC16F57 which only has one timer, TMR0, and no interrupts...
    TMR0 timer is an 8-bit special function register with working range of 256. Assuming that 4MHz oscillator is used, TMR0 can measure 0-255 microseconds range (at 4MHz, TMR0 increments by one microsecond), but how do i measure 20s with TMR0?
    Dec 2003
    Wichita KS
    Hello Leonel,
    I don't know what you want to do... but how complicated do you want to get????
    psuedo code..(that just may work, but haven't tested it).
    TRISB=%00000000
    Loop:
    Portb.0 = High
    Pause 500
    Portb.0=Low
    Pause 20000 'pause 20 seconds.
    goto loop
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Talking
    Hi, leonel
    At each interrupt, you increment ( or easier decrement !!! ) a counter ...which (inc) rements another counter if the first overflows ... which ( inc ) rements ...
    etc. etc.
    Permits to do something else during blinking ... ( isn't it Dwayne ??? )
    can be done with PBP or directly with assembler ... ( No, ... i didn't tell it ... my doctor said: no shock on the head, ... )
    PS : No interrupt ... so you poll for TMR0 overflow !!!
    Dec 2003
    Wichita KS
    Hello Alain,
    Alain >>Permits to do something else during blinking ... ( isn't it Dwayne ??? )<<
    Don't know <smile>. Simple program to blink a light?
    With change of Chips? With no info on the final project, With no intended purpose but to blink a light, and "Simple example"? I can only assume a Blinky Light...Hopefully He will have it running, and if the info we gave him doesn't pan out, He can give us more info, so that we can become a little more detailed <g>.
    Like What Ralph posted on the FAQ...
    Need chip #, Code, details, Projects purpose, and other things.
    I rememeber a while back, a person asked to change a 4 (separate) byte Hex to Decimal...I gave him the code, then his example had 5 (separate) bytes coming in, and he wondered why it didn't give him the right answer<g>.
    Dwayne
    Ability to Fly:
    Feb 2005
    Portugal
    Default Pause command
    Using pause command i donīt see if any other input. What i want is put my output high during 20s but at the same time see if other input goes high. If it goes high i will start over again, my time goes to 0s, and i will start counting 20s
    Wink
    Hi, leonel ...
    Don't shout at me but I did something like that with a resettable 555 and some CD4000 logic ... it was in one of my prior lives.
    Said honestly, the 16F57 is not really the best Choice here ...
    Feb 2005
    Portugal
    Default Space problems
    Yes, i know thatīs not the best choice, but itīs what i have i know that with some logic i can do that, but i have 8 inputs and mixing all together i will need "some CD4000" and i have space problems (in my box i have to put 8 relays, and all electronic...), thatīs why i want to use a cheaper PIC...
    Talking
    Your project looks like a quizz box ...
    20 second to answer ... who's the quickest of 8 !!!
    we REALLY need to know a lot more about your top secret weapon. ...
    if you really want help, of course
    Feb 2005
    Portugal
    Default Code - warning
    Hereīs my code to do what i said (with a little help of Dwayne).
    Compiling my code thereīs some warnings "Crossing page boundary -- ensure page bits are set." I read in PBP manual that i donīt have to worry because PBP take care of this for me. Itīs true?
    Dec 2003
    Wichita KS
    Hello Leonel,
    Leonel
    If itīis pressed i turn on the relay and stays on for 20s or 40s (depending the position of a switch). If one button is pressed while one relay is on the time goes to begin and the two relays stays on again 20s or 40s.
    Hummm....I see a 40 second delay.... not a twenty second delay... thus a new variable has been added
    Ok. let me get this straight...(correct me if I am wrong).
    1. You have 8 LED's (or relays).
    2. You have 1 switch that is connected to some kind of software relay that says 20 or 40 seconds. (I am going to assume you have this switch set to the 20 second position for this message)
    3. If #1 button is pressed, it will turn on relay 1 for 20 seconds (or 40, depending upon if the HighLow software switch is on or off) If a second button is pressed BEFORE the first relay resets, Both the first Relay and the NEW relay (The one that you just got through pressing) stays on for at LEAST another 20 seconds.
    4. If another button (lets say relay #3) is pressed BEFORE Button 1 and 2 go off in their allowed time, all 3 relays will be active for at least another 20 seconds..
    5. But at ANY time, there is a 20 second interval of NO button pressing, all the relays will turn off....
    Is this correct?
    Dwayne
    Ability to Fly:
    Dec 2003
    Wichita KS
    Hello Leonel,
    I am going to assume what I posted was correct...Here is some code to look at...Using my code, I added just a few things to allow for all your switches.
    Switching var byte;
    Counter1 var word
      Counter2 Var word
      Loop:
      Counter1=0
      Counter2=0
      Loop2:
       if Counter1< 20
         if Counter2 <1000
         if switching=1 then Pause 1  'Pause 1/1000 of a second to make 20
         if switching=0 then Pause 2  'Pause 1/500 of a second to make 40
         if Portb.0=1 then
                turn on switch.
                goto Loop
          if Portb.1=1 then
                turn on switch.
                goto Loop
          if Portb.2=1 then
                turn on switch.
                goto Loop
          ....    (for each of your eight switches)
            Counter2=Counter2+1;
         Endif
         if(Counter2>=1000)
           Counter1=Counter1+1;
           counter2=0;
       if Counter1<20 goto Loop2
      Portb=0;  'turn off ALL of the switches!
      Blink light = on
      Pause 200  'pause 1/5 of a second to light up the light.
      Blink Light = off
      goto Loop:
    The above code will take care of your switches, but the problem comes with your Blinky light every 20 seconds. If a person keeps pressing switches, your light will not blink every 20 seconds. Thus some kind of internal timer is needed to take care of your blinky to have it blink every 20 seconds.
    Dwayne
    Ability to Fly:
    Feb 2005
    Portugal
    Default Correct
    Yes... all your 5 points are correct. If you understand my code thatīs a good beginning!
    Thank you!
    Dec 2003
    Wichita KS
    Hello Leonel,
    Yes, I pretty much understood your code...
    Just a couple of suggestions.
    If and then statements...
    If a "IF statement has only one statement, you do not need a "endif".
    The if statement below NEEDS a endif
      If a > b then
           c=d
           d=f
           f=g
    this does not need a endif statement;
      if  a=b then c=d
      if d=f then d=g
    This will help you on your code space and readability...(Of course I must look whos speaking too <chuckle> I think my code is some of the hardest to read <g>)
    Dwayne
    Ability to Fly:
    Dec 2003
    Wichita KS
    Hello Leonel,,
    just had a brain fart to take care of your blinky light...
    Switching var byte;
      LightCount var Word
      Counter1 var word
      Counter2 Var word
      LightCount=0
      Loop:
      Counter1=0
      Counter2=0
      Loop2:
       if Counter1< 20
         if Counter2 <1000
         LightCount=LightCount+1
         If LightCount=20000 then
           LightCount=0
           Blink light = on
           Blink Light = off
         if Portb.0=1 then
                turn on switch.
                goto Loop
          if Portb.1=1 then
                turn on switch.
                goto Loop
          if Portb.2=1 then
                turn on switch.
                goto Loop
         Endif
         if(Counter2>=1000)
           counter2=0;
      goto Loop:
    I put a separate counter for the blinky... stuck the blinky in the routine so that it will be called all the time, removed it from the end of the routine and since you said it doesn't matter too much on the exact time.... well...
    Dwayne
    Ability to Fly:
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 18th January 2009, 00:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 09:41
