Again ADC with 12F675 ...
Results 1 to 30 of 30
    SWITZERLAND (french speaking)
    Default Re: Again ADC with 12F675 ...
    In your very first post, I couldn't find any clear description of your problem or goal....
    Quote Originally Posted by fratello View Post
    Resistor coupling is apparently not the same in those two posts - is this okay?
    Try this:
    Button 1 = 0 Volt => ADC 8 bits = +/-0 , ADC 10 bits = +/-0
    Button 2 = 1,25 Volts => ADC 8 bits = +/-64 , ADC 10 bits = +/-320
    Button 3 = 2,5 Volts => ADC 8 bits = +/-128 , ADC 10 bits = +/-640
    Button 4 = 3,75 Volts => ADC 8 bits = +/-192 , ADC 10 bits = +/-960
    I didn't built the circuit above; if ADC values are not stable, try with all R values ( :10) => 10k becomes 1k, 3k3 becomes 300Ohms and so on.
    As an alternative, you may want to have a look here "Compiled Tips ‘N Tricks Guide".Name:  RC ramp.jpg
    Roger
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for info !
  1. ADC values above 4095 for 12 bit ADC
    Last Post: - 1st February 2015, 22:24
  2. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 20:22
  3. 12f675
    By mystified in forum mel PIC BASIC
    Last Post: - 10th September 2007, 02:47
  4. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 01:55
  5. ADC on 12f675?
    By peu in forum mel PIC BASIC Pro
    Last Post: - 16th March 2005, 17:44
