DT Ints on 18F (First time user problem)
Results 1 to 16 of 16
    Default Re: DT Ints on 18F (First time user problem)
    I count two whiles but one wend
    WHILE 1
    A:		' CHECK IF MODEM IS WORKING OK AND SET ECHO OFF
    			HSEROUT2 ["SENDING AT",13,10]
    			HSEROUT ["AT",13,10]
    			GoSub GetResponse
    			HSEROUT ["ATE0",13,10]
    			GoSub GetResponse
    			HSEROUT2 ["ATE0 RESULT=OK",STR MESS\500,13,10]
    WHILE 1
    			HSEROUT2 ["SEND COMMAND",13,10]
    			HSERIN2 [STR MESS\500\13]
    			HSEROUT2 ["SENDING-",STR MESS,13,10]
    			HSEROUT [STR MESS,13,10]
    			GoSub GetResponse
    WEND
    ;WHILE 1
    GoSub GetResponse
    GoSub GetResponse
    WHILE 1
    GoSub GetResponse
    WEND
    Ignore the first While1 please.
    ___________________
    WHY things get boring when they work just fine?
    As I said, commenting out any of the WHILE 1 statements makes it compile just fine for the 18LF45K22 at my end - with or without the ReEnterPBP-18LP.bas file included.
    What version of MPASM are you using? (I'm using 5.45)
    not sure its a good practice to use hersin and hserout in an isr either
    b_c var word ; buffer count
    PIE3.5 I ASSUME IS RXINT ENABLE OR use
    @ INT_ENABLE RX1_INT
    GetData:
    mess[B_C]=RCREG
    if ( b_c > 499) OR ( MESS[B_C]=10) then
    bity=1
    PIE3.5=0 ; BUFFER FULL TAKE NO MORE or @ INT_DISABLE RX1_INT
    B_C=B_C+1
    @ INT_RETURN
    PIE3.5=0 might be wrong the example I was drawing from uses two euarts
    I am using PBP3 with MPLAB v8.90.
    @Richard - Tried taking everything out of the ISR except Bity=1. Problem stays the same.
    ___________________
    I concur with henrik it compiles for me with the bogus while removed
    Would it be possible if one of you guys can upload your copy of DT INT and REEnter. I will try compiling with them. It compiles fine if I remove the Interrupts!
    ___________________
    Yup, you want to keep the isr as short as possible; set only the flag.
    Then, back in main, check the flag, do the hser, then reset flag.
    Also, try adding a label to the main loop and a goto at the bottom.
    Thanks Demon, this is just a trial program and I wanted to set the PIC up properly before arranging the code nicely with labels etc.
    ___________________
    I can't guarantee I have not fiddled with these but here they are
    Nops the same error still exists.
    BTW if its not too much to ask, can you also upload the compiled HEX file so I can get some results in the mean time someone helps to resolve the problem.
    ___________________
    rename it back to . hex
  1. User Position, Velocity & Time II (D1h)
    By dj.lambert in forum GPS
    Last Post: - 31st July 2009, 09:21
  2. Problem with Dt Ints Interrupts
    By Quin in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 19:21
  3. Some initial help for a first time PBP user
    By jtburnham in forum mel PIC BASIC Pro
    Last Post: - 29th April 2006, 07:32
  4. First time with 18F pic...
    By gabrielg74 in forum mel PIC BASIC Pro
    Last Post: - 9th December 2005, 07:04
  5. need help first time user of picmicro
    By tekdavid in forum mel PIC BASIC
    Last Post: - 29th March 2005, 04:39
