I have the following code: (Using PIC18LF45K22)
What I am trying to achieve here is the response from the modem in the interrupt. I get the following errors when compiling:Code:Include "modedefs.bas" INCLUDE "DT_INTS-18.bas" INCLUDE "ReEnterPBP-18LP.bas" INCLUDE "ReEnterPBP-18.bas" DEFINE OSC 4 ;----[Device Configuration]--(See manual section 4.9)--------------------------- #CONFIG CONFIG FOSC = HSMP ; Internal oscillator block CONFIG PLLCFG = OFF ; Oscillator used directly CONFIG PRICLKEN = OFF ; Primary clock can be disabled by software CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled CONFIG IESO = ON ; Oscillator Switchover mode disabled CONFIG PWRTEN = OFF ; Power up timer disabled CONFIG BOREN =OFF ; Brown-out Reset DISabled CONFIG BORV = 190 ; VBOR set to 1.90 V nominal CONFIG WDTEN = OFF ; WDT is always enabled. SWDTEN bit has no effect CONFIG WDTPS = 512 ; 1:512 CONFIG CCP2MX = PORTC1 ; CCP2 input/output is multiplexed with RC1 CONFIG PBADEN = OFF ; PORTB<5:0> pins are configured as digital I/O on Reset CONFIG CCP3MX = PORTB5 ; P3A/CCP3 input/output is multiplexed with RB5 CONFIG HFOFST = ON ; HFINTOSC output and ready status are not delayed by the oscillator stable status CONFIG T3CMX = PORTC0 ; T3CKI is on RC0 CONFIG P2BMX = PORTD2 ; P2B is on RD2 CONFIG MCLRE = EXTMCLR ; MCLR pin enabled, RE3 input pin disabled CONFIG STVREN = OFF ; Stack full/underflow will cause Reset CONFIG LVP = OFF ; Single-Supply ICSP disabled CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode) CONFIG DEBUG = OFF ; Disabled CONFIG CP0 = ON ; Block 0 (000800-001FFFh) not code-protected - all protected actually CONFIG CP1 = ON ; Block 1 (002000-003FFFh) not code-protected CONFIG CP2 = ON ; Block 2 (004000-005FFFh) not code-protected CONFIG CP3 = ON ; Block 3 (006000-007FFFh) not code-protected CONFIG CPB = ON ; Boot block (000000-0007FFh) not code-protected CONFIG CPD = ON ; Data EEPROM not code-protected CONFIG WRT0 = ON ; Block 0 (000800-001FFFh) not write-protected CONFIG WRT1 = ON ; Block 1 (002000-003FFFh) not write-protected CONFIG WRT2 = ON ; Block 2 (004000-005FFFh) not write-protected CONFIG WRT3 = ON ; Block 3 (006000-007FFFh) not write-protected CONFIG WRTC = ON ; Configuration registers (300000-3000FFh) not write-protected CONFIG WRTB = ON ; Boot Block (000000-0007FFh) not write-protected CONFIG WRTD = ON ; Data EEPROM not write-protected CONFIG EBTR0 = ON ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks CONFIG EBTR1 = ON ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks CONFIG EBTR2 = ON ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks CONFIG EBTR3 = ON ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks CONFIG EBTRB = ON ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks #ENDCONFIG DEFINE HSER_RCSTA 90h ' Enable serial port & continuous receive DEFINE HSER_TXSTA 20h ' Enable transmit, BRGH = 0 DEFINE HSER_CLROERR 1 ' Clear overflow automatically DEFINE HSER_BAUD 4800 DEFINE HSER_SPBRG 51 ' 4800 Baud @ SPBRGH = 0 BAUDCTL.3 = 1 ' Enable 16 bit baudrate generator DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive DEFINE HSER2_TXSTA 20h ' Enable transmit, BRGH = 0 DEFINE HSER2_CLROERR 1 ' Clear overflow automatically DEFINE HSER2_BAUD 4800 ;DEFINE HSER2_SPBRG 51 ' 4800 Baud @ SPBRGH = 0 'SPECIAL FUNCTION REGISTER SETTINGS ' DISABLE SR LATCH SRCON0=0 '------------------------- ' DISABLE COMPARATORS CM1CON0.7=0 CM2CON0.7=0 '------------------------- ' DISABLE DAC MODULE VREFCON1.7=0 ' DISABLE FIXED VOLTAGE REFERENCE VREFCON0.7=0 '------------------------- 'DISABLE CTMU MODULE CTMUCONH=0 '------------------------- 'DISABLE ADC ADCON0=0 '------------------------- ' DISABLE HIGH/LOW VOLTAGE DETECT MODULE HLVDCON=0 '------------------------- '------------------------- ' DISABLE TIMER 0/1/2/3/4/5 T0CON=0 T1CON=0 T2CON=0 T3CON=0 T4CON=0 T5CON=0 T6CON=0 '------------------------- ' INTERRUPT SETUP RCON.7=0 INTB0 VAR INTCON.1 INTCON=0 '%00010000 INTCON2=%00000000 INTCON3=0 PIE1=0 PIE2=0 PIE3=0 PIE4=0 PIE5=0 LATA=%00000000 LATB=%00000000 LATC=%00001000 LATD=%00000000 LATE=%010 'PORTA initialises as ANALOG INPUTS except A4 - Keep then as it is to reduce power TRISA=%11101111 : ANSELA=%11101011 ' Make all pins ANALOG input except RA2 (MODEM STAT PIN) TRISB=%11111111 : ANSELB=%00111110 TRISC=%10100101 : ANSELC=%00100100 TRISD=%10100000 : ANSELD=%00011111 ' PORTD as test LED (RD6/7 ARE TX2/RX2)RD5 AS TEST INPUT TRISE=%000 : ANSELE=%000' TRISE=%100 : ANSELE=%100 (KEEP E2 FOR TESTING ' PORT MAPPING TO NAMES Pwr_Key Var LATE.1 COM VAR PORTE.2 ' VARIABLES DECLARED HERE COUNTER VAR BYTE Counter2 var byte MESS VAR BYTE[500] Bity Var BIT 'VARIABLE INITIALISATION------- Counter2=0 COUNTER=51 MESS=0 Bity=0 Pwr_Key=0 : PAUSE 2000 : Pwr_Key=1 PAUSE 10000 ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX1_INT, _GetData, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE RX1_INT ; enable external (INT) interrupts WHILE 1 A: ' CHECK IF MODEM IS WORKING OK AND SET ECHO OFF HSEROUT2 ["SENDING AT",13,10] HSEROUT ["AT",13,10] GoSub GetResponse HSEROUT ["ATE0",13,10] GoSub GetResponse HSEROUT2 ["ATE0 RESULT=OK",STR MESS\500,13,10] WHILE 1 HSEROUT2 ["SEND COMMAND",13,10] HSERIN2 [STR MESS\500\13] HSEROUT2 ["SENDING-",STR MESS,13,10] HSEROUT [STR MESS,13,10] GoSub GetResponse WEND GetResponse: While Bity=0 : wend Bity=0 Return GetData: Bity=1 HSERIN [STR MESS\500\10] HSEROUT2 ["RESULT=",STR MESS,13,10] @ INT_RETURN
Help please!Executing: "C:\Program Files (x86)\PBP3\PBPX.EXE" -ampasmwin -k# -p18LF45K22 "TRIAL2.BAS"
PICBASIC PRO(TM) Compiler 3.0.7.1, (c) 1998, 2013 microEngineering Labs, Inc.
All Rights Reserved.
Error[116] C:\USERS\PMARSTERS\DESKTOP\EES\TRIAL2\TRIAL2.ASM 846 : Address label duplicated or different in second pass (Z0003F)
Error[116] C:\USERS\PMARSTERS\DESKTOP\EES\TRIAL2\TRIAL2.ASM 909 : Address label duplicated or different in second pass (Z00040)
Error[116] C:\USERS\PMARSTERS\DESKTOP\EES\TRIAL2\TRIAL2.ASM 962 : Address label duplicated or different in second pass (Z00041)
Error[116] C:\USERS\PMARSTERS\DESKTOP\EES\TRIAL2\TRIAL2.ASM 993 : Address label duplicated or different in second pass (Z00042)
Halting build on first failure as requested.
BUILD FAILED: Tue Mar 24 10:18:40 2015
Nops
the same error still exists.
