LCDOut $FE,$94,"rh ",#hum/10,".",dec1 hum//10 this gives a value of 870.4
lcdout $FE, $94, hex2 dht(0), " ", hex2 dht(1), " ",hex2 dht(2), " ", hex2 dht(3), " ", hex2 dht(4) produces 38 00 16 00 22
In one of the other examples I've tested it has the following statement
humid=dht[31]*128+dht[30]*64+dht[29]*32+dht[28]*16+dht[27]*8+dht[26]*4+dht[25]*2+dht[24]*1
Using
lcdout $FE,$C0,"Humidity = ",#humid,"% " gives the humidity as a percentage.
Just trying to apply this to Richards code to get the same result
Not using the DHT11 sensor, what is the temperature around your test rig?
TABSoft
As I read the datasheet for the DHT11 a few of things jump out.
1. The resolution for the Humidity is 1%
2. The resolution for the Temperature is 1 degC.
The datastream is 40 bits long.
8bit integral RH data + 8bit decimal RH data + 8bit integral T data + 8bit decimal T data + 8bit check sum.
The algorithm you are implementing stores the bitstream into the dht array like this.
dht[4] = integral RH data
dht[3] = decimal RH data
dht[2] = integral T data
dht[1] = decimal T data
dht[0] = checksum
So the Hex data values you showed earlier "38 00 16 00 22" should be this
dht[0] = checksum = $38 (56 decimal) $00 + $16 + $00 + $22
dht[1] = decimal T data = $00 (this is the decimal portion of the Temperature, which will always be 0)
dht[2] = integral T data = $16 (22 decimal)
dht[3] = decimal RH data = 00 (this is the decimal portion of the Humidty, which will always be 0)
dht[4] = integral RH data = $22 (34 decimal)
I believe you do not need to perform any calculations to convert the RH data to a percentage.
That is what is giving you the strange results.
The calculation "#hum/10" is taking the hum variable and dividing it by 10.
The issue as I see it is that using the hum variable is not necessary and giving you the incorrect values.
PBP treats word variables as Little Endian numbers meaning the low order byte is stored first then the high order byte.
So when hum = _dht+3 and hum is declared as a word, PBP is looking at dht[3] & dht[4] as the word variable hum.
This would be $00 $22, but since we are looking at Little Endian numbers PBP will use dht[4] as the high byte and dht[3] as the low byte.
This makes hum = $2200 (8704 dec), which will result in 870 decimal when you divide 8704 by 10 and a result of 4 with 8704 // 10.
Making your output equal 870.4 as you say.
For the RH percentage you simply need to display the value in dht[4], something like this.
lcdout $FE, $94, dec dht[4], "%"
You do not need the ".",dec1 stuff since the DHT11 does not report a decimal place for RH or Temperature because of the resolution of the sensor.
As for the Temperature, if you are going to just use it as a Celsius number, there is no need for any calculation or conversion either.
Just simply display the value in dht[2]. E.g. lcdout $FE, $94, dec dht[2].
Hope this helps.
TABSoft
looks like the dht11 only has a 8 bit range for rh an t so the display needs to be
LCDOut $FE,$94,"rh ",#hum/100
or
LCDOut $FE,$94,"rh ",#dht[4]
my fault I stopped reading the dht11 data sheet when I saw the 40 bit timings were the same as a dht22 , I have no dht11 to test with
just an observation but the fineoffset wh1081 weather station that I have uses a dht11 and its readings vary greatly from those of the dht22 right next to it . somehow I think the dht11 is not very accurate
Guys thanks for your continued input.
using the #hum/100 gives 87% as the value, which to me seems rather humid, especially when the indoor humidity according to my maplins weather station says it's 51%. As a comparison I tried the following code which uses the pause and pulsein statements to read the chip
This gives 174c in our living room, with the humidity fluctuating between three values of 24%, 144% and 152%. Clearly there is something wrong with the hardware. I'm using a new solderless breadboard so I'll look at hard wiring the sensor and see if that helps, even though the connections between the Easypic board and sensor are next to each otherCode:ASM __CONFIG _CONFIG1H, _OSC_HS_1H __CONFIG _CONFIG2L, _PWRT_ON_2L __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L ENDASM '******************************************************************************* ' LCD (20 x 4) set up '******************************************************************************* DEFINE LCD_DREG PORTB ' LCD Data port DEFINE LCD_DBIT 0 ' starting Data bit (0 or 4) DEFINE LCD_EREG PORTB ' LCD Enable port DEFINE LCD_EBIT 5 ' Enable bit (on EasyPIC 5 LCD) DEFINE LCD_RSREG PORTB ' LCD Register Select port DEFINE LCD_RSBIT 4 ' Register Select bit (on EasyPIC 5 LCD) DEFINE LCD_BITS 4 ' LCD bus size (4 or 8 bits) DEFINE LCD_LINES 4 ' number of lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us '******************************************************************************* ' Defines Statements '******************************************************************************* DEFINE OSC 20 ' 18F4520 / 18F2520, 20mhz crystal ADCON1 = $0F clear '******************************************************************************* 'Analog and Comparator settings '******************************************************************************* ADCON0 = %00000000 'AD converter module disabled ADCON1 = %00001111 'All Digital ADCON2 = %00000000 CMCON = 7 'Disable Comparators '******************************************************************************* 'Port and Register settings (interrupts) '******************************************************************************* TRISA = %00010111 TRISB = %00000011 T0CON = %11000111 T1CON = %00000001 ; free-running, 1:1 prescaler TMR1H = %11111111 TMR1L = %11111011 '******************************************************************************* LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD '******************************************************************************* dht var byte[32] humidite var byte haut var byte bas var byte temp var byte x var byte dht11 var portA.1 '******************************************************************************* start: TRISA.1 = 0 ' high dht11 pause 2000 ' wait 2 sec low dht11 : pause 18' send 20ms low high dht11 : pauseus 30 ' send 40us hi TRISA.1 = 0 PulsIn PORTA.1, 1, haut if haut < 15 then goto start for x = 31 to 0 step-1 PulsIn PORTA.1, 1, dht[x] ' 1 next x For x = 31 to 0 step-1 if dht(x)>=9 and dht(x)<=21 then dht(x)=0 'if pulsewidth between 20 and 40uS then read as '0' if dht(x)>=29 and dht(x)<=41 then dht(x)=1 'if pulsewidth between 60 and 80uS then read as '1' next x humidite=dht[31]*128+dht[30]*64+dht[29]*32+dht[28]*16+dht[27]*8+dht[26]*4+dht[25]*2+dht[24]*1 temp=dht[15]*128+ dht[14]*64+dht[13]*32+dht[12]*16+dht[11]*8+dht[10]*4+dht[9]*2+dht[8]*1 lcdout $FE,1 lcdout $FE,$C0,"Humidite = ",#humidite,"% " lcdout $FE,$80,"Temperature = ",#temp,$DF,"C" goto start
Hummm
Well I've now soldered the wires direct to the sensor, and plugged the wires directly into the header on the EasyPIC5 board.
Dht(0) - 4 now reads 38 00 19 00 1F with a hum/256 value of 34.
whilst this seems to of resolved the issues with the breadboard, 34% humidity seems rather low, and quite a gap from the 50% shown on the weatherstation
Richard,
I don't think #hum/100 will give the correct result.
Since I. This example hum=8704 ($2200), 8704/100=87 ($57).
The correct result should be 34 ($22).
He just needs to use dht[4]
Or
To use a division calculation with hum it should be #hum/256.
This will right shift 8704 ($2200) 8 bits resulting in 34 ($22).
TABSoft
brain fade due to lack of coffee divide 256 is of course correct
attached the blue is a dht11 the red a dht22 in the same room
As Richard has stated, the DHT11 doesn't seem to be too accurate in his experience.
As far as your readings go 39 00 16 23
This is 35% RH and 22c Temp.
Just use dht[4] for RH and dht[2] for Temp.
TABSoft
Thanks guys - I'll look at getting a DH22 as I need something more precise given that this will be monitoring the humidity in my snakes enclosure.
