A bit of point to point goodness :)
Results 1 to 9 of 9
    Default Re: A bit of point to point goodness :)
    How about using a sort of sample compression?
    Instead of storing the state at a fixed interval have a 24bit 10, 50 or 100Hz tick counter running. Whenever something changes state you store the counter value and the state.
    If the state is 16 bits each record will be 5 bytes total.
    Even at 100Hz resolution the 24bit tick counter allows for close to two days of recording before overflowing.
    Nice proto build!
    Aug 2003
    I did think of both ways, either time stamp and data, or continuous data.
    I suppose I like the idea of a memory timer as well though
    SD card I remember reading it’s easy to access byte by byte raw mode, but I never looked into it.
    yes I probably could have gone nuts, and these EEPROMs are samples,
    but if you buy them they aren’t cheap considering what you pay per byte.
    Aug 2003
    ...and done
  1. Replies: 10
    Last Post: - 8th March 2015, 19:26
  2. Using floating point
    By andywpg in forum mel PIC BASIC Pro
    Last Post: - 25th February 2015, 06:10
  3. pic16f88, xbee's & point-2-point comms
    By rdxbam in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2009, 08:43
  4. Getting out of floating point
    By jcb344 in forum General
    Last Post: - 5th August 2008, 21:18
  5. help floating Point!
    By Eric in forum mel PIC BASIC Pro
    Last Post: - 7th December 2003, 21:18
