How long does it take for an 8 bit PIC to stabilize after Power-up?
Results 1 to 18 of 18
    Northern California
    Default How long does it take for an 8 bit PIC to stabilize after Power-up?
    I searched the FAQ's and didn't find an answer so here goes. We have an application that's
    currently using an NE556 and several transistors and resistors for timing and logic that we'd
    like to replace with a 12F629 using the 4MHz internal clock. We have experience with the
    12F629 but the external power to an LM7805 in this application is cycled on and off every 1.2 seconds.
    We need to generate a pulse within 50 milli-seconds of power-up; 50 milli-seconds seems like a long time.
    Looking at the datasheet, the Oscillation Start-up Timer Period is 25 micro-seconds using the 4MHz
    internal clock which looks fine; the Power-up Timer Period is 132 milli-seconds which is a problem. Does the
    Power-up Timer Period apply here - i.e. does it take 132 milli-seconds to stabilize?
    Craig
    Aug 2003
    Default Re: How long does it take for an 8 bit PIC to stabilize after Power-up?
    I imagine the power up timer is to wait for the crystal frequency to be stable, and that you could disable it
    if you had an external clock source continually running (not in your case).
    You could use a reset circuit (a resistor and a capacitor) on the MCLR pin to make a shorter reset time.
    Pretty sure the PWRT is belt and braces. If you don't need to startup in the minimum time and want to be completely stable.
    What would be the effect of a few clock cycles long/short slow/fast whatever?
    George
    George
    Northern California
    Thanks for the suggestion. I had considered adding a supercap to the power supply but didn't think to add a capacitor to the MCLR pin to retain the charge and prevent a reset.
    Craig
    Aug 2003
    That’s actually not what I was suggesting, but instead to disable the powerup timer which usually holds MCLR,
    and use the MCLR pin yourself that will lower the power up time to what is acceptable with a stock reset circuit
    consisting of a resistor and capacitor. But if you can use a cap on the supply, the thing I’m working on now
    continues to multiplex a display for a couple of seconds after power off with two 470uF caps.
    I had a quick look at the datasheet and I see that the Oscillator Start-up Timer is not invoked if an internal clock is selected. I couldn't find a figure for how long the internal clock takes to stabilize but the "Oscillator Wake-up from Sleep start-up time" is 8us (worst case)
    I think it's important to note that the power up timer is optional, so MC must forsee a situation where it is not used.
    If you believe that some delay after power up is necessary, Art's idea is the way to go.
    if you have space, how about a string of NOPs at the reset vector?
    George
    How long is the power off for?
    Aug 2003
    Interesting, I’d have thought it’s the internal RC clock that would be the option wanting to be stabilised,
    but really don’t know how the startup of either clock really looks on a scope, etc.
  1. How do I use 10 bit A/D on 8 bit Pic? 12F675
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2020, 21:10
  2. Replies: 3
    Last Post: - 24th September 2013, 19:01
  3. long countdown timer, how to save power?
    Last Post: - 15th November 2008, 06:15
  4. signed long (32-bit) variable
    By Stephan in forum mel PIC BASIC Pro
    Last Post: - 11th September 2007, 04:40
  5. Long Distance Input's to Pic
    By GregK in forum General
    Last Post: - 21st April 2005, 10:37
