Hopefully someone can comment on why my compiler doesnt know what ADCON1 & ADCON2 is for the 18F series chip.
If i take out ADCON2 and the usb stuff and compile for 16F877A it has no problems with ADCON1 - which to me suggest my support for a 18F4550 is buggered.
this compiles fine for the 16F877A:
DEFINE OSC 20
DEFINE LOADER_USED 1
'ADC defines
Define ADC_BITS 10 ' Set number of bits in result
Define ADC_CLOCK 3 ' Set clock source /32
Quanta con 1251
Adval VAR WORD
USBBufferSizeMax con 64 ' maximum buffer size
USBBufferSizeTX con 64 ' input
USBBufferSizeRX con 64 ' output
' the USB buffer...
USBBuffer Var Byte[USBBufferSizeMax]
USBBufferCount Var Byte
x VAR BYTE
TRISA.0 = 1 ' RA0 input
ADCON1 = %00001110 ' A/D channel 0
'ADCON2 = %10000011 ' Left justify for 10-bit
'usbinit ' initialise USB...
x = 0
LOW PORTB
BlinkLED:
if x = 7 then ProgramStart
x = x + 1
HIGH PORTB.7
PAUSE 1000
LOW PORTB.7
PAUSE 500
goto blinkLED
ProgramStart:
x = 0
gosub DoUSBIn
gosub DoUSBOut
goto ProgramStart
' * receive data from the USB bus *
DoUSBIn:
USBBufferCount = USBBufferSizeRX ' RX buffer size
' USBService ' keep connection alive
' USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
if usbbuffer[2] = 1 then
high portb.7
IF USBbuffer[2] = 0 THEN
LOW portb.7
goto DoAD
DoAD:
ADCIN 0,adval ' Read A/D channel 0 into ADval variable
ADval = ADval */ Quanta ' Quanta result
' Load data buffer
USBBuffer[0] = Adval dig 3 'Y.LowByte
USBBuffer[1] = "."
USBBuffer[2] = Adval DIG 2
USBBuffer[3] = Adval DIG 1
USBBuffer[4] = aDVAL DIG 0
' * wait for USB interface to attach *
DoUSBOut:
USBBufferCount = USBBufferSizeTX ' TX buffer size
'USBService ' keep connection alive
'USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
