Pic 18f Usb
Results 1 to 40 of 135
Thread: Pic 18f Usb
    Jul 2005
    Default Version info
    I have PBP Compiler 2.46, Microcode studio 2.2.1.1 and version 4.21 beta of MeLabs Programmer software
    Jul 2005
    Hopefully someone can comment on why my compiler doesnt know what ADCON1 & ADCON2 is for the 18F series chip.
    If i take out ADCON2 and the usb stuff and compile for 16F877A it has no problems with ADCON1 - which to me suggest my support for a 18F4550 is buggered.
    this compiles fine for the 16F877A:
    DEFINE OSC 20
    DEFINE LOADER_USED 1
    'ADC defines
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_CLOCK 3 ' Set clock source /32
    Quanta con 1251
    Adval VAR WORD
    USBBufferSizeMax con 64 ' maximum buffer size
    USBBufferSizeTX con 64 ' input
    USBBufferSizeRX con 64 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    x VAR BYTE
    TRISA.0 = 1 ' RA0 input
    ADCON1 = %00001110 ' A/D channel 0
    'ADCON2 = %10000011 ' Left justify for 10-bit
    'usbinit ' initialise USB...
    x = 0
    LOW PORTB
    BlinkLED:
    if x = 7 then ProgramStart
    x = x + 1
    HIGH PORTB.7
    PAUSE 1000
    LOW PORTB.7
    PAUSE 500
    goto blinkLED
    ProgramStart:
    x = 0
    gosub DoUSBIn
    gosub DoUSBOut
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    ' USBService ' keep connection alive
    ' USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available
    if usbbuffer[2] = 1 then
    high portb.7
    IF USBbuffer[2] = 0 THEN
    LOW portb.7
    goto DoAD
    DoAD:
    ADCIN 0,adval ' Read A/D channel 0 into ADval variable
    ADval = ADval */ Quanta ' Quanta result
    ' Load data buffer
    USBBuffer[0] = Adval dig 3 'Y.LowByte
    USBBuffer[1] = "."
    USBBuffer[2] = Adval DIG 2
    USBBuffer[3] = Adval DIG 1
    USBBuffer[4] = aDVAL DIG 0
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    'USBService ' keep connection alive
    'USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    Jul 2005
    I just applied the update for version 2.46 - no effect.
    Jul 2005
    Updated MPLAB & MPASM to latest version - no effect.
    Try this:
    Poke $fc0, $83 'which is the same thing as the line above.
    Jul 2005
    Ok that compiled... with warnings...
    Warning c:\progra~1\picbas~1\18F4550.inc 20: _CONFIG has been depreciated for PIC18 devices. Use CONFIG (repeated about 8 ti
    does the fact that the "POKE" command compiled tell us why ADCON1 & ADCON2 would not?
    Quote Originally Posted by RYTECH View Post
    PBP 2.47 shows fixes for miscellaneous items and a few other things.
    Maybe that's one of the fixes...who knows. And, heck, if Poke works, who cares
    Jul 2005
    Ok, so poke just manually writes values to the given registers?
    I'd still like to figure out why ADCON1 & ADCON2 is not working.
    Last edited by RYTECH; - 11th June 2007 at 00:19. Reason: I asked for the answer to a simple problem
    Sep 2006
    Mexico
    Download Microcode Studio 3.0
    http://www.mecanique.co.uk/code-studio/
    Jul 2005
    Yeah if the peek and poke work thats fine for me, I had used ADCON commands before and am a little stumped about why it would work in once case for a certain PIC and not for another (the 18F4550). I knew it might be a matter of having support for the specific chip. i'm hoping other commands don't have syntax errors as i go...
    I wonder if 2.47 resolves the Syntax error as I intend to start using the USB type 18Fxxxx type PICs
    How do i find the microcontroller register address for ADCON0 - ADCON1 - ADCON2, is it in the datasheet? ( the sections describing A/D operation dont seem to list the address locations)
    Jul 2005
    Exclamation Version 2.47
    Is there no downloadable version of Pic Basic Pro Upgrade 2.47. The shipping is like 3 times the cost of the cdrom!!
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB communication with pic
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 23:43
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
