Pic 18f Usb
Results 1 to 40 of 135
Thread: Pic 18f Usb
    Feb 2005
    Essex, UK
    Hi Bruce,
    I have now ordered the book as you recommended, i'm sure it will come in very handy.
    I have figured out that if you use EasyHID to set the maximum Buffer size to 32, then you can increase the amount of outputs on the PIC that you can set HIGH or LOW. ie the PIC side is odd numbers 1 - 31 and the VB side is even numbers 2 - 32.
    ie on the PIC side requires:
    PORTC.1 = USBBuffer[23]
    where as on the VB side requires:
    BufferOut(24) = 1 ' LED on
    If i want to use all of PORTA and PORTB, is there an easy way of listing these in the two codes, or do they have to be done seperately? ie:
    PIC
    PORTA.1 = USBBuffer[1]
    PORTA.2 = USBBuffer[3]
    PORTA.3 = USBBuffer[5]
    PORTA.4 = USBBuffer[7]
    PORTA.5 = USBBuffer[9]
    VB
    BufferOut(2) = 1 ' LED on
    BufferOut(4) = 1 ' LED on
    BufferOut(6) = 1 ' LED on
    BufferOut(8) = 1 ' LED on
    BufferOut(10) = 1 ' LED on
    Moving on from the switching of outputs HIGH or LOW, how would one send say text from the PIC to a text box in VB. For example, on the PIC, if a certain routine is executed, it sends a command to the VB application which is then displayed in a text window. Or is this getting too advanced for a quick explanation??
    Thanks again for you assistance,
    andresnavas's Avatar
    andresnavas Guest
    Unhappy EasyHID Files
    Hello. I don't know what happend but my EasyHID only create 4 files:
    DESCUSBProject.asm
    USBDESC.asm
    USBProject.asm
    USBProject.pbp
    What i doing wrong? why it don't creat the other files like the USB18.c
    Thanks for yours help!!!
    Please if somebody have any example send it to me at: [email protected]
    Thanks!
    Feb 2005
    Essex, UK
    andresnavas,
    I have sent the reply straight to your personal email address. It would appear that the files aren't generating properly. All i can suggest is check the compilation settings again. If that doesn't work, try installing the application again.
    I certainly haven't had any problems like that.
    Within the directory you specified in the project settings (default is C:\Program Files\Mecanique\EasyHID\) should see another directory as per your title, such as USBProject. Within that directory is 2 sub directories, one for the VB or C code and one for the Proton or PICBasic code.
    I have sent you a zip file containing what you should expect to see for a default VB and PICBasic code using the PIC18F4550 also with all the default settings.
    Hope this helps,
    judy's Avatar
    judy Guest
    Smile Newbie
    Hi all,
    Absolutely brilliant thread, a lot of quality info and best of all can be done fast, cheers to all those involved. I am really new to this interfacing stuff, so if I'm asking too much or the newbie stink is unbearable, feel free to tell me to sling my hook.
    I was wondering how one would go about changing the HID code provided by Easy HID USB code generator to simply read in up to three pulse width inputs (as far as I know the digital ins on the 18f2455 support this) and up to three analog ins through on board adc (ideally varying between -3 to +3v) simultaneously and as fast as possible, in fact how many samples per second is possible using the HID approach? Sin e.
    I would greatly appreciate any help with this/direction to where help should be sought.
    Thanks in advanced
    Judy
    Steve,
    You're dealing with bytes. PORTA.1 = USBBuffer[1] isn't the way to go since you can't place a byte value on a single port "bit".
    Just place the byte you need on the whole port. You can send a single byte value from the PC app, and simply place it on the port.
    I.E. PORTA = USBBuffer[1] should work fine - assuming that's the byte element you want.
    Sending data from the PIC to PC is equally simple. Here's one example. Note this isn't everything. Just the sections I added to the framework file created with EasyHID.
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    DEFINE	ADC_BITS 10     ' Set number of bits in result
    DEFINE	ADC_CLOCK 3     ' Set clock source /32
    DEFINE	ADC_SAMPLEUS 50 ' Set sampling time in uS
    DEFINE RESET_ORG 800h ' <-- I used the Microchip USB loader
    BufferSize      con 8
    DataBuffer      Var Byte(BufferSize) ' data buffer
    DataBufferCount Var Byte             ' buffer size
    Quanta  con 1251
    TRISD = 0
    PORTD = 0
    ' Variables
    X       VAR byte
    Adval   VAR WORD
        TRISA.0 = 1        ' RA0 input
        ADCON1 = %00001110 ' A/D channel 0
        ADCON2 = %10000011 ' Right justify for 10-bit
        USBInit
        GOSUB DoUSBIn
        PORTD = DataBuffer[7]
        ADCIN 0,adval		     ' Read A/D channel 0 into ADval variable
        ADval = ADval */ Quanta  ' Quanta result
        ' Load data buffer
        DataBuffer(0) = Adval DIG 3
        DataBuffer(1) = "."
        DataBuffer(2) = Adval DIG 2
        DataBuffer(3) = Adval DIG 1
        DataBuffer(4) = Adval DIG 0
        GOSUB DoUSBOut
        FOR X = 0 to 99 ' Short delay between updates
         PAUSEUS 1000
         USBSERVICE     ' Maintain HID connection during delay period
        NEXT X
        GOTO Main
    On the PC side, modify the USB framework file created with EasyHID something like this;
    Dim MyText As String ' create your string storage space
    In the OnRead sub-routine;
    MyText = (CStr(BufferIn(1)) + Chr$(BufferIn(2)) + CStr(BufferIn(3)) + CStr(BufferIn(4)) + CStr(BufferIn(5)) + "V")
    Label1.Caption = MyText ' Place string text into label displaying A/D value
    Judy,
    Reading three pulse widths or A/D values doesn't really have anything to do with USB. The USB PIC is just another PIC with the addition of the USB module. Using the onboard A/D is pretty much the same as any other PIC.
    All you need here is the datasheet, and a little time to experiment getting your pulse measurement & A/D routines working. Sending this all to the PC via the USB module is no more than stuffing your values into the outgoing buffer like in the previous example.
    Just be sure to keep the USB connection alive by avoiding the use of blocking functions, long delays, etc,,. It's really not that hard, but you will need to experiment a tad.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Essex, UK
    Bruce,
    Would you mind posting all of your ADC code, i am getting errors. I've had a look, but can't figure it out.
    The code posted above seems to be missing the DoUSBIn and DoUSBOut subroutines.
    I also get an error on the DataBuffer(1) = "."
    I want to use it as a 5v voltage monitor passing the results to Vb.
    Many thanks,
    Hi Steve,
    Sure. Here's the complete file. Just be sure you've used EasyHID to generate the required USB support files.
    DEFINE OSC 48
    DEFINE RESET_ORG 800h    ' For Microchip USB loader
    BufferSize      con 8
    Quanta  con 1251
    TRISD = 0
    PORTD = 0
    ' Variables
    X       VAR byte
    Adval   VAR WORD
        USBInit
        GOSUB DoUSBIn
        ADCIN 0,Adval		 ' Read A/D channel 0 into ADval variable
        ' Load data buffer
        DataBuffer(0) = Adval dig 3
        DataBuffer(1) = "."
        GOSUB DoUSBOut
         PAUSEUS 1000
        NEXT X
        GOTO Main
       ' USB in...
    DoUSBIn:
        DataBufferCount = BufferSize
        USBService
        USBIn 1, DataBuffer, DataBufferCount, DoUSBIn
       ' USB out...
    DoUSBOut:
        USBService
        USBOut 1, DataBuffer, DataBufferCount, DoUSBOut
    Here's the PIC & VB source for a USB A/D datalogger http://www.rentron.com/mcstudio/USB_AD.zip
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Great, thanks Bruce. Unfortuanatly i am still getting a big 0 in VB. I'm sure its only something small i am doing wrong (hopefully) !!
    Here is the code, can you spot anything obvious that i have done wrong?
    Its a PIC18F2455 where i am putting 5v onto RA0.
    DEFINE OSC 48
    'DEFINE RESET_ORG 800h    ' For Microchip USB loader
    BufferSize      con 8
    Quanta  con 1251
    ' Variables
    X       VAR byte
    Adval   VAR WORD
        USBInit
        GOSUB DoUSBIn
        PORTB = DataBuffer[7]
        ' Load data buffer
        DataBuffer(1) = "."
        GOSUB DoUSBOut
           PAUSEUS 1000
        NEXT X
     GOTO Main
    ' * receive data from the USB bus                            *
    DoUSBIn:
        USBService
    ' * wait for USB interface to attach                         *
    DoUSBOut:
        USBService
    In VB, i have placed a label on the form and this is in the read event section
    ' on read event...
    Public Sub OnRead(ByVal pHandle As Long)
       ' read the data (don't forget, pass the whole array)...
       If hidRead(pHandle, BufferIn(0)) Then
          ' ** YOUR CODE HERE **
          ' first byte is the report ID, e.g. BufferIn(0)
          ' the other bytes are the data from the microcontrolller...
       End If
    End Sub
    Many thanks again.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB communication with pic
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 23:43
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
