Pic 18f Usb
Results 1 to 40 of 135
Thread: Pic 18f Usb
    Feb 2004
    Germany
    Default Pic 18f Usb
    Has anybody worked with these PICs:
    18F2455, 18F4455, 18F2550, 18F4550
    and EaysHID yet?
    Do you have any experience (or code) to share?
    I have received my ICD2 today and started playing with a 18F4550.
    (PICSTART+ doesn't suport the 18F4550!)
    regards
    Ralph
    I've used it, and if you're looking to get started with USB, then Dave's new
    EasyHID & the PIC18F4550 are definitely the way to go.
    Download & install EasyHID.
    http://www.mecanique.co.uk/products/usb/easyhid.html
    I have several projects for USB coming shortly, but in the mean time, I've
    loaded the files for a complete USB project on our website.
    The zip file contains PBP source code for a PIC18F4550, and VB source for a
    USB analog data-logger. Should be fun for anyone interested in tinkering with
    EasyHID and the new full-speed 18F USB parts.
    Here are the files: http://www.rentron.com/mcstudio/EasyHIDPrj.zip
    You'll need VB6 & SoftWire. You can download SoftWire from here. It's free.
    http://www.softwire.com/swdownload/softwiredownload.htm
    I used the activx controls in SoftWire for the analog meter interface. Really
    nice stuff.
    You'll also need PBP version 2.46 since this is the version offering support for
    the newer 18F USB parts.
    If anyone's looking for an excellent book on USB, then grab a copy of Jan
    Axelson's new 3rd edition of USB Complete. We just got them in. I spent the
    last few days reading mine, and it's awesome.
    Jan has done an outstanding job on her 3rd edition of this book. Even "I" can
    understand it now...;o]
    -Bruce
    tech at rentron.com
    I'm also in the middle of trying to use EasyHID. I'm just not sure where the USB18.ASM file fits in the grand scheme of things.
    I used the PIC18F4550, PBP and VB. The file is in the project PBP folder.
    I also got USB Complete as well as USB Design By Example. It's too bad they chose to use EZ-USB chips from Cypress or else I could have used their examples directly. Unfortunately I don't know enough about MPASM Assembler, let alone Cypress' version to convert things around.
    Is it complicated to get the generated code to be compatible with the slower USB speed? I'd like to be able to connect to PCs that do not yet have USB 2.0.
    Bruce,
    I get a LOT more files generated on the PIC side?
    It's that large Assembler file with all the VERY important USB routines that I don't know where that fits in. It doesn't seem to be linked with the PBP base program at all, or I missed something?
    Bruce,
    Don't forget to add a README that mentions mcHID.dll and where the user can get it. Your PC-side code won't work without it.
    Hi Robert,
    You should have 8 (PBP) files total generated by EasyHID. All this stuff is required, and included when you compile for the 18F USB part.
    Look in your PBP\USB18 directory for USB.TXT. This explains what most of
    the files are.
    -Bruce
    tech at rentron.com
    aman_b's Avatar
    aman_b Guest
    Default links missing
    Hi
    I tried to access the link for zip file and the easy hid, but seems like they dont exist anymore. could you please attach them in the forum. That would very helpful
    Aman
    nice stuff.
    Sorry. These files are no longer available since the support applications you would need to install to use them have been discontinued.
    Mecanique dropped the free version of EasyHID, and the VB6 version of Softwire is no longer available. Without these two applications, the .zip file would be useless.
    See Mr E's USB example here: http://www.picbasic.co.uk/forum/showthread.php?t=5418
    -Bruce
    tech at rentron.com
    problem now will be the .dll. Not sure if we are allowed to distribute it
    Jul 2005
    So basically now it's part of microcode studio right?
    This confused me too for a bit till i saw it in Microcode studio's "view" menu.
    wjfong's Avatar
    wjfong Guest
    Default Re: Pic 18f Usb
    nice stuff.
    good day, just tried out the easyhid & got some problems here, haha... i got the error msg: unable to locate device item.
    can anybody tell me how can i rectify this problem??
    thanks alot
    Question
    I've just started on this, having been encouraged by EasyHID.
    I noticed that the interrupt check box is disabled if PBP is the device code genrator selected. Does this mean that PBP programs have to jump to service the USB every 10ms? That's surely not very practical.
    Do ME Labs have a fix in the pipeline for this or do I feel an upgrade to my neglected Proton+ coming on?
    I can't see me investing the time in making USB work with PBP if the USB connection cannot be maintained in the background.
    Any advice greatly welcomed.
    Brian Walsh
    Glasgow
    Scotland
    I haven't started on the USB aspect yet, but offhand I would say that's the function of the "USBservice" command.
    An easy way to manage this? I have absolutely no idea yet.
    Please somebody shoot me if i'm wrong, didn't find time to play enough with USB, BUT none of both compiler will do the refresh for you.. sorry. Timer interrupt one of the way to go or keep track of your code and sprinkle few USBSERVICE. No big deal
    paramotor's Avatar
    paramotor Guest
    Quote Originally Posted by NavMicroSystems
    and EaysHID yet?
    You have try this circuit from this project
    http://www.sixca.com/eng/articles/usbdaq.php
    Feb 2005
    Essex, UK
    Default Device Not Recognised
    I've built the simple piece of hardware using the 18F2550, it has been programmed as per the files generated by the EasyHID application.
    Having plugged the hardware into the USB port, it states the device is not recognised. I was expecting it to come up with the device name as i stated in the EasyHID compilation.
    I was expecting a .ini file or similar to be generated for the installation of the device.
    Can anyone help why this might be.
    Many thanks.
    Feb 2005
    Essex, UK
    OK, seem to have that issue sorted now, it actually was something to do with the programming fuses.
    Although it now connects OK, when i look at the device manager, it only shows up as a 'USB Human Interface Device' and HID-Compliant Device' and not as i set in the EasyHID maker.
    Also, can anyone help with what is required at the VB and PIC end to light a simple LED. ie when i click a 'button' in the VB code, it turns an LED on one of the ports, ie PORTB.1.
    Many thanks,
    Feb 2005
    Essex, UK
    Can anybody help with the above request or point me in a direction of who / where might?
    Many thanks,
    Hi Steve,
    If you have the PIC being recognized as an HID device, try this. It's real simple, but will allow you to control an LED from VB6 (should also work with VB5) but I don't have that to test it with.
    Create your VB code with EasyHID. Open the project, and drop two command buttons on your form. Add this code for your buttons --
    Private Sub Command1_Click()
    BufferOut(8) = 0 ' LED on
    hidWriteEx VendorID, ProductID, BufferOut(0)
    End Sub
    Private Sub Command2_Click()
    BufferOut(8) = 1 ' LED off
    End Sub
    Modify the PBP code created by EasyHID something like this --
    PORTB = 0
    TRISB = 0
    usbinit ' initialise USB...
    ProgramStart:
    gosub DoUSBIn
    PORTB = USBBuffer[7]
    goto ProgramStart
    Note this doesn't send data, it's just a sit & spin simple app reading USB input, and placing the value received in USBBuffer(7) on RB.
    -Bruce
    tech at rentron.com
    Jul 2008
    Now, I live in Tokyo, Japan
    Question Full speed USBOUT
    Hi everybody,
    I am new in this forum. I use PBP compiler and VB6 for my application.
    The problem are:
    . When I used USBOUT to send the data via EndPoint #1 from PIC to PC, I can send only
    the spead upto 64kbit/s (I use oscilloscope to measure the time of sending
    one packet from PIC to PC, an the time is about 8ms for 64 Bytes).
    . If I use EndPoint #3 (virtual COM port), I can send data upto 115200 bit/s but it still
    so slow for my application because I need to send data about 10 Byte at 100 ksample/s
    My question is:
    How can I used PBP to send the data in hight speed mode or full speed
    mode? Normally, I used EasyHID from MicrocodeStudio to generate the
    template for PBP and VB.
    Hope to hear from you all soon.
    Quote Originally Posted by lengcallrobot View Post
    My question is:
    How can I used PBP to send the data in hight speed mode or full speed mode?
    PIC18xxxx USB capable PICs are not capable of the high speed (480mpbs) mode.
    Jul 2008
    So, how about full speed mode? What to do?
    Feb 2005
    Essex, UK
    Hi Lengcallrobot and welcome to the forums!
    This is taken from the EasyHID help file contained in the EasyHID folder:
    "What is a HID Device?
    ...... One of the major advantages of HID is that you do not need to supply a custom driver, as one is already supplied with the operating system. A limitation of HID is that its data transfer rate is limited to a maximum of 64KB per second. However, this is still significantly faster than RS-232 (115200 baud is approximately 12KB per second)......"
    You should be able to send 64kBytes/sec in Full-speed mode as shown above.
    It looks to me as though you are sending data in Low-speed mode 64kbits/sec (or 8kBytes/sec) from what you have shown.
    Are you using a 48MHz clock source for the USB and have you set bit 2 of the UCFG register to enable Full-speed?
    I could be leading you up the garden path about the speeds but this is my understanding
    Hope this helps
    Rob
    Last edited by Rob; - 15th July 2008 at 09:09. Reason: Really should proof read before posting!
    Jul 2008
    Quote Originally Posted by Rob View Post
    Thank Rob, however, I cannot set UCFG.2=1 or FSEN=1 in my program. When I do this, I get error message . the below is my source code in pbp
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    USBBufferSizeMax con 64 ' maximum buffer size
    USBBufferSizeTX con 64
    USBBufferSizeRX con 64
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    'Variables -----------------
    I var byte
    Ana var word
    ' Define ports
    SP1 VAR PORTC.0
    ' * main program loop - remember, you must keep the USB *
    ' * connection alive with a call to USBService every couple *
    ' * of milliseconds or so... *
    TRISD = %11110000 'Set PORTD 0-3 to output, 4-7 to input
    'UCFG.2 = 1
    ProgramStart: 'Just want to test the USB speed
    high sp1
    gosub DoUSBIn
    low sp1
    gosub DoUSBOut
    goto ProgramStart
    ' * receive data from the USB bus *
    DoUSBIn:
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive (executed at least every 10ms)
    USBIn 1, USBBuffer, USBBufferCount, DoNext ' read data, if available
    PORTD = usbbuffer[2]
    Ana = (usbbuffer[0] << 7) | usbbuffer[1]
    freqout sp1,500,ana
    DoNext:
    ' * wait for USB interface to attach *
    DoUSBOut:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    Do you know other way to get Full-Speed mode with pbp ?
    Thank you in advance.
    Dec 2008
    I want to use EasyHID, so purchased Microcode Studio about one week ago. Since then, Mecanique has not responded to two emails, I cannot find where to download EasyHID, and am at a loss. Have since sent a complaint to WorldPay and have requested a refund... just in case.
    Where can one get hold of a copy of EasyHID? Or, are there other solutions out there, so I don't have to beg for the software from some vendor?
    Is Mecanique going out of business? Why doesn't anybody respond?
    Quote Originally Posted by kirtcathey View Post
    Holiday season many businesses are closed. Try again Monday.
    EASY ....
    Down boy, down ... That's better.
    David is a busy man.
    With MicroCode Studio, the PROTON IDE, Swordfish Basic, and others, the poor guys got his hands full.
    Please don't report him to Internet squeelers.
    Be nice, ask real questions ... he'll get back to you.
    Dec 2008
    Thanks again Darrel. Okay, I can understand that situation very well, since I tend to be a one-man band. However, it seems like with that much going on, he'd hire a spare geek or two to handle the front end.
    Getting back to the subject....
    I am building a proof-of-concept prototype (aren't we all!!) that will sit between the keyboard and host. When the end-user types in a certain character string or key combination, the microcontroller will send a control signal to another receiving device to start and stop a motor. Should I make this a keyboard HID, a generic device HID, or none at all and somehow pull information off the wire?
    Kirt
    What micro-controller will you use? Last I heard (maybe over a year ago), the PIC could not act as host to a USB device. Has a new model been released?
    Dec 2008
    Robert,
    Thank you.
    I'm using an 18F2550, since it's only 28 pins. Yes, I understand that it cannot be a USB host, which is why I am at a loss. What I am doing right now with somewhat positive results is programming for a keyboard device, then plugging the straight-wiring the keyboard to the host, then pulling power and data taps to the PIC. All is recognizing fine, except am working on finding the right host driver for this funky keyboard.
    Going to catch a train to Akihabara in a few minutes to pickup a generic USB keyboard and some other stuff.
    I should mention that EasyHID comes with MicroCode Studio.
    It's located in the "C:\Program Files\Mecanique\MCSP\EasyHID" folder. (assuming default installation).
    In that folder, there is a file EasyHID.chm.
    Should answer most of your questions.
    Dec 2008
    Right. And after reading a bunch of posts on these forums (many by you) about it... I want it even more! Or, do I? I am thinking that things may work out with just a generic keyboard HID for the time being, but not sure.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB communication with pic
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 23:43
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
