Pic 18f Usb
Page 1 of 4 1234 LastLast
Results 1 to 40 of 135
Thread: Pic 18f Usb
    Feb 2004
    Germany
    Default Pic 18f Usb
    Has anybody worked with these PICs:
    18F2455, 18F4455, 18F2550, 18F4550
    and EaysHID yet?
    Do you have any experience (or code) to share?
    I have received my ICD2 today and started playing with a 18F4550.
    (PICSTART+ doesn't suport the 18F4550!)
    regards
    Ralph
    I've used it, and if you're looking to get started with USB, then Dave's new
    EasyHID & the PIC18F4550 are definitely the way to go.
    Download & install EasyHID.
    http://www.mecanique.co.uk/products/usb/easyhid.html
    I have several projects for USB coming shortly, but in the mean time, I've
    loaded the files for a complete USB project on our website.
    The zip file contains PBP source code for a PIC18F4550, and VB source for a
    USB analog data-logger. Should be fun for anyone interested in tinkering with
    EasyHID and the new full-speed 18F USB parts.
    Here are the files: http://www.rentron.com/mcstudio/EasyHIDPrj.zip
    You'll need VB6 & SoftWire. You can download SoftWire from here. It's free.
    http://www.softwire.com/swdownload/softwiredownload.htm
    I used the activx controls in SoftWire for the analog meter interface. Really
    nice stuff.
    You'll also need PBP version 2.46 since this is the version offering support for
    the newer 18F USB parts.
    If anyone's looking for an excellent book on USB, then grab a copy of Jan
    Axelson's new 3rd edition of USB Complete. We just got them in. I spent the
    last few days reading mine, and it's awesome.
    Jan has done an outstanding job on her 3rd edition of this book. Even "I" can
    understand it now...;o]
    -Bruce
    tech at rentron.com
    I'm also in the middle of trying to use EasyHID. I'm just not sure where the USB18.ASM file fits in the grand scheme of things.
    I used the PIC18F4550, PBP and VB. The file is in the project PBP folder.
    I also got USB Complete as well as USB Design By Example. It's too bad they chose to use EZ-USB chips from Cypress or else I could have used their examples directly. Unfortunately I don't know enough about MPASM Assembler, let alone Cypress' version to convert things around.
    Is it complicated to get the generated code to be compatible with the slower USB speed? I'd like to be able to connect to PCs that do not yet have USB 2.0.
    Bruce,
    I get a LOT more files generated on the PIC side?
    It's that large Assembler file with all the VERY important USB routines that I don't know where that fits in. It doesn't seem to be linked with the PBP base program at all, or I missed something?
    Bruce,
    Don't forget to add a README that mentions mcHID.dll and where the user can get it. Your PC-side code won't work without it.
    Hi Robert,
    You should have 8 (PBP) files total generated by EasyHID. All this stuff is required, and included when you compile for the 18F USB part.
    Look in your PBP\USB18 directory for USB.TXT. This explains what most of
    the files are.
    -Bruce
    tech at rentron.com
    Thanks Bruce, that's the only place I hadn't looked for help.
    "The header file for the device, the files USB18.ASM, USB18MEM.ASM, USB18.INC, USBDESC.ASM and the project descriptor file, as well as any desired sample programs, should be copied to the project source subdirectory before being used."
    Ok, so we just have those files sitting there when we compile and the compiler takes care of everything, cool!
    "For low-speed USB operation, the main changes are to set the system clock postscaler to divide by 4 and change the define for UCFG_VAL in the descriptor file for the project. The sample project descriptor files show settings of UCFG_VAL for both full-speed and low-speed. With these settings, for full-speed, the PIC core runs at 48MHz. For low-speed, the PIC core runs at 24MHz."
    Ok, I haven't checked the details, but at least it's possible to adjust for low-speed USB, excellent!
    mbramwel's Avatar
    mbramwel Guest
    Exclamation
    This is a very interesting thread. I am especially interested in the data logger. I was thinking about putting together a PIC based scope project. Something that could clip onto a few pins and display the waveforms on a PC screen. Your project looks very interesting. Any special hardware being used? How to you hookup the inputs without fear of over voltage?
    Do you get 0 to 5 volts readings or more like .7v to 4.xx readings?
    mbramwel's Avatar
    mbramwel Guest
    Question no vb6 support in softwire
    hmm, softwire seems to be vb.net only.
    I do not see vb6 support. Any chance you are using an older version of softwire?
    I downloaded VB Express, it's free without any strings attached.
    "How to you hookup the inputs without fear of over voltage?"
    How to process the signals MCU-side, beats me. I'd do a search on comparing voltage, I've seen lots of stuff on that.
    Just don't even consider feeding that through the USB line. Even a PIC has limitations, I would place some sort of step-down circuit before the PIC. Google is your friend.
    Quote Originally Posted by mbramwel
    Suppose to be available.. look here
    Well as you want to build a kind of scope, it could be interesting that your input also provide an high impedance. So use a simple OP AMP buffer would do the trick IMHO.
    But if don't need any buffer, a simple resistor between PIC and Unit wil do the job. Look at the datasheet, most PIC have two diode as 'Over/Under voltage protection...
    mbramwel's Avatar
    mbramwel Guest
    Smile
    Thanks for the 'old' link for 3.1
    The regular download button was only showing the newer VB.net version. I do have VB.net because of our University site license (less than $5 per copy) but have a hard time loading up gigabytes of compiler for what should be simple apps. Maybe I should byte the bullet and move up from vb6.
    At least I can now try running the app posted earlier in this thread.
    I'll read the datasheet for the pic chip. My concern was due to many sites saying never exceed the supply voltage on an input pin.
    The scope project would be for hobby based projects. The PIC would monitor a few pins and transmit the data via USB to the PC. The PC would graph the result. If anything already exists that has source and is free, I would check it out. I do not mind starting from scratch. I do not copywrit anything I write, it would be for public consumption.
    Question
    I've just started on this, having been encouraged by EasyHID.
    I noticed that the interrupt check box is disabled if PBP is the device code genrator selected. Does this mean that PBP programs have to jump to service the USB every 10ms? That's surely not very practical.
    Do ME Labs have a fix in the pipeline for this or do I feel an upgrade to my neglected Proton+ coming on?
    I can't see me investing the time in making USB work with PBP if the USB connection cannot be maintained in the background.
    Any advice greatly welcomed.
    Brian Walsh
    Glasgow
    Scotland
    I haven't started on the USB aspect yet, but offhand I would say that's the function of the "USBservice" command.
    An easy way to manage this? I have absolutely no idea yet.
    Please somebody shoot me if i'm wrong, didn't find time to play enough with USB, BUT none of both compiler will do the refresh for you.. sorry. Timer interrupt one of the way to go or keep track of your code and sprinkle few USBSERVICE. No big deal
    paramotor's Avatar
    paramotor Guest
    Quote Originally Posted by NavMicroSystems
    and EaysHID yet?
    You have try this circuit from this project
    http://www.sixca.com/eng/articles/usbdaq.php
    Feb 2005
    Essex, UK
    Default Device Not Recognised
    I've built the simple piece of hardware using the 18F2550, it has been programmed as per the files generated by the EasyHID application.
    Having plugged the hardware into the USB port, it states the device is not recognised. I was expecting it to come up with the device name as i stated in the EasyHID compilation.
    I was expecting a .ini file or similar to be generated for the installation of the device.
    Can anyone help why this might be.
    Many thanks.
    Feb 2005
    Essex, UK
    OK, seem to have that issue sorted now, it actually was something to do with the programming fuses.
    Although it now connects OK, when i look at the device manager, it only shows up as a 'USB Human Interface Device' and HID-Compliant Device' and not as i set in the EasyHID maker.
    Also, can anyone help with what is required at the VB and PIC end to light a simple LED. ie when i click a 'button' in the VB code, it turns an LED on one of the ports, ie PORTB.1.
    Many thanks,
    Feb 2005
    Essex, UK
    Can anybody help with the above request or point me in a direction of who / where might?
    Many thanks,
    Hi Steve,
    If you have the PIC being recognized as an HID device, try this. It's real simple, but will allow you to control an LED from VB6 (should also work with VB5) but I don't have that to test it with.
    Create your VB code with EasyHID. Open the project, and drop two command buttons on your form. Add this code for your buttons --
    Private Sub Command1_Click()
    BufferOut(8) = 0 ' LED on
    hidWriteEx VendorID, ProductID, BufferOut(0)
    End Sub
    Private Sub Command2_Click()
    BufferOut(8) = 1 ' LED off
    End Sub
    Modify the PBP code created by EasyHID something like this --
    PORTB = 0
    TRISB = 0
    usbinit ' initialise USB...
    ProgramStart:
    gosub DoUSBIn
    PORTB = USBBuffer[7]
    goto ProgramStart
    Note this doesn't send data, it's just a sit & spin simple app reading USB input, and placing the value received in USBBuffer(7) on RB.
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Bruce, thanks ever so much for taking the time to reply and for starting me in the right direction. Indeed i now have VB talking to the PIC over USB.
    Do you have any knowledge of the EasyHID application? Having used EasyHID to set the base code etc, when i look at the device manager, it only shows up as a 'USB Human Interface Device' and 'HID-Compliant Device' and not as i set in the EasyHID maker, such as 'USB LED Controller'.
    I was expecting an .inf file or similar to be compiled. Is this something that needs to be done manually? It would be a nice touch to have that when i plug in the device, in the task bar, the name of this device is displayed like any other USB device when connected.
    Thanks again for you kind help,
    Steve Tisseyre
    Hi Steve,
    The information you enter when creating USB framework files with EasyHID is just for the embedded side with a very handy .dll that handles host to function communications.
    EasyHID just gives you the USB framework. As far as I know, it does not create a Windows .inf file. That's up to you to create.
    If you don't have your own .inf file or HID driver, then Windows will install its own HID drivers, and your new USB gadget is just going to show up with the default Windows name in Device Manager like 'USB Human Interface Device' and 'HID-Compliant Device'.
    If you're running XP, look in the Windows input.inf file, and you'll see why. It tries to match the descriptors, VID, PID with existing "certified" manufacturers & hardware. If your new USB gadget isn't in the list, Windows uses the default HID compliant description with generic HID drivers.
    Download the Microchip USB framework and take a look at how they setup the .inf & driver files. That will help you understand what's required.
    If you plan on making a USB enabled "product", then you might also want to grab a copy of Jan Axelson's USB Complete 3rd edition. It's worth every penny, and gives you details on how to get your USB product/manufacturer name to show up in Windows Device Manager.
    EasyHID will get you started, (and really quick I might add), but there's still a lot left to the end user to figure out.
    Hats off to Dave at Mecanique for putting in the HUGE amount of time & study required just to give everyone that nifty "free" utility.
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Hi Bruce,
    I have now ordered the book as you recommended, i'm sure it will come in very handy.
    I have figured out that if you use EasyHID to set the maximum Buffer size to 32, then you can increase the amount of outputs on the PIC that you can set HIGH or LOW. ie the PIC side is odd numbers 1 - 31 and the VB side is even numbers 2 - 32.
    ie on the PIC side requires:
    PORTC.1 = USBBuffer[23]
    where as on the VB side requires:
    BufferOut(24) = 1 ' LED on
    If i want to use all of PORTA and PORTB, is there an easy way of listing these in the two codes, or do they have to be done seperately? ie:
    PIC
    PORTA.1 = USBBuffer[1]
    PORTA.2 = USBBuffer[3]
    PORTA.3 = USBBuffer[5]
    PORTA.4 = USBBuffer[7]
    PORTA.5 = USBBuffer[9]
    VB
    BufferOut(2) = 1 ' LED on
    BufferOut(4) = 1 ' LED on
    BufferOut(6) = 1 ' LED on
    BufferOut(8) = 1 ' LED on
    BufferOut(10) = 1 ' LED on
    Moving on from the switching of outputs HIGH or LOW, how would one send say text from the PIC to a text box in VB. For example, on the PIC, if a certain routine is executed, it sends a command to the VB application which is then displayed in a text window. Or is this getting too advanced for a quick explanation??
    Thanks again for you assistance,
    andresnavas's Avatar
    andresnavas Guest
    Unhappy EasyHID Files
    Hello. I don't know what happend but my EasyHID only create 4 files:
    DESCUSBProject.asm
    USBDESC.asm
    USBProject.asm
    USBProject.pbp
    What i doing wrong? why it don't creat the other files like the USB18.c
    Thanks for yours help!!!
    Please if somebody have any example send it to me at: [email protected]
    Thanks!
    Feb 2005
    Essex, UK
    andresnavas,
    I have sent the reply straight to your personal email address. It would appear that the files aren't generating properly. All i can suggest is check the compilation settings again. If that doesn't work, try installing the application again.
    I certainly haven't had any problems like that.
    Within the directory you specified in the project settings (default is C:\Program Files\Mecanique\EasyHID\) should see another directory as per your title, such as USBProject. Within that directory is 2 sub directories, one for the VB or C code and one for the Proton or PICBasic code.
    I have sent you a zip file containing what you should expect to see for a default VB and PICBasic code using the PIC18F4550 also with all the default settings.
    Hope this helps,
    judy's Avatar
    judy Guest
    Smile Newbie
    Hi all,
    Absolutely brilliant thread, a lot of quality info and best of all can be done fast, cheers to all those involved. I am really new to this interfacing stuff, so if I'm asking too much or the newbie stink is unbearable, feel free to tell me to sling my hook.
    I was wondering how one would go about changing the HID code provided by Easy HID USB code generator to simply read in up to three pulse width inputs (as far as I know the digital ins on the 18f2455 support this) and up to three analog ins through on board adc (ideally varying between -3 to +3v) simultaneously and as fast as possible, in fact how many samples per second is possible using the HID approach? Sin e.
    I would greatly appreciate any help with this/direction to where help should be sought.
    Thanks in advanced
    Judy
    Steve,
    You're dealing with bytes. PORTA.1 = USBBuffer[1] isn't the way to go since you can't place a byte value on a single port "bit".
    Just place the byte you need on the whole port. You can send a single byte value from the PC app, and simply place it on the port.
    I.E. PORTA = USBBuffer[1] should work fine - assuming that's the byte element you want.
    Sending data from the PIC to PC is equally simple. Here's one example. Note this isn't everything. Just the sections I added to the framework file created with EasyHID.
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    DEFINE	ADC_BITS 10     ' Set number of bits in result
    DEFINE	ADC_CLOCK 3     ' Set clock source /32
    DEFINE	ADC_SAMPLEUS 50 ' Set sampling time in uS
    DEFINE RESET_ORG 800h ' <-- I used the Microchip USB loader
    BufferSize      con 8
    DataBuffer      Var Byte(BufferSize) ' data buffer
    DataBufferCount Var Byte             ' buffer size
    Quanta  con 1251
    TRISD = 0
    PORTD = 0
    ' Variables
    X       VAR byte
    Adval   VAR WORD
        TRISA.0 = 1        ' RA0 input
        ADCON1 = %00001110 ' A/D channel 0
        ADCON2 = %10000011 ' Right justify for 10-bit
        USBInit
        GOSUB DoUSBIn
        PORTD = DataBuffer[7]
        ADCIN 0,adval		     ' Read A/D channel 0 into ADval variable
        ADval = ADval */ Quanta  ' Quanta result
        ' Load data buffer
        DataBuffer(0) = Adval DIG 3
        DataBuffer(1) = "."
        DataBuffer(2) = Adval DIG 2
        DataBuffer(3) = Adval DIG 1
        DataBuffer(4) = Adval DIG 0
        GOSUB DoUSBOut
        FOR X = 0 to 99 ' Short delay between updates
         PAUSEUS 1000
         USBSERVICE     ' Maintain HID connection during delay period
        NEXT X
        GOTO Main
    On the PC side, modify the USB framework file created with EasyHID something like this;
    Dim MyText As String ' create your string storage space
    In the OnRead sub-routine;
    MyText = (CStr(BufferIn(1)) + Chr$(BufferIn(2)) + CStr(BufferIn(3)) + CStr(BufferIn(4)) + CStr(BufferIn(5)) + "V")
    Label1.Caption = MyText ' Place string text into label displaying A/D value
    Judy,
    Reading three pulse widths or A/D values doesn't really have anything to do with USB. The USB PIC is just another PIC with the addition of the USB module. Using the onboard A/D is pretty much the same as any other PIC.
    All you need here is the datasheet, and a little time to experiment getting your pulse measurement & A/D routines working. Sending this all to the PC via the USB module is no more than stuffing your values into the outgoing buffer like in the previous example.
    Just be sure to keep the USB connection alive by avoiding the use of blocking functions, long delays, etc,,. It's really not that hard, but you will need to experiment a tad.
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Bruce,
    Would you mind posting all of your ADC code, i am getting errors. I've had a look, but can't figure it out.
    The code posted above seems to be missing the DoUSBIn and DoUSBOut subroutines.
    I also get an error on the DataBuffer(1) = "."
    I want to use it as a 5v voltage monitor passing the results to Vb.
    Many thanks,
    Hi Steve,
    Sure. Here's the complete file. Just be sure you've used EasyHID to generate the required USB support files.
    DEFINE OSC 48
    DEFINE RESET_ORG 800h    ' For Microchip USB loader
    BufferSize      con 8
    Quanta  con 1251
    TRISD = 0
    PORTD = 0
    ' Variables
    X       VAR byte
    Adval   VAR WORD
        USBInit
        GOSUB DoUSBIn
        ADCIN 0,Adval		 ' Read A/D channel 0 into ADval variable
        ' Load data buffer
        DataBuffer(0) = Adval dig 3
        DataBuffer(1) = "."
        GOSUB DoUSBOut
         PAUSEUS 1000
        NEXT X
        GOTO Main
       ' USB in...
    DoUSBIn:
        DataBufferCount = BufferSize
        USBService
        USBIn 1, DataBuffer, DataBufferCount, DoUSBIn
       ' USB out...
    DoUSBOut:
        USBService
        USBOut 1, DataBuffer, DataBufferCount, DoUSBOut
    Here's the PIC & VB source for a USB A/D datalogger http://www.rentron.com/mcstudio/USB_AD.zip
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Great, thanks Bruce. Unfortuanatly i am still getting a big 0 in VB. I'm sure its only something small i am doing wrong (hopefully) !!
    Here is the code, can you spot anything obvious that i have done wrong?
    Its a PIC18F2455 where i am putting 5v onto RA0.
    DEFINE OSC 48
    'DEFINE RESET_ORG 800h    ' For Microchip USB loader
    BufferSize      con 8
    Quanta  con 1251
    ' Variables
    X       VAR byte
    Adval   VAR WORD
        USBInit
        GOSUB DoUSBIn
        PORTB = DataBuffer[7]
        ' Load data buffer
        DataBuffer(1) = "."
        GOSUB DoUSBOut
           PAUSEUS 1000
        NEXT X
     GOTO Main
    ' * receive data from the USB bus                            *
    DoUSBIn:
        USBService
    ' * wait for USB interface to attach                         *
    DoUSBOut:
        USBService
    In VB, i have placed a label on the form and this is in the read event section
    ' on read event...
    Public Sub OnRead(ByVal pHandle As Long)
       ' read the data (don't forget, pass the whole array)...
       If hidRead(pHandle, BufferIn(0)) Then
          ' ** YOUR CODE HERE **
          ' first byte is the report ID, e.g. BufferIn(0)
          ' the other bytes are the data from the microcontrolller...
       End If
    End Sub
    Many thanks again.
    Private Const VendorID = 6017
    Private Const ProductID = 2000
    Check to make sure the vendor & product ID numbers in your VB source match the vendor/product ID #'s in the PIC framework files generated by EasyHID. If these don't match, the VB app will never respond.
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Although i have changed the ProductID from 2000 to 2005, the device is recognised.
    The VB program displays a text box which says USB Device Connected or indeed Disconnected, depending on its status.
    So, i think this bit is OK.
    What exactly is happening? Are you getting nothing on the label caption? Have you verified your hardware with something simple like reading the A/D input, and displaying the result on an LCD, serial terminal, etc?
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Basically i'm putting 5v on the PORTA.0 pin and just gettin 'label1' in the label of VB.
    Should VB always be updating and looking at the USBinput or should there be a READ button thats calls the procedure?
    Also on the VB side it has:
    Most of it contains CStr but the bit thats contains Chr$, i presume thats for the "." as sent from the PIC.
    I've tried playing around with it, but still no joy. If you have it, is it worth sending me the vb source file you have just for this bit?
    Are you on messenger, i am, i thought it might be easier to converse?
    Thanks again,
    I'll be happy to send you the working source for one example. Email me directly at tech@rentron
    -Bruce
    tech at rentron.com
    Quote Originally Posted by Bruce
    Hi Bruce, do you have a link? I did a search on the Microchip site for <Microchip USB framework> and couldn't find a download.
    (I'm assuming this is some sort of compile utility that will help Windows XP make a link between the USB device and our EasyHID-generated VB code.)
    Hi Robert,
    The Microchip USB framework files are C18 code for the USB PIC. Look under Development Tools for PIC Demo Boards. Go to the page for the full speed USB board. All files & app notes can be downloaded from that page.
    When you run the setup program for the PIC USB demo board it installs the framework files. You'll want to grab all the associated app notes on the same page, and USB loader if you plan on using that.
    With PBP v2.46 you use DEFINE RESET_ORG 800h to force user code to start at the proper location when using the Microchip USB loader.
    -Bruce
    tech at rentron.com
    Feb 2005
    Essex, UK
    Is the USB loader so you can bootload the PIC over USB with a new firmware?
    Yes. It's the same USB boot-loader provided with the Microchip full speed PIC USB demo board.
    -Bruce
    tech at rentron.com
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 12:00
  3. Replies: 15
    Last Post: - 30th October 2007, 19:25
  4. USB communication with pic
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 23:43
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
