PIC10F32x Configuration Settings
Results 1 to 3 of 3
    Jul 2013
    Default PIC10F32x Configuration Settings
    Hello,
    Just setting up the new PIC10F32x Development Board which is both a really extreme chip and a really nice experimenter platform.
    Only $12!
Size:  128.9 KBPIC10F32x_DEV-AC103011_eng_tds.pdf
    However, it appears to need different configuration settings from the less sophisticated 10F2xx series. (Uses RA0/RA1/RA2/RA3 parlance instead of GPIO.0/GPIO.1/GPIO.2/GPIO.4. Likewise not sure of how to set the usual...
    GPIO = %00000000 ' GPIO All OFF
    TRISIO = %00001001 ' Inputs = 1, Outputs = 0
    OSCCAL.0 = 0 ' Disable INTOSC/4 Out on GP2 (Enable I/O on GP2)
    OPTION_REG.5 = 0 ' Disable TRIS override on T0CKI (Enable I/O on GP2)
    OPTION_REG.6 = 1 ' Disable Weak Pull-Ups (GP0, GP1, GP3)
    OPTION_REG.7 = 0 ' Enable Wake-Up on Pin Change (GPO, GP1, GP3)
    I have surfed the net for a PICBASIC PRO example to clarify but have found none.
    There used to be INC files that showed syntax examples but have not located anything for this new part.
    The data sheet does detail the myriad of new options but I'm just stuck on the basics.
    (My immediate objective is just make the LEDs and the pushbutton do something.)
    PIC10F320_322_Brief.pdf
    The data sheet was too big to attach so here is the link:
    http://ww1.microchip.com/downloads/e...Doc/41585A.pdf
    Jul 2013
    Default Re: PIC10F32x Configuration Settings
    Just did a search on the melabls forum:
    http://support.melabs.com/threads/35...ghlight=10f322
    RATS!
    Jul 2013
    Charles Leo just confirmed the bad news:-(
    (I think I have been down this road before.)
  1. Replies: 6
    Last Post: - 29th December 2011, 22:39
  2. Confused over A/D settings
    Last Post: - 22nd February 2010, 11:44
  3. Changing the Configuration Settings
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 24th October 2007, 08:33
  4. PIC 16F684 Configuration Settings
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 16:18
  5. Replies: 7
    Last Post: - 14th July 2006, 04:21
