Low Power Regulators
Results 1 to 22 of 22
    May 2012
    Merseyside, UK
    Default Re: Low Power Regulators
    Quote Originally Posted by Charlie View Post
    Both the RTC and LCD are 5V devices - RTC min is 4.5V, LCD min is 4.7 V.
    So you really can't run your circuit at 3.3 V.
    You will either need to use Ioannis' suggestion (which I also recommend), or go back to your 2936 regulator with at least a 6V battery. The 9V batteries have pretty low capacity - you might be better off with a couple 3V button cells; I have not worked out the details on those.
    Hi yes the present circuit is built around a 5v supply....BUT :-
    Looking to upgrade using LF818/19, LCD 3.3v and different RTC ...1307 has lousy timekeeping :-(
    Application remains same... just maybe different parts!
    BR
    Andy
    Dec 2010
    Quote Originally Posted by andybarrett1 View Post
    BR
    Andy
    You'll need to choose those parts to know your supply tolerance. The answers are all in the data sheets.
  1. LCD Low Power
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 01:05
  2. Low power applicationn
    By Andre_Pretorius in forum General
    Last Post: - 17th September 2010, 19:13
  3. Low Power Sleep
    Last Post: - 4th December 2009, 15:33
  4. low power consumption
    By taos in forum General
    Last Post: - 26th February 2006, 09:33
  5. Replies: 0
    Last Post: - 25th May 2005, 11:35
