Argh,
if you want to use interrupts to receive serial input - use hardware !!!!!
Access direct the registers and place an inverter into the serial signal !
Using SERIN will lead you to big trouble !
Argh,
Thank you for the adviced I will use HSERIN instead of SERIN.
P.S. : If someone make to work the Hardware serial Port on the PIC16F688 with the Hserout command please let me know how you did it...
