OPTION_REG.7=0…… Or does it ?
Results 1 to 4 of 4
    May 2012
    Merseyside, UK
    Question OPTION_REG.7=0…… Or does it ?
    Hi all
    Am using a 16f818 in a simple program …all is working BUT :-
    OPTION_REG.7=0 ' Enables all pull-ups on PORTB
    Question is What happens if only PORTB 0-3 are inputs and 4-7 are outputs….I thought I had seen a way of enabling . disabling some pins if this was the case…..
    OR Does telling PBP that pin 4-7 are outputs do it for me ???
    My program is working fine….. Just wondering !
    Thank you for reading
    Andy
    Default Re: OPTION_REG.7=0…… Or does it ?
    0 = PORTB pull-ups are enabled by individual port latch values - inputs only get pullups
    BTW OPTION_REG.7=0 Decimal point got lost in post, I will fix in your post, check your code
    Selecting a gpio as output automatically disables the weak pull-up. Several peripherals do the same.
    George
    May 2012
    Merseyside, UK
    Quote Originally Posted by towlerg View Post
    George
    Is what I thought….
    Just needed to confirm…. Thank you
    Andy
  1. 12F683 trailing and rising edges in option_reg
    By AvionicsMaster1 in forum General
    Last Post: - 26th May 2011, 15:02
  2. Question about Option_Reg
    Last Post: - 15th November 2009, 22:06
  3. 18f2520 - Option_reg
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 18:06
  4. OPTION_REG = $7f syntax error
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 21:05
