RS-232 confusion
Results 1 to 12 of 12
    New Jersey
    Default RS-232 confusion
    This may be a case of a dog chasing his own tail but I'm trying to figure out if what I'm looking at is an RS-232 signal. I've tried various baud rates and it seems to be something around 9600 as that's the most consistent data I can see on the screen. Each piece of data is 500uS. If it's not RS-232, can anyone identify the communication protocol?Name:  IMG_2011 copy.jpg
    Default Re: RS-232 confusion
    definitely not rs232 and not a Manchester code , its a rtz(return to zero) stream of some sort . where does it come from and is there any identifiable start/stop sequence
    bi-phase ?
    Miami, Florida USA
    Also, RS-232 signals go from -12V to +12V. What you have there is some kind of 1-wire serial communication going on.
    Anonymous
    New Jersey
    It is one wire communication. The voltage level is 18VDC. What you see in that picture the output from a RS-232 IC. I can identify the start/stop and know what each piece of data is. The problem is, I have to do it with my oscilloscope and eyes as opposed to using a PIC to interpret it.
    Each bit is 500uS. The high/low within the 500uS bit is predetermined. In other words, it may be 200uS off and 300uS on or 400uS on and 100uS off but I know before the packets starts. The entire packet is 100mS long.
    What is the best way to get this information to a PIC where I can log it instead of staring at my oscilloscope?
    if you can't identify the device then a complete transaction from line idle to send/receive and back to idle with a data translation would help . guessing seems pointless
    If you know it's RS232, why not send into a PC?
    Assuming you don't have a Saleae logic probe or other device capable of reading signal.
    New Jersey
    Richard has confirmed it's not RS-232.
    I can identify everything.
    I don't really need to convert the data into a "readable" format, all I need to do is accurately measure the on/off period in each bit. For example, if I'm able to do something like this, my job is complete:
    Bit 1 // On - 100uS / Off - 400uS
    Bit 2 // On - 350uS / Off - 150uS
    Bit 3 // On - 100uS / Off - 400uS
    Bit 100..........
    I'm using an 18F87J50 and tried using an ECCP input but was never able to get it working. Then I figured if it was some type of standard communication I'd be able to push the easy button but that's not a reality now.
    I got confused by this I guess.
    If you only want to know ON/OFF duration of 18v signal, why not use the signal to control the base of a transistor that would send 5v to a PIC?
    Then I would use interrupts on that pin and use a timer.
    getting info here is a bit like pulling teeth , but lets assume a 48mhz clock and that timer4 is free along with a pin like portb .2
    some vars
    bit_is var byte
    I_data var PORTB.2    'lets call this the input
    a routine
    bit_test:
    bit_is =0
    t4con=0   ' timer off
    tmr4=0   ' clear timer
    pir3.3=0  'clear timer overflow flag
    while ( ! i_data) : wend 'wait here till input goes high  to sync up
     while ( i_data) : wend  ' wait here till input goes low
    t4con=6     ;  prescale 16 timer on
     while ( ! i_data) : wend  ' wait here till input goes high
     if  pir3.3 then bit_is=1  ;  offtime > 340 uS
      bit_is=0 '  the offtime < 340 uS
    it could be nicer if
    1 does the line idle high or low
    2 what does a start bit look like
    3 how many bits in a session
    4 100uS / Off - 400uS a 1 or a 0 ?
    New Jersey
    I'm a novice when it comes to the timers and interrupts. Seems like a good idea that's worth trying.
    Idles low.
    1ms on/1ms off
    100
    It's a 1 but it can vary. Before the packet is received, I will know what is a 0 and what is a 1.
    this should get close to it
    define OSC 48
    some vars
    bits var byte[13] ' an array to hold the 100 bits
    bit_count var byte
    'a subroutine
    bit_read:
    t4con=0   ' timer off
    bit_count = 0
    while ( i_data) : wend  ' wait here till input goes idle
    t4con=$7e  '256:1// count of 45 or so = 1mS
    t4con=0   ' timer off
    if (tmr4 >43 ) and (tmr4 < 47) then goto start_ok '  bit of latitude might need more
    goto bit_read
    start_ok:
    while bit_count < 100
    t4con=0   ' timer off
     if  pir3.3 then bits.0[bit_count]=1  ;  ontime > 340 uS
      bits.0[bit_count]=0 '  the ontime < 340 uS
     bit_count=bit_count+1
    wend
    As far as the IDLE high or IDLE low state, looking at the signal with a scope, where is the bus signal level when NO data is being sent? I would imagine it to be high, as most single wire communications use a passive sourced current to stimulate the bus wire (usually a resistor). That way there can be more than 1 device listening as well as more than 1 device able to answer a request. This is done by pulling the line LOW thru an open collector transistor or N channel fet.
    EN82fn
  1. Arbitration of 232 signals
    By blmcali in forum Serial
    Last Post: - 13th July 2012, 05:06
  2. PIC18F2450 Rs-232
    By PlantBob in forum mel PIC BASIC Pro
    Last Post: - 4th February 2011, 01:14
  3. PIC18F2450 Rs-232
    By PlantBob in forum General
    Last Post: - 17th January 2011, 19:58
  4. polling information in rs-232
    By Tondunard in forum mel PIC BASIC Pro
    Last Post: - 12th February 2008, 13:32
  5. ethernet to rs-232
    By maus in forum mel PIC BASIC Pro
    Last Post: - 18th April 2006, 18:44
