Pic10F202 Master clear will not turn off.
Results 1 to 23 of 23
    Apr 2013
    Default Pic10F202 Master clear will not turn off.
    No matter what I try master clear will not turn off. I have done everything but change the device file as it says if it is listed in your code it over rides it. Need GPIO.3 as an input. Dumbed the program as much as I could. output pins go from high to low as should. But if I ground GPIO.3 everything resets.
            __config _WDT_OFF & _MCLRE_OFF & _CP_OFF
            OPTION_REG=000000
            TRISIO = 001000
            A    VAR    GPIO.0
            B    VAR    GPIO.1
            C    VAR    GPIO.2
            IN    VAR    GPIO.3
    BEGIN:  high A
            high B
            high C
            low A
            low B
            low C
            gotO BEGIN
    Apr 2013
    Default Re: Pic10F202 Master clear will not turn off.
    for some reason it changed my code so here it is again
    OPTION_REG=%01000000
    TRISIO = %00001000
    A VAR GPIO.0
    B VAR GPIO.1
    C VAR GPIO.2
    IN VAR GPIO.3
    BEGIN: high A
    high B
    high C
    low A
    low B
    low C
    gotO BEGIN
      __config  _IntRC_OSC & _WDT_OFF & _CP_OFF & _MCLRE_OFF
    MY GUESS
    ^__config^_IntRC_OSC & _WDT_OFF & _CP_OFF & _MCLRE_OFF
    TRISIO = 001000
    should anything hurt you ???
    me does !!!
    try to use A = 1, B = 1 ... etc, etc
    instead of HIGH and LOW Commands ...
    PS: Oooops ...
    Apr 2013
    richard,
    are you saying add carrots? around __config ?
    Alain,
    I agree I normally use var = x also, and not High and low but just wrote something quick and that is faster. and GPIO.0-.2 do as they are told. So that part is working memory clear just won't enable as an input. So irritating.
    Thanks again,
    Joe
    Jan 2013
    Texas USA
    No I think that Richard was trying to tell you that there were too many spaces.
    It should look like this " __config _IntRC_OSC & _WDT_OFF & _CP_OFF & _MCLRE_OFF"
    Notice, (1) space before __config and (1) space between __config and _IntRC_OSC
    TABSoft
    Apr 2013
    I think the spaces were added when I copy and pasted it. as it screwed up other formating as well. But I will check and get back to you.
    it gets difficult to show when the forum eats up the white space on your posts .
    post #2 shows no spaces
    Apr 2013
    I appreciate the help guys. I had a tab then a space after. fixed to a space before and a space after but MCLR is still active. I even said the hell with it and changed it in the device folder and still no go. checked .asm file and looks like it is writing it right. Wish I could read the .hex I'm wondering if it is my programmer but I have programmed tons of other pics with no problems what so ever. Xeltek Superpro 580u
    Sep 2010
    Las Vegas, NV
    OK. According to page 35 of the 10F20x datasheet you can't change the config word that has the MCLRE bit in it. Will setting the fuse do that for you?
    I think I ran into this a while ago and was never able to use a 10F222 GPIO.3 as an input no matter what I did.
    Is there any chance GPIO.3 is shorted to VDD ? Just asking because you did not mention if this is a PDIP or SMT package, in chk or not . . .
    Apr 2013
    avioncis,
    I did see page 35 and does not give memory location for some reason where the register 9-1 is at. Which I find weird. But there has to be one because the bits are writable says datasheet. But yes at this point it's not looking good.
    Arch,
    Sorry this is a DIP 8 pin package. vdd seems to be holding it high internally. as there is 5 volt on GPIO.3 with nothing connected. But I'm sure that is the way it is suppose to be. So it doesn't reset itself if someone didn't know they need a pull up resistor. And per data sheet if voltage greater than Vdd will enter programming mode. If you are saying that vdd is being applied externally accidentally no.
    Ok sometimes finding out what it is is by eliminating everything else. So what does your volt meter tell you if you turn ON MCLRE ? Also do you have another chip?edit: (Almost)/edit Lastly are you SURE it is a Genuine PIC? I know it seems silly to entertain the idea of cloning a $0.38 chip but when you are selling 50 million of them . . .
    Data sheet says GPIO.3 is connected to VDD when MCLRE is off, I am trying to get my head around how it can serve as an input while connected to vdd unless it's via a WPU, . . . . How "ROBUST" is your power supply? Does grounding GPIO.3 cause the chip to BROWNOUT ? Also check your breadboard for corrosion causing weak connections, seen that many times.
    Apr 2013
    Gen pic bought from digikey. have three in rotation. all do the same. I have tried two bead boards. I just have Vdd and Vss hooked up. just metering the rest. using 1 kohm res to ground to reset mclre. chip does not brown out. power supply is 1 amp 5volt. clean on the scope. Pg 9 of data sheet says it can be enabled as GPIO.3 with pull ups or no pull ups. so it should not be tied to Vdd.
    ;----- CONFIG Options --------------------------------------------------
    _OSC_IntRC           EQU  H'0FFF'    ; This is the only option. It is here for backward compatibility
    _IntRC_OSC           EQU  H'0FFF'    ; This is the only option. It is here for backward compatibility
    _WDTE_OFF            EQU  H'0FFB'    ; WDT disabled
    _WDT_OFF             EQU  H'0FFB'    ; WDT disabled
    _WDTE_ON             EQU  H'0FFF'    ; WDT enabled
    _WDT_ON              EQU  H'0FFF'    ; WDT enabled
    _CP_ON               EQU  H'0FF7'    ; Code protection on
    _CP_OFF              EQU  H'0FFF'    ; Code protection off
    _MCLRE_OFF           EQU  H'0FEF'    ; GP3/MCLR pin fuction is digital I/O, MCLR internally tied to VDD
    _MCLRE_ON            EQU  H'0FFF'    ; GP3/MCLR pin function  is MCLR
    This is from this chips file in MPASM P10F202.inc
    Ok this is found on pp35 of the data sheet
    Apr 2013
    ya it says tied to vdd internally. It is still there it just isn't tristated to an external pin I believe.
    Anyways I think I have had some success last night. I found that Microcode was automatically changing my case on on #endconfig From #ENDCONFIG to #endconfig. and #CONFIG was staying #CONFIG. So I changed #CONFIG to #config. and doesn't seem to reset anymore on a low to GPIO.3. However I have pull ups off. and it still rests at vdd. and not getting ram over load error(which I find that you get if you add just one static variable). and will not respond as GPIO.3 as an input. (changed program to if "IN" = 1 alternate ports from high to low else stay low) and won't do it. And as soon as I introduce "IN" into the program program doesn't work. comment out. it will alternate. I guess I didn't do if IN=0. that would off been smart since seems internal pull ups are on even though OPTION_REG.6 is high which is suppose to disable them.
    Honestly I didn't know ANY of the 10F series would even program with PBP due to RAM limitations, as I remember Darrel usually told members who wanted to try to use a 12F series. Any special reason to use 10F series?
    Hi,Archangel
    Darrel told that because there is no room for vars in RAM once PBP has placed its own vars ...
    so, no serious work could be done using PBP ... just Blinking the Led, may be ...
  1. Replies: 2
    Last Post: - 24th February 2011, 02:35
  2. turn-off lcd and turn-on again
    By mehmetOzdemir in forum mel PIC BASIC Pro
    Last Post: - 5th September 2009, 13:57
  3. GP3 Funtion on PIC10f202
    By kessral in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 20:49
  4. Does CLEAR Command clear return adrress of a subroutine?
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 19th February 2008, 17:25
  5. PIC10F202 Variable trouble
    By George in forum mel PIC BASIC Pro
    Last Post: - 13th October 2006, 03:14
