Converting 32 bit Floating Point, and 48 and 64 bit Integer to string
Results 1 to 11 of 11
    Default Re: Converting 32 bit Floating Point, and 48 and 64 bit Integer to string
    Sep 2009
    Thanks!
    I just take short look at that, and that should be exactly what I need. I'll give it a try and report back. Thank again.
    Sep 2009
    While writing first post, I was thinking that DT isn't around any more...
    And here it is, his solution
    Sep 2009
    I found this article
    http://www.picbasic.co.uk/forum/cont...153-N-Bit_MATH
    That should be enough, to display 64 bit integer.
    Sep 2009
    I tested Darrels example with more numbers and something doesn't work...
    include "fp1832l.bas"
    ;----[Variables]----------------------------------------------------------------
    A         VAR LONG
    B         VAR LONG
    A_Float   VAR LONG EXT : @A_Float = AARGB2 ;
    B_Float   VAR LONG EXT : @B_Float = BARGB2 ;
    OutStr    VAR BYTE[20]
    ;----[macro Converts IEEE to Microchip FP format]-------------------------------
    IEEEtoMCHIP?NN  macro Nin, Nout
        MOVE?BB Nin, Nout
        MOVE?BB Nin+1, Nout+1
        MOVE?BB Nin+2, Nout+2
        MOVE?TT Nin+3,7, Nin+2,7
        MOVE?BA Nin+3
        RLNCF   WREG,W
        MOVE?AB Nout+3
        MOVE?TT Nin+2,7, Nout+3,0
    ;----[Test IEEE to Microchip conversion]---------------------------------------
    HSEROUT2 ["Value from IEEE calculator: 50" ,13,10]
    A = $42480000        ; 50 - IEEE
    GOSUB ShowConversion
    HSEROUT2 ["Value from IEEE calculator: -25.62" ,13,10]
    A = $C1CCF5C3        ; -25.62 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 23.75" ,13,10]
    A = $41BE0000        ; 23.75 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 35.00" ,13,10]
    A = $420C0000        ; 35.00 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 24.00" ,13,10]
    A = $41C00000        ; 24.00 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 22.00" ,13,10]
    A = $41B00000        ; 22.00 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 8.875" ,13,10]
    A = $410E0000        ; 8.875 - IEEE
    STOP
    ;----[Show conversion via HSEROUT]---------------------------------------------
    ShowConversion:
        HSEROUT2 ["IEEE = ",HEX8 A,13,10]
        @ IEEEtoMCHIP?NN _A, _B
        HSEROUT2 ["Mchip= ",HEX8 B,13,10]
        A_Float = B
        GOSUB FtoIA
        HSEROUT2 ["Aint = ",SDEC Aint,13,10]
        A = Aint
        A_Float = B       ; with 1 decimal place
        Bint = 10
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT2 ["       ",SDEC Aint/10,".",DEC1 ABS(Aint),13,10]
        A_Float = B       ; with 2 decimal places
        Bint = 100
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT2 ["       ",SDEC Aint/100,".",DEC2 ABS(Aint),13,10]
        A_Float = B       ; with 3 decimal places
        Bint = 1000
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT2 ["       ",SDEC Aint/1000,".",DEC3 ABS(Aint),13,10,13,10]
    Results:
    IEEE = 42480000
    Mchip= 84480000
    Aint = 50
           50.0
           50.00
           50.000
    IEEE = C1CCF5C3
    Mchip= 83CCF5C3
    Aint = -25
           -25.6
           -25.62
           -25.620
    IEEE = 41BE0000
    Mchip= 82BE0000
    Aint = -11
           -11.8
           -11.87
           -11.875
    IEEE = 420C0000
    Mchip= 840C0000
    Aint = 35
           35.0
           35.00
           35.000
    IEEE = 41C00000
    Mchip= 82C00000
    Aint = -12
           -12.0
           -12.00
           -12.000
    IEEE = 41B00000
    Mchip= 82B00000
    Aint = -11
           -11.0
           -11.00
           -11.000
    IEEE = 410E0000
    Mchip= 820E0000
    Aint = 8
           8.8
           8.87
           8.875
    Sep 2009
    As far as I can see, there is some problem with Darrel subroutine.
    To get correct number in microchip format I used this code:
        aint = 2375
        Gosub itofa     ' Convert int to float
        bint = 100
        Gosub itofb     ' Convert int to float
        Gosub fpdiv
    Result is: $833E0000
    And I can display correctly with this code:
        A_Float = $833E0000  ; with 1 decimal place
        Bint = 10
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        Bint = 100
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        Bint = 1000
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
    Output is:
    23.7
    23.74
    23.749
    That is fine...
    But when I try to convert $41BE0000 with Darrel's routine result is
    IEEE = 41BE0000
    Mchip= 82BE0000
    Sep 2009
    I think that I solved this...
    From include file FP32.A18:
    ;       32 bit floating point representation
    ;       EXPONENT        8 bit biased exponent
    ;                       It is important to note that the use of biased exponents produces
    ;                       a unique representation of a floating point 0, given by
    ;                       EXP = HIGHBYTE = MIDBYTE = LOWBYTE = 0x00, with 0 being
    ;                       the only number with EXP = 0.
    ;       HIGHBYTE        8 bit most significant byte of fraction in sign-magnitude representation,
    ;                       with SIGN = MSB, implicit MSB = 1 and radix point to the right of MSB
    ;       MIDBYTE         8 bit middle significant byte of sign-magnitude fraction
    ;       LOWBYTE         8 bit least significant byte of sign-magnitude fraction
    ;       EXPONENT        HIGHBYTE        MIDBYTE         LOWBYTE
    ;       xxxxxxxx        S.xxxxxxx       xxxxxxxx        xxxxxxxx
    ;                      RADIX
    ;                      POINT
    IeeFormat:
    http://www.h-schmidt.net/FloatConverter/IEEE754.html
    As you can see in IEE format, only 7 bit of exponent is in first byte, so bit 23 should be shifted to first bit of byte3, when shifting to right exponent.
    Here is binary for 23.75:
    IEE   41BE0000 = 01000001 10111110 00000000 00000000
    MCHIP 833E0000 = 10000011 00111110 00000000 00000000
    Darel 82BE0000 = 10000010 10111110 00000000 00000000
    As you can see Darrel's code set sign instead of first bit of exponent.
    Here is my code, done in PBP
    MyIEEEtoMCHIP:
        B.BYTE0=A.BYTE0
        B.BYTE1=A.BYTE1
        B.BYTE2=A.BYTE2 : B.23=A.31 'SIGN
        B.BYTE3=A.BYTE3<<1 : B.24=A.23
    A-IEEE
    B-Microchip
    I'll try to fix Darrel's macro.
    Sep 2009
    I fixed bug in Darrel's macro:
        MOVE?BB Nin, Nout
        ;MOVE?TT Nin+3,7, Nin+2,7  ;<<<<<<<<here he is setting bit in input byte, not output byte
        MOVE?TT Nin+3,7, Nout+2,7  ;<<<<<<<<Corrected
        MOVE?BA Nin+3
        RLNCF   WREG,W
        MOVE?AB Nout+3
  1. Using Floating Point to integer subroutines
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 5th March 2014, 08:52
  2. Microchip 32bit floating point to integer conversion
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 1st February 2011, 17:49
  3. Replies: 5
    Last Post: - 28th May 2008, 11:20
  4. Replies: 3
    Last Post: - 18th March 2008, 05:29
  5. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 03:03
