Converting 32 bit Floating Point, and 48 and 64 bit Integer to string
Results 1 to 11 of 11
    Sep 2009
    Default Converting 32 bit Floating Point, and 48 and 64 bit Integer to string
    I need to upgrade old project. It's quit complicated...
    Now it need to display data received via serial port. There is few data format which need to be displayed.
    Most critical is 32bit Floating Point. There is no need for any other calculation, except converting it to ASCII string.
    I have about 30K of code space, for implementing 32 bit FP to ASCII converter, and 64bit Integer do ASCII.
    Does any have any idea where to start?
    One other thing that crossed my mind is to create small program that convert data from X ram location to ASCII and store it in ram on Y location in some other programming language that support FP.
    Program should start at predefined address and use predefined ram. So I can put data at right place, call some address and then get ASCII string back...
    If i could change data formats I would, but I can't. It's fixed...
    I forgot to say for FP I need -###.### format, without leading zeros, and only - in front if negative. Maybe it helps that range is +/-100 for FP. And full range for signed and unsigned integers...
    I really doesn't understand why is so much data formats used on same device.
    Default Re: Converting 32 bit Floating Point, and 48 and 64 bit Integer to string
    you have not really explained what format the serial data input takes . can you provide a few examples of input data verses desired result
    Sep 2009
    I can try to explain. I get 4 bytes for FP.
    Eg:
    For temperature 23.75, I get 4 bytes $41,$BE,$00,$00
    24.375=$41,$c3,$00,$00
    etc...
    And that values matches with results from this calculator:
    http://www.h-schmidt.net/FloatConverter/IEEE754.html
    Sep 2009
    Thanks!
    I just take short look at that, and that should be exactly what I need. I'll give it a try and report back. Thank again.
    Sep 2009
    While writing first post, I was thinking that DT isn't around any more...
    And here it is, his solution
    Sep 2009
    I found this article
    http://www.picbasic.co.uk/forum/cont...153-N-Bit_MATH
    That should be enough, to display 64 bit integer.
    Sep 2009
    I tested Darrels example with more numbers and something doesn't work...
    include "fp1832l.bas"
    ;----[Variables]----------------------------------------------------------------
    A         VAR LONG
    B         VAR LONG
    A_Float   VAR LONG EXT : @A_Float = AARGB2 ;
    B_Float   VAR LONG EXT : @B_Float = BARGB2 ;
    OutStr    VAR BYTE[20]
    ;----[macro Converts IEEE to Microchip FP format]-------------------------------
    IEEEtoMCHIP?NN  macro Nin, Nout
        MOVE?BB Nin, Nout
        MOVE?BB Nin+1, Nout+1
        MOVE?BB Nin+2, Nout+2
        MOVE?TT Nin+3,7, Nin+2,7
        MOVE?BA Nin+3
        RLNCF   WREG,W
        MOVE?AB Nout+3
        MOVE?TT Nin+2,7, Nout+3,0
    ;----[Test IEEE to Microchip conversion]---------------------------------------
    HSEROUT2 ["Value from IEEE calculator: 50" ,13,10]
    A = $42480000        ; 50 - IEEE
    GOSUB ShowConversion
    HSEROUT2 ["Value from IEEE calculator: -25.62" ,13,10]
    A = $C1CCF5C3        ; -25.62 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 23.75" ,13,10]
    A = $41BE0000        ; 23.75 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 35.00" ,13,10]
    A = $420C0000        ; 35.00 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 24.00" ,13,10]
    A = $41C00000        ; 24.00 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 22.00" ,13,10]
    A = $41B00000        ; 22.00 - IEEE
    HSEROUT2 ["Value from IEEE calculator: 8.875" ,13,10]
    A = $410E0000        ; 8.875 - IEEE
    STOP
    ;----[Show conversion via HSEROUT]---------------------------------------------
    ShowConversion:
        HSEROUT2 ["IEEE = ",HEX8 A,13,10]
        @ IEEEtoMCHIP?NN _A, _B
        HSEROUT2 ["Mchip= ",HEX8 B,13,10]
        A_Float = B
        GOSUB FtoIA
        HSEROUT2 ["Aint = ",SDEC Aint,13,10]
        A = Aint
        A_Float = B       ; with 1 decimal place
        Bint = 10
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT2 ["       ",SDEC Aint/10,".",DEC1 ABS(Aint),13,10]
        A_Float = B       ; with 2 decimal places
        Bint = 100
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT2 ["       ",SDEC Aint/100,".",DEC2 ABS(Aint),13,10]
        A_Float = B       ; with 3 decimal places
        Bint = 1000
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        HSEROUT2 ["       ",SDEC Aint/1000,".",DEC3 ABS(Aint),13,10,13,10]
    Results:
    IEEE = 42480000
    Mchip= 84480000
    Aint = 50
           50.0
           50.00
           50.000
    IEEE = C1CCF5C3
    Mchip= 83CCF5C3
    Aint = -25
           -25.6
           -25.62
           -25.620
    IEEE = 41BE0000
    Mchip= 82BE0000
    Aint = -11
           -11.8
           -11.87
           -11.875
    IEEE = 420C0000
    Mchip= 840C0000
    Aint = 35
           35.0
           35.00
           35.000
    IEEE = 41C00000
    Mchip= 82C00000
    Aint = -12
           -12.0
           -12.00
           -12.000
    IEEE = 41B00000
    Mchip= 82B00000
    Aint = -11
           -11.0
           -11.00
           -11.000
    IEEE = 410E0000
    Mchip= 820E0000
    Aint = 8
           8.8
           8.87
           8.875
    Sep 2009
    As far as I can see, there is some problem with Darrel subroutine.
    To get correct number in microchip format I used this code:
        aint = 2375
        Gosub itofa     ' Convert int to float
        bint = 100
        Gosub itofb     ' Convert int to float
        Gosub fpdiv
    Result is: $833E0000
    And I can display correctly with this code:
        A_Float = $833E0000  ; with 1 decimal place
        Bint = 10
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        Bint = 100
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
        Bint = 1000
        GOSUB ItoFB
        GOSUB fpmul
        GOSUB FtoIA
    Output is:
    23.7
    23.74
    23.749
    That is fine...
    But when I try to convert $41BE0000 with Darrel's routine result is
    IEEE = 41BE0000
    Mchip= 82BE0000
    Sep 2009
    I think that I solved this...
    From include file FP32.A18:
    ;       32 bit floating point representation
    ;       EXPONENT        8 bit biased exponent
    ;                       It is important to note that the use of biased exponents produces
    ;                       a unique representation of a floating point 0, given by
    ;                       EXP = HIGHBYTE = MIDBYTE = LOWBYTE = 0x00, with 0 being
    ;                       the only number with EXP = 0.
    ;       HIGHBYTE        8 bit most significant byte of fraction in sign-magnitude representation,
    ;                       with SIGN = MSB, implicit MSB = 1 and radix point to the right of MSB
    ;       MIDBYTE         8 bit middle significant byte of sign-magnitude fraction
    ;       LOWBYTE         8 bit least significant byte of sign-magnitude fraction
    ;       EXPONENT        HIGHBYTE        MIDBYTE         LOWBYTE
    ;       xxxxxxxx        S.xxxxxxx       xxxxxxxx        xxxxxxxx
    ;                      RADIX
    ;                      POINT
    IeeFormat:
    As you can see in IEE format, only 7 bit of exponent is in first byte, so bit 23 should be shifted to first bit of byte3, when shifting to right exponent.
    Here is binary for 23.75:
    IEE   41BE0000 = 01000001 10111110 00000000 00000000
    MCHIP 833E0000 = 10000011 00111110 00000000 00000000
    Darel 82BE0000 = 10000010 10111110 00000000 00000000
    As you can see Darrel's code set sign instead of first bit of exponent.
    Here is my code, done in PBP
    MyIEEEtoMCHIP:
        B.BYTE0=A.BYTE0
        B.BYTE1=A.BYTE1
        B.BYTE2=A.BYTE2 : B.23=A.31 'SIGN
        B.BYTE3=A.BYTE3<<1 : B.24=A.23
    A-IEEE
    B-Microchip
    I'll try to fix Darrel's macro.
    Sep 2009
    I fixed bug in Darrel's macro:
        MOVE?BB Nin, Nout
        ;MOVE?TT Nin+3,7, Nin+2,7  ;<<<<<<<<here he is setting bit in input byte, not output byte
        MOVE?TT Nin+3,7, Nout+2,7  ;<<<<<<<<Corrected
        MOVE?BA Nin+3
        RLNCF   WREG,W
        MOVE?AB Nout+3
  1. Using Floating Point to integer subroutines
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 5th March 2014, 08:52
  2. Microchip 32bit floating point to integer conversion
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 1st February 2011, 17:49
  3. Replies: 5
    Last Post: - 28th May 2008, 11:20
  4. Replies: 3
    Last Post: - 18th March 2008, 05:29
  5. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 03:03
