simple way?
Results 1 to 2 of 2
Thread: simple way?
    Default simple way?
    Hello Everyone. Here is a piece of code. It simply turns an X10 module (with the address 0,0) on, it waits 1 second and turns it off. This works perfectly. What I want to do is use only the first line and replace unitOn with a command that will turn on if it's off and turn off if it's on. Like the "toggle" command. I guess I could use the read and write commands to "remember" the state of the module but was hoping for an easier way. Thanks for any suggestions.
    XOUT PORTA.4, PORTA.5, [0\0,0\unitOn]
    Pause 1000
    XOUT PORTA.4, PORTA.5, [0\0,0\unitOff]
    Pause 1000
    Wink
    Your answer is hidden in the Pbpicxx.libs ...XOUT section ...
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  3. Simple LCD code not working!...WHY?
    Last Post: - 29th November 2009, 19:48
  4. Replies: 0
    Last Post: - 2nd February 2009, 23:23
  5. Replies: 4
    Last Post: - 7th September 2005, 14:11
