Incrementing Upper Nibble Only (HighNibble)
Results 1 to 4 of 4
    Jul 2013
    Default Incrementing Upper Nibble Only (HighNibble)
    Hello Again,
    How does one increment only the upper nibble of a byte?
    Apparently there is no HighNibble or LowNibble function in PICBASIC?
    My goal is to add 1, to the value of Bits [7654] leaving Bits [3210] alone.
    And/or how to set just the high bits to some number?
    Thanks!
    Default Re: Incrementing Upper Nibble Only (HighNibble)
    number var byte
    number=number+16 will increment high nibble
    number var byte
    somenumber var byte
    number =$11
    somenumber =2
    number =(number&$f) |( somenumber<<4 );note (for a meaningful result somenumber <16)
    result number=$21
    Last edited by richard; - 6th March 2015 at 22:37. Reason: add some more brackets just in case
    Jul 2013
    Richard,
    Wonderful! Works beautifully!
    number var byte
    Again, very clean and easy.
    Thank you very much!
    Jay Zebryk
    Zebryk Engineering
    Southbridge, Massachusetts
    www.zebryk.com
  1. 32 bit seconds math (how do I include the upper 16 bits?)
    By Heckler in forum mel PIC BASIC Pro
    Last Post: - 5th February 2015, 04:46
  2. Combining 4 nibble to 16bits
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 11th November 2006, 22:40
  3. Accessing the upper 64Kbytes with READCODE
    Last Post: - 14th March 2006, 22:22
  4. Incrementing Help
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2005, 22:57
  5. writecode at upper half of 128K parts?
    By Tomasm in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2004, 20:02
