Can't get SST25VF032B to work
Results 1 to 2 of 2
    New Jersey
    Default Can't get SST25VF032B to work
    I'm using the same footprint as a FM25V10 and the SST25VF032B appears to have almost the exact same instructions as the FM25V10. The problem is, no matter what commands I try, reading or writing produce nothing usable. The code is below. Can anyone see something that I missed?
    MSSP_WRITE:
      	LOW PORTH.3
    	SSP2BUF =  6
        WHILE PIR3.7 = 0:WEND:PIR3.7 = 0
    	HIGH PORTH.3
        LOW PORTH.3
        SSP2BUF =  2
        SSP2BUF =  MCP_ADDRESS_EXT
        SSP2BUF =  MCP_ADDRESS_.HIGHBYTE
        SSP2BUF =  MCP_ADDRESS.LOWBYTE
        SSP2BUF = WRITE_DATA
        HIGH PORTH.3
    MSSP_READ:
     	LOW PORTH.3
        SSP2BUF = 3
        SSP2BUF =  MCP_ADDRESS.HIGHBYTE
        READ_DATA = SSP2BUF
        HIGH PORTH.3
    Default Re: Can't get SST25VF032B to work
    As far as I understand (having played around with the SST25VF08 a couple of years ago) you have to,
    A) Make sure the adress you're trying to write to it's erased,
    B) If the WP-pin is HIGH, make sure the block you're trying to write is NOT protected by the Block Protect bits in the status register, see below.
    B.1) Execute the EWSR command
    B.2) Execute the WRSR command
    B.2) Write the new value (0 to unlock all of it) of the status register
    C) Execute the WREN instruction.
    I highly recommend you declare a bunch of constants for the various commands, it's much easier than having to a bunch a magic numbers in the code.
    SST_Cmd_Read                CON $03                 ' Read byte, adress increment automatically
    SST_Cmd_EWSR                CON $50                 ' Enable status register write
    SST_Cmd_WREN                CON $06                 ' Write Enable
    SSPBUF = SST_Cmd_WREN
  1. bootloader does not work..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 21st October 2011, 09:55
  2. Cant get it to work
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 9th April 2010, 09:21
  3. why this doesn't work?
    By strasni_betmen in forum Serial
    Last Post: - 4th September 2008, 15:56
  4. Will This program work
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 22:45
  5. does this work?
    By igor@24 in forum mel PIC BASIC Pro
    Last Post: - 13th June 2005, 19:19
