How to setup 38kHz PWM with PIC18F1330
Results 1 to 15 of 15
    SWITZERLAND (french speaking)
    Default Re: How to setup 38kHz PWM with PIC18F1330
    I'm modified my code as follows (in bold) and unfortunately, I doesn't work at all now (now PWM signal).
    ' Fuses PIC18F1330 for MPASM
    @ __CONFIG _CONFIG1H, _OSC_HS_1H     & _FCMEN_OFF_1H   & _IESO_OFF_1H
    @ __CONFIG _CONFIG2L, _PWRT_OFF_2L   & _BOR_OFF_2L     & _BORV_0_2L
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H    & _WDTPS_512_2H
    @ __CONFIG _CONFIG3L, _HPOL_HIGH_3L  & _LPOL_HIGH_3L   & _PWMPIN_OFF_3L
    @ __CONFIG _CONFIG3H, _FLTAMX_RA7_3H & _T1OSCMX_LOW_3H & _MCLRE_OFF_3H
    @ __CONFIG _CONFIG4L, _STVREN_ON_4L  & _BBSIZ_BB256_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L    & _CP1_OFF_5L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H    & _CPD_OFF_5H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L   & _WRT1_OFF_6L
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H   & _WRTB_OFF_6H    & _WRTD_OFF_6H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L  & _EBTR1_OFF_7L
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    ' Main Registers
    '          76543210
    'OSCCON  = %00000000 'OSCILLATOR CONTROL REGISTER
    'OSCTUNE = %00000000 'OSCILLATOR TUNING REGISTER
    ADCON0  = %00000000 'A/D CONTROL REGISTER 0
    ADCON1  = %00000000 'A/D CONTROL REGISTER 1
    ADCON2  = %00000000 'A/D CONTROL REGISTER 2
    INTCON  = %00000000 'INTERRUPT CONTROL REGISTER
    INTCON2 = %00000000 'INTERRUPT CONTROL REGISTER 2
    INTCON3 = %00000000 'INTERRUPT CONTROL REGISTER 3
    TRISA   = %00000000 'Data Direction Control Register (Input/Output)
    PORTA   = %00000000 'State High (1) or Low (0)
    TRISB   = %00000000 'Data Direction Control Register (Input/Output)
    PORTB   = %00000000 'State High (1) or Low (0)
    ' Set up PWM1 (PORTB.1)
    T0CON   = %00000000
    T1CON   = %01001010
    PTCON0  = %00000000 'Postscale 1:1, Fosc/4 Prescale 1:1, Free Running Mode
    PTCON1  = %10000000 'Time base in ON, Time base counts up
    PWMCON0 = %00010000 'PWM1 enabled
    PDC0H   = 30        'Duty Cycle control for PWM0/1
    PTMRL   = %00000000
    PTMRH   = %00000000
    PTPERL  = %00110011 ' = 51
    PTPERH  = %00000000
    DEFINE OSC 8
    LED var PORTA.2
    'PORTB.1 is PWM1
    MAIN:
        TOGGLE LED
        PAUSE 500
        GOTO MAIN
    Roger
    Way to high duty cycle value (7680) try writing 30 to PDC0L instead.
    Thanks a lot Henrik.
    It works now
    To get a nice "visual" (= visible on scope) close to 50% duty-cycle, I set PDC0L to 100.
    I now have to start to "play" with the formula(s) and registers to change values - I might come back for more questions
    T0CON   = %00000000
    T1CON   = %01001010
    PDC0L   = 100        'Duty Cycle control for PWM0/1
    PTMRL   = %00000000
    PTMRH   = %00000000
    PTPERH  = %00000000
    Sorry to ask maybe a stupid question but what is the interrest of a PWM "resolution" parameter? I can understand resolution for an incoming analog signal, but PWM is only output as far as I know...
    Another thing; look at the pulsed signal, especially at the high state where the signal is kind of rippled. What's wrong here?
    Roger
    It's not really a parameter in that sense, it's more like a side effect of the relationship between the oscillator frequency and PWM frequency. The closer they are in relation to each other the less resolution you get - it's just the way it works.
    Basically, all it is a counter driven by the oscillator. The PWM period is set by telling a comparator at what count to "start over". If the counter is clocked at 1MHz and you tell it start over at the value 100 then the PWM frequency would be 1000000/100=10000Hz. If you tell it start over at 10000 the PWM frequency becomes 1000Hz and so on. This is what the PTPER value does.
    The PWM output is set at the start of the PWM cycle and reset when the counter equals the dutycycle value. Now I Think you can see that when the PWM frequency in the example above is 1000Hz ther resolution will be 10000 "steps" while when the PWM frequency is 10000Hz the resolution will be 100 "steps". It's just the way a digital PWM generator works.
    As for your ripple, make sure you have decoupling capacitor(s) as close to the supply pins of the PIC as possible. If the PIC has more than one pair of supply pins make sure they are all connected and properly bypassed.
    Thanks Henrik.
    I had to use a 4,7µF capacitor to finally get a nice clean signal
    Thank you for the explanation too. I'll have a go for some tests with the formulas; this is going to be the hardest for me...maths are not really my best friends
    Roger
    Roger
    So there's where I am now:
    Desired freq = 38kHz (PWMperiod = 26,3157µs), crystal (Fosc) 20MHz, prescaler = 1
    SEARCHING FOR PTPER (max 4095)
    Transform formula:
    PWMperiod[µs] = (PTPER+1 * prescaler) / (Fosc / 4)
    => (PTER+1 * prescaler) = PWMperiod * (Fosc / 4)
    => PTPER+1 = (PWMperiod * (Fosc / 4)) / prescaler
    (26,3157µs * 5'000'000) / 1 = 131
    But how do I calculate the duty-cyle register (PDC0) admitting I'd like to have a 50% value to set?
    Roger
    There will be aproximately 4 times as many "steps" (+/-3) to the dutycycle value as you set PTPER to. If PTPER is 131 then you'll have 131*4 = 524 steps so to get a a 50% dutycycle you set the dutycycle register to 264 (PDC0H=1, PDC0L=8).
    Well, I just found this in the DS:
    DS note, page 131:
    To get the correct PWM duty cycle, always
    multiply the calculated PWM duty cycle
    value by four before writing it to the PWM
    Duty Cycle registers....
    I think this means a "100%" (in my mind, this is a signal always high - not useful but for the theory) duty-cycle value would be:
    - PTER * 4 => 130 * 4 => 520
    So, for a 50% duty-cycle, the PDC0 value is going to to be:
    - 520 * 50% => 260
    But, playing with the values, I can see on my scope that the numbers would be more accurate taking in account the PTER+1 (131 instead of 130) value.
    Where is the truth?
    Roger
  1. 38Khz Modulator
    By Gord11 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2011, 08:14
  2. manual hardware PWM setup on 16F1824
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 31st January 2011, 18:34
  3. Use Button For setup
    By tump in forum mel PIC BASIC Pro
    Last Post: - 21st November 2007, 19:43
  4. Generated square wave 19Khz and 38Khz
    By blinkstar88 in forum mel PIC BASIC Pro
    Last Post: - 9th August 2007, 16:40
  5. pic12f683 setup
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 4th July 2007, 11:48
