I'm modified my code as follows (in bold) and unfortunately, I doesn't work at all now (now PWM signal).
Code:' Fuses PIC18F1330 for MPASM @ __CONFIG _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_0_2L @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H @ __CONFIG _CONFIG3L, _HPOL_HIGH_3L & _LPOL_HIGH_3L & _PWMPIN_OFF_3L @ __CONFIG _CONFIG3H, _FLTAMX_RA7_3H & _T1OSCMX_LOW_3H & _MCLRE_OFF_3H @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _BBSIZ_BB256_4L & _XINST_OFF_4L & _DEBUG_OFF_4L @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H '========================================================================== ' Main Registers ' 76543210 'OSCCON = %00000000 'OSCILLATOR CONTROL REGISTER 'OSCTUNE = %00000000 'OSCILLATOR TUNING REGISTER ADCON0 = %00000000 'A/D CONTROL REGISTER 0 ADCON1 = %00000000 'A/D CONTROL REGISTER 1 ADCON2 = %00000000 'A/D CONTROL REGISTER 2 INTCON = %00000000 'INTERRUPT CONTROL REGISTER INTCON2 = %00000000 'INTERRUPT CONTROL REGISTER 2 INTCON3 = %00000000 'INTERRUPT CONTROL REGISTER 3 TRISA = %00000000 'Data Direction Control Register (Input/Output) PORTA = %00000000 'State High (1) or Low (0) TRISB = %00000000 'Data Direction Control Register (Input/Output) PORTB = %00000000 'State High (1) or Low (0) ' Set up PWM1 (PORTB.1) T0CON = %00000000 T1CON = %01001010 PTCON0 = %00000000 'Postscale 1:1, Fosc/4 Prescale 1:1, Free Running Mode PTCON1 = %10000000 'Time base in ON, Time base counts up PWMCON0 = %00010000 'PWM1 enabled PDC0H = 30 'Duty Cycle control for PWM0/1 PTMRL = %00000000 PTMRH = %00000000 PTPERL = %00110011 ' = 51 PTPERH = %00000000 DEFINE OSC 8 LED var PORTA.2 'PORTB.1 is PWM1 MAIN: TOGGLE LED PAUSE 500 GOTO MAIN END
