Interrupts and Sleep help 16f818
Results 1 to 11 of 11
    May 2012
    Merseyside, UK
    Default Re: Interrupts and Sleep help 16f818
    Hello again...
    Have put together some code as I see it... :-
    ' Name        : PI.pbp
    ' Compiler    : PICBASIC PRO Compiler 2.5
    ' Assembler   : MPASM
    ' Target PIC  : PIC16F628A or similar type
    ' Hardware    : VeroBoard
    ' Oscillator  : 4Megs Internal
    ' Keywords    : I2CREAD, I2CWRITE, LCDOUT
    ' Description : PICBASIC PRO program for an LCD clock program
    ' using the Dallas DS1307 I2C RTC.
    ' Define LCD pins
            DEFINE LCD_EREG PORTA
            DEFINE LCD_EBIT 6
    ' Alias pins
            SDA Var PORTB.1
            SCL Var PORTB.4
            wakebutton var PORTB.0 'shake
            lcdandrtc var PORTA.6 'LCD and RTC ON/OFF
            timeout1 var byte
            'timeout2 var byte
    ' Allocate variables
            RTCYear  Var Byte
            RTCMonth Var Byte
            RTCDate  Var Byte
            RTCDay   Var Byte
            RTCHour  Var Byte
            RTCMin   Var Byte
            RTCSec   Var Byte
            RTCCtrl  Var Byte
            TRISA=0 'outputs
            TRISB=15 'Bit 0,1,2,3 inputs
            CMCON=7 'turns  off analogs
    wakeup: INTCON=%00010000 'RB0 is interrupt
            OPTION_REG.6=0 'Trig on falling
            OPTION_REG.7=0 'Enables pull ups
            Pause 500            ' Wait for LCD to startup
            Lcdout $fe, 1 ' Clear LCD screen
            Lcdout "WELCOME TO"  ' Display WELCOME TO
            Lcdout $fe, $C0, "      PI DAY" ' Display  PI Day
            Pause 2000       ' Wait 2 seconds
            'Set initial time
            RTCYear = $15
            RTCMonth = $03
            RTCDate = $03
            RTCDay = $06
            RTCHour = $20
            RTCMin = $46
            RTCSec = 0
            RTCCtrl = 0
            'Gosub settime        ' Set the time
            Goto mainloop        ' Skip over subroutines
    ' Subroutine to write time to RTC
    'settime:I2CWrite SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
    '        Return
    ' Subroutine to read time from RTC
    gettime:I2CRead SDA, SCL, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
            timeout1=rtcmin
    ' Main program loop
    mainloop:Gosub gettime        ' Read the time from the RTC
            ' Display time on LCD
            'Lcdout $fe, 1, hex2 RTCMonth, "/", hex2 RTCDate, "/" , hex2 RTCYear,_
            '"  ", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
            Lcdout $fe, 1, HEX2 RTCDate, "/", HEX2 RTCMonth,"   ", HEX2 RTCHour, ":", HEX2 RTCMin, ":", HEX2 RTCSec
            IF RTCHour <=$12 then  gosub morning
            IF RTCHour >=$13 then  gosub afternoon
            IF RTCHour=$03 and RTCMin=$14 Then CACHE ' Morning Cache
            IF RTCHour=$15 and RTCMin=$14 Then CACHE ' Afternoon Cache
            if rtcmin=(timeout1+2) then bedtime
            Pause 500            ' Do it about 2 times a second
            Goto mainloop        ' Do it forever
    morning:    Lcdout $fe, $C0, "CACHE @  3:14AM"
    afternoon:  Lcdout $fe, $C0, "CACHE @ 3:14PM"
    CACHE:  Lcdout $fe, 1 ' Clear LCD screen
            LCDOUT "CONGRATULATIONS"
            Lcdout $fe, $C0, "CACHE IS LOCATED"
            PAUSE 2000
            Lcdout "N   XX",$DF, "  YY.ZZZ "  ' Display N   123° 456.789
            Lcdout $fe, $C0, "W   XX",$DF, "  YY.ZZZ " ' Display  W   123° 456.789
            PAUSE 20000
    bedtime:high lcdandrtc 'turn of lcd and rtc
            INTCON.1=0 'reset RB0 interupt flag
            @ sleep
            @ NOP
            @ NOP
            pause 500 'wakeup delay
            goto wakeup
    Would appreciate some comments .... good or bad on above code.... I am not really sure about my jumps out of the main loop to "bedtime" I have just identified that if it is more than 58 mins to the hour my +2 calc wont work :-) So need to find a work around ?
    Thank you for reading... Andy
    Jan 2013
    Texas USA
    Andy,
    You are correct that your timeout1 test/calculation will fail when the RTC roles over from 59 to 00.
    Also, if for some reason that the execution is delayed you could miss an entire minute which would further affect your timeout1 test.
    I took the liberty of adding/modifying the logic to make this portion more robust (although I can't test this :-) )
    Take a look at the revised code and see if this helps you.
    ' Name        : PI.pbp
    ' Assembler   : MPASM
    ' Define LCD pins
            DEFINE LCD_EBIT 6
    ' Alias pins
            SDA Var PORTB.1
            SCL Var PORTB.4
            timeout1 var byte
            'timeout2 var byte
            PrevTime var byte     'Holds previously read RTCMin
            CurTime  var byte     'Holds currently read RTCMin
            TimeoutMax var byte 'You can change this to a constant if it is not changed during execution
            WakeupFlag var bit    'Used for wakeup/reset tracking for timer
            TimeoutMax = $02    'You can delete this if TimeoutMax is a constant
            WakeupFlag = 1        'Preset to true
            RTCYear  Var Byte
            RTCMonth Var Byte
            RTCDate  Var Byte
            RTCDay   Var Byte
            RTCHour  Var Byte
            RTCMin   Var Byte
            RTCSec   Var Byte
            RTCCtrl  Var Byte
            TRISA=0 'outputs
            timeout1 = TimeoutMax   'Preset timeout1 for countdown
            'Set initial time
            RTCYear = $15
            RTCMonth = $03
            RTCDate = $03
            RTCDay = $06
            RTCHour = $20
            RTCMin = $46
            RTCSec = 0
            RTCCtrl = 0
    '        Return
            'timeout1=rtcmin
            CurTime = RTCMin    '
            if WakeupFlag = 1 then  '1st time after a wakeup/reset
                PrevTime = CurTime  'Set PrevTime after wakeup/reset
                WakeupFlag = 0        'Clear the flag
    ' Main program loop
    mainloop:
            'if rtcmin=(timeout1+2) then bedtime
            If CurTime > PrevTime Then
                timeout1 = timeout1 - (CurTime - PrevTime)
                PrevTime = CurTime
                'Oops something happened. Current time is less than Previous time
                'This should take care of the rollover from 59 to 00 minutes and unexpected delays
                'If timeout1 = 0 no need to do anything, the timeout1 test below will put the unit to sleep
                'The WakeupFlag will be set when we go to sleep and PrevTime and CurTime will be set properly
                'after we wakeup and proceed through the mainloop
                if timeout1 > 0 then
                    timeout1 = timeout1 - 1 'decrement the timeout value
                    PrevTime = CurTime  'Reset Previous time to a valid number for the countdown timer
            if timeout1 = 0 then    'Timeout reached
                WakeupFlag = 1     'Reset the flag
                goto bedtime        'countdown has reached 0, go to sleep
            PAUSE 2000
            PAUSE 20000
            @ sleep
            @ NOP
            @ NOP
            goto wakeup
    TABSoft
    May 2012
    Merseyside, UK
    Missed this...
    Thanks TABSoft..... Will try later.
    Let you know how I get on
    BR
    Andy
  1. 16f818 from 16f628a
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 07:31
  2. Basic problem with interrupts and sleep command
    By Davidmarks in forum mel PIC BASIC Pro
    Last Post: - 21st February 2012, 01:21
  3. Replies: 3
    Last Post: - 6th November 2011, 19:33
  4. Replies: 0
    Last Post: - 26th June 2010, 17:52
  5. @ SLEEP with interrupts 16F88
    By drewlash in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 05:55
