Quickest way to get highest set bit on port in to a variable?
Results 1 to 29 of 29
    Jan 2013
    Texas USA
    Default Re: Quickest way to get highest set bit on port in to a variable?
    I may be wrong but I don't think this will work.
    LOOKDOWN2 Search,{Test}[Value{,Value...}],Var
    Lookdown2 compares the value of "Search" with the values in the list from left to right (index values 0 up to 255) with the "Test" comparison.
    So if "Search" = 5 and "Test" = "=>" then using your values for the Value in the list, the logic tests should look like this.
    (Values: 0, 1, 2, 4, 8, 16, 32, 64, 128) bits 0-7
    Test 1: is 5 => 0? : Yes, (0 will be stored in Var)
    The testing would stop right here for every value of "Search" (0-255) for bytes (0-65535) for words because the "Search" value will always be greater than or equal 0 (unless you're using Long variables)
    Maybe I'm wrong?
    As I see it, to use Lookdown2 you would still need to enter all the values from 0 to 255 inclusive into the list.
    And "Test" would need to be set to "="
    Lookdown2 supports up to 85 values in the list or up to 256 when using a PIC18.
    TABSoft
    Miami, Florida USA
    Quote Originally Posted by Tabsoft View Post
    Lookdown2 compares the value of Search with the values in the list from left to right (index values 0 up to 255) with the "Test" comparison.
    So if Search = 5 and Test = "=>" then using your values for the Value in the list, the logic tests should look like this.
    The testing would stop right here for every value of Search (0-255) for bytes (0-65535) for words.
    Maybe I'm wrong?
    And
    No, I don't think that you are wrong. I think there is a minor change that needs to be done to Dave's code,
    lookdown2 index, <= [%00000000,%00000001,%00000010,%00000100,%00001000,%00010000,%00100000,%01000000,%10000000,255],temp
    Anonymous
    Jan 2013
    Texas USA
    Thanks for the feedback.
    I still think there are issues with this approach.
    I ran a test and printed the output.
    I ran a For/Next loop from 0 to 255.
    e.g.
    For i = 0 to 255
    Lookdown2 i, <= [%00000000,%00000001,%00000010,%00000100,%00001000, %00010000,%00100000,%01000000,%10000000,%11111111], j
    Next i
    The output resulted in 247 wrong values out of 256.
    I am attaching the output here.
    Again, perhaps I'm wrong and missing something?
    Lookdown2.pdf
    TABSoft
    Miami, Florida USA
    e.g.
    For i = 0 to 255
    Next i
    Attachment 7724
    Yes, you are right. We should always use truth tables just to make sure it is correct. We were just giving Matias a general idea. Try this now,
    For i = 0 to 255
    Lookdown2 i, <= [%00000000,%00000001,%00000011,%00000111,%00001111, %00011111,%00111111,%01111111,%11111111], j
    Next i
    Anonymous
    Jan 2013
    Texas USA
    Thanks. That works great.
    To find the port pin state using this, you would just need to decrement the return value by 1 if the value is >0 ( same for NCD).
    When I get some time I will run this against NCD and check the instruction cycles to see which is quicker.
    Thanks again.
    TABSoft
    Not wishing to be rude, but how can 255 iterations be quicker than NCD or the in-line assembler equivalent?
    George
    Miami, Florida USA
    Quote Originally Posted by towlerg View Post
    George
    The 255 iterations is just to test the LOOKDOWN2 command line.
    Anonymous
  1. Replies: 6
    Last Post: - 18th July 2012, 02:42
  2. Whats the quickest way to set bits?
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th October 2010, 04:38
  3. Bit set question
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2007, 21:23
  4. set flags within a variable?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2006, 11:07
  5. How do I to set one bit in a register?
    Last Post: - 11th February 2006, 08:43
