Quickest way to get highest set bit on port in to a variable?
Results 1 to 29 of 29
    Miami, Florida USA
    Default Re: Quickest way to get highest set bit on port in to a variable?
    Like Archangel mentioned above, you should also try the LOOKUP command. This command takes only a few cycles to execute.
    Anonymous
    Henric, never the less, not as quick as 8 rotates and 8 jump on carry in-line. Worst case, with no bits set in the target thats only 16 cycles.
    rscor01, I didn't realize LOOKUP would do that. How would that go?
    George
    Miami, Florida USA
    Quote Originally Posted by towlerg View Post
    Nevermind. You would need too many entries in the LOOKUP constant fields. That would be 64 entries to be precise since your variable PORT has 6 bits. It will be something like this
    LOOKUP MyPort, [0,1,2,2,3,3,3,3,4,........], MyVar
    Still, it might be faster than NCD, but I don't know.
    Anonymous
    George
    lookdown2 index, >= [%00000000,%00000001,%00000010],temp
    Miami, Florida USA
    Quote Originally Posted by Archangel View Post
    Nice! Very clever indeed . I have never used this command before, but now I can see it's potential.
    Anonymous
    Jan 2013
    Texas USA
    I may be wrong but I don't think this will work.
    LOOKDOWN2 Search,{Test}[Value{,Value...}],Var
    Lookdown2 compares the value of "Search" with the values in the list from left to right (index values 0 up to 255) with the "Test" comparison.
    So if "Search" = 5 and "Test" = "=>" then using your values for the Value in the list, the logic tests should look like this.
    (Values: 0, 1, 2, 4, 8, 16, 32, 64, 128) bits 0-7
    Test 1: is 5 => 0? : Yes, (0 will be stored in Var)
    The testing would stop right here for every value of "Search" (0-255) for bytes (0-65535) for words because the "Search" value will always be greater than or equal 0 (unless you're using Long variables)
    Maybe I'm wrong?
    As I see it, to use Lookdown2 you would still need to enter all the values from 0 to 255 inclusive into the list.
    And "Test" would need to be set to "="
    Lookdown2 supports up to 85 values in the list or up to 256 when using a PIC18.
    TABSoft
    Miami, Florida USA
    Quote Originally Posted by Tabsoft View Post
    Lookdown2 compares the value of Search with the values in the list from left to right (index values 0 up to 255) with the "Test" comparison.
    So if Search = 5 and Test = "=>" then using your values for the Value in the list, the logic tests should look like this.
    The testing would stop right here for every value of Search (0-255) for bytes (0-65535) for words.
    Maybe I'm wrong?
    And
    No, I don't think that you are wrong. I think there is a minor change that needs to be done to Dave's code,
    lookdown2 index, <= [%00000000,%00000001,%00000010,%00000100,%00001000,%00010000,%00100000,%01000000,%10000000,255],temp
    Anonymous
    Jan 2013
    Texas USA
    Thanks for the feedback.
    I still think there are issues with this approach.
    I ran a test and printed the output.
    I ran a For/Next loop from 0 to 255.
    e.g.
    For i = 0 to 255
    Lookdown2 i, <= [%00000000,%00000001,%00000010,%00000100,%00001000, %00010000,%00100000,%01000000,%10000000,%11111111], j
    Next i
    The output resulted in 247 wrong values out of 256.
    I am attaching the output here.
    Again, perhaps I'm wrong and missing something?
    Lookdown2.pdf
    TABSoft
  1. Replies: 6
    Last Post: - 18th July 2012, 03:42
  2. Whats the quickest way to set bits?
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th October 2010, 05:38
  3. Bit set question
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2007, 22:23
  4. set flags within a variable?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2006, 12:07
  5. How do I to set one bit in a register?
    Last Post: - 11th February 2006, 09:43
