Quickest way to get highest set bit on port in to a variable?
Results 1 to 29 of 29
    Dec 2014
    Default Quickest way to get highest set bit on port in to a variable?
    Hi.
    I have eight sensors with digital output connected to a port and now I want to in the quickest way get only the highest set bit in to a variable.
    if port = 110000
    I want var = 000000
    if port = 001111
    I want var = 001000
    So how can I do this in quickest(least amount of clock cycles) possible way?
    /Matias
    Default Re: Quickest way to get highest set bit on port in to a variable?
    look at NCD command to do what you asked, checkout AND && for your example, search for MASK: http://www.picbasic.co.uk/forum/show...highlight=mask
    or you could use a lookup table
    What PIC device?
    Dec 2014
    Quote Originally Posted by towlerg View Post
    What PIC device?
    It´s a PIC18F45K80
    sorry can't write PIC assembler but something like
    WReg= 8
    Rotate Left f through Carry, 1
    jump on carry, done
    dec WReg
    jump on carry, done
    etc...
    or maybe BTFSC - BitTest, skip if clear
    George
    Dec 2010
    To repeat, look up NCD in the manual. I think it does what you want.
  1. Replies: 6
    Last Post: - 18th July 2012, 02:42
  2. Whats the quickest way to set bits?
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 26th October 2010, 04:38
  3. Bit set question
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2007, 21:23
  4. set flags within a variable?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2006, 11:07
  5. How do I to set one bit in a register?
    Last Post: - 11th February 2006, 08:43
