If Then Range
Results 1 to 12 of 12
Thread: If Then Range
    mytekcontrols's Avatar
    mytekcontrols Guest
    Hi Dynamo,
    Here is another way of expressing the same thing.
    If x => 5 And x <= 8 Then
    [do something code here]
    Endif
    This does give a simpler look to your basic source code, but unfortunately it will cause PBP to compile it fatter (in otherwords it will take more program space in your PIC chip). Any time you use "And" in your If...Then statements you run this risk. The first code sample I gave you circumvents this problem, but does take a little getting used to.
    Go ahead and try both examples, compiling each, and see the difference in the amount of bytes used.
    edit: I just realized that you can save a heck of a lot more bytes by eliminating the "=>" and "<=" and replacing them with ">" and "<" (see examples below). Of course you will need to adjust your range values to compensate, but I think this would be well worth it for the greatly reduced program space needed.
    If x > 4 Then
         If x < 9 Then
         Endif
    Endif
    ' -or-
    If x > 4 And x < 9 Then
    Endif
    Hint: Compile all the examples to see the differences in program space required.
    I hope that answers all your questions,
    Jun 2005
    Wisconsin
    I did try your second example prior to posting. What I found was it includes everything leading up to 8. I think this has to do with the second condition in the statement. It was very odd to see.
    If (x > 4) And (x < 9) Then
    Endif
    should fix it
    Jun 2005
    Wisconsin
    I will give it a try and see how it effects my code size.
    Thanks for all the help so far
    You can test various comparison equations with something like this. Just
    compile each one separately.
    X CON 10
        IF (X=5) or (X<=8) THEN   ' 30 words
        @ nop
    X CON 10
        IF X => 5 THEN
           IF X < 9 THEN  ' 11 words
             @ nop
    Then you could do something like this to save yet a few more words.
    X CON 10
    ' Upper boundary # = 8
    ' Lower boundary # = 5
    ' Range = 4  (5,6,7,8)
    ' IF unknown value (X - lower range #) < range, it's in range.
        IF (X-5) < 4 THEN  ' 8 words
        @ nop
    Just place some heavy-duty comments in there so you don't forget what the
    heck it's doing down-the-road...;o]
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    mytekcontrols Guest
    Thumbs up
    Hey Bruce,
    Wow I had to look at that last example a couple times before it sunk in! But sure enough it does the trick with the least amount of code required. Bravo!
    Jun 2005
    Wisconsin
    Bruce you rock. Between Bruce and Melanie they are PICBasic sages.
  1. Expanding Timer1 counting range
    By sycluap in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2014, 22:00
  2. using a pot to control a time range
    By glkosec in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 19:59
  3. Long range communication
    By Christopher4187 in forum Off Topic
    Last Post: - 6th February 2008, 16:12
  4. Sharp GP2D12 Range Finder???
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 13th December 2007, 09:21
  5. HPWM frequency range
    By jcsquire in forum mel PIC BASIC Pro
    Last Post: - 16th June 2006, 02:11
