10-Bit PWM using PIC16F1509
Results 1 to 20 of 20
    Jan 2011
    Sydney, Australia
    Default Re: 10-Bit PWM using PIC16F1509
    Thanks Richard.
    I updated the versions of PBP3 and MCS and everything now compiles...
    Cheers
    Barry
    VK2XBP
    Having same idea, to control RGB led using PWM, but how you did it with 1 hardware channel PWM?
    OK
    Great question! I don't know. I would suggest if you have 3 different targets (R + B + G) each requiring a different PWM DC%, you will need a PIC with 3 separate PWM channels.
    And that appears to be a hard task - most MCUs as I've checked from datasheet, have "synchronised" PWM outputs, which mostly mirror each other, and also they all run same frequency....
    Sep 2009
    Take look at SPWM from DT. Or better MIBAM.
    OK
    All that means is that the Period for each starts at the same time, and they operate at the same frequency. Each is capable of independent Duty Cycle. That will work for an RGB LED.
    Mike, that means a PIC should have different CCPxCON registers. As many as the different channels, so the user can define the duty of each independently.
    For example, the 16F887 has two and 16F1939 has four CCPxCON registers.
  1. DMX512 Reception + 3 * 8-Bit PWM Outputs
    By JEC in forum Code Examples
    Last Post: - 16th February 2015, 16:21
  2. 16 bit PWM using CCP1
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 09:13
  3. Replies: 17
    Last Post: - 22nd May 2014, 20:58
  4. Replies: 1
    Last Post: - 13th March 2012, 00:34
  5. 10 bit pwm as dac
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 16:12
