Integer Arithmetic Assistance Required
Results 1 to 6 of 6
    Default Re: Integer Arithmetic Assistance Required
    you might get a better result using pot 4 to control a pwm signal that is fed to a common control element driving all the leds (10 bit pwm is no too difficult either)
    One possible solution
    Dummy VAR WORD
    Dummy = Red * Pot4
    ScaledRed = DIV32 1024
    Dummy = Green * Pot4
    ScaledGreen = DIV32 1024
    Dummy = Blue * Pot4
    ScaledBlue = DIV32 1024
    Jan 2011
    Sydney, Australia
    Hi Henrik,
    I knew there had to be a simple way of doing this, I just couldn't figure it out on my own - thank you!
    Will the DIV32 command be affected if I am using DT-Interrupts? What happens is an interrupt occurs between the two arithmetic operations?
    Dummy = Red * Pot4
    Interrupt occurs here
    Cheers
    Barry
    VK2XBP
    It shouldn't have any effect. DT-INTS saves the system variables when entering the ISR so even if an interrupt happens in between the multiplication and the division AND the ISR happens to use the same system variables (R0 and R2 IIRC) holding the 32 bit result from the multiplication no harm is done since the content of those variables are restored by DT-INTS when exiting the ISR.
    Jan 2011
    Sydney, Australia
    Hi Henrik,
    The DIV32 approach worked perfectly - thank you.
    Cheers
    Barry
    VK2XBP
  1. Assistance Required with VB.net
    By malc-c in forum Off Topic
    Last Post: - 11th September 2010, 19:26
  2. Resolution integer math assistance?
    Last Post: - 14th January 2010, 04:01
  3. VB.net and bit arithmetic
    By Ron Marcus in forum Off Topic
    Last Post: - 7th May 2008, 05:38
  4. keypad lcd and arithmetic help
    By csubroncs in forum General
    Last Post: - 27th January 2004, 18:18
