Gyro L3G4200D Code Request
Results 1 to 9 of 9
Threaded View
  1. #9
    Nov 2007
    West Covina, CA
    Default Re: Gyro L3G4200D Code Request
    Hey Fritz,
    Cool project, close to the crash sensor I was working on.
    It sounds as though there's nothing in the buffer to give, causing it to stay there. Now what would keep the gyro from actually working? CTRL_REG1 bits 2:0 enable/disable the 3 axes.
    Busy looking at datasheet.....
    Do you get an interrupt output signal at DRDY or INIT indicating the device is updating?
    Edit:
    I looked at the code I provided and noticed that I stopped using the INT1 and DRDY outputs, bits 7 and 3. So you'll have to set these in order to verify data updates.
    Besides the typos, I see a few discrepancies within the comments and actual SSPBUF values so confirm what you need to use, sorry about that.
    ' Load CTRL_REG3: 10000000, INT1_G enabled, no Boot Status, Active High,
    ' Push-pull output. INT2_G disabled
    GOSUB Start_Gyr        ' Adresss the device
    SSPBUF = $22           ' Transmit register address
    WHILE SSPSTAT.2: WEND  ' Wait until MSSP module finishes task
    SSPBUF = %00000000     ' Transmit the 8bit data to register
    PIR1.3 = 0             ' Clear interrupt flag
    GOSUB Stop_I2C         ' Complete TX data
    Louie
  1. am I being rude to ask this. . .ASM code request
    By camcompco in forum mel PIC BASIC Pro
    Last Post: - 11th March 2013, 12:54
  2. 16F877A and Gyro algorithm question
    Last Post: - 22nd February 2012, 23:21
  3. A Defines Request
    By Kirk Fraser in forum mel PIC BASIC Pro
    Last Post: - 31st March 2011, 23:23
  4. How to tell there is a serial request
    By cncmachineguy in forum Serial
    Last Post: - 21st November 2010, 22:14
  5. Code request....18f2550 usb/serial
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 14:26
