Gyro L3G4200D Code Request
Results 1 to 9 of 9
    Nov 2007
    West Covina, CA
    Default Re: Gyro L3G4200D Code Request
    Here's part of some code for ST's LSM330DLC that looks like it has all the same registers for your gyroscope. Be sure to correct the address for your device.
    Since it's a lengthy program, I'll just list the basic functions.
    I used the MSSP module of the PIC18F14K50 so it can run in the background.
    The read routine was called using the DRDY interrupt output of the device.
    MSSP config:
    SSPSTAT.7 = 0           ' Slew rate control set to 400KHz
    SSPSTAT.6 = 0           ' SMBus compliance disabled
    SSPCON1 = %00101000     ' Enbles I2C module and Master mode
    SSPADD = $1A            ' Baud rate clock divider bits set for 400KHz
                            ' Adjusted from $1D = 368KHz
    CLEAR                   ' Set all registers to 0
    XYZ_RAM  VAR BYTE[12]  ' Array for 16 bit data, 2 bytes each. First 6 for accelerometer, last 6 for gyro
    Gyro register configs:
    '                      Gyroscope configuration
    ' Load time for all 13 Registers is 1029us at 400KHz setting
    ' Registers loaded in order specified by data sheet:
    '   1. Write CTRL_REG2
    '   2. Write CTRL_REG3
    '   3. Write CTRL_REG4
    '   4. Write CTRL_REG5
    '   5. Write Reference
    '   6. Write INT1_THS
    '   7. Write INT1_DUR
    '   8. Write INT1_CFG
    '   9. Write CTRL_REG5
    '   10. Write CTRL_REG1
    Config_Gyr:
    ' Load CTRL_REG2: 10100111, Edge sensitive trigger, HP filter = Normal,
    ' HP cutoff = 0.09Hz
    GOSUB Start_Gyr        ' Adresss the device
    SSPBUF = $21           ' Transmit register address
    WHILE SSPSTAT.2: WEND  ' Wait until MSSP module finishes task
    SSPBUF = %10100111     ' Transmit the 8bit data to register
    PIR1.3 = 0             ' Clear interrupt flag
    GOSUB Stop_I2C         ' Complete TX data
    ' Load CTRL_REG3: 10000000, INT1_G enabled, no Boot Status, Active High,
    ' Push-pull output. INT2_G disabled
    SSPBUF = $22           ' Transmit register address
    SSPBUF = %00000000     ' Transmit the 8bit data to register
    ' Load CTRL_REG4: 01110000, cont. update, MSB @ lower address, 2000dps
    ' non SPI
    SSPBUF = $23           ' Transmit register address
    SSPBUF = %01110000     ' Transmit the 8bit data to register
    '////////////////// XYZ Interrupt threshold settings ////////////////////
    ' Threshold level = THS / 0.061dps, where THS = 540dps (1.5 turns/sec)
    ' Maximum threshold level is 1/2 of Full Scale
    ' 14bit result is loaded into HI/LO registers of each axis
    ' Load INT1_THS_XH: 00100010, Interrupt MSB threshold bits 14:8
    SSPBUF = $32           ' Transmit register address
    SSPBUF = %00100010     ' Transmit the 8bit data to register
    ' Load INT1_THS_XL: 10010100, Interrupt LSB threshold bits 7:0
    SSPBUF = $33           ' Transmit register address
    SSPBUF = %10010100     ' Transmit the 8bit data to register
    ' Load INT1_THS_YH: 00100010, Interrupt MSB threshold bits 14:8
    SSPBUF = $34           ' Transmit register address
    ' Load INT1_THS_YL: 10010100, Interrupt LSB threshold bits 7:0
    SSPBUF = $35           ' Transmit register address
    ' Load INT1_THS_ZH: 00100010, Interrupt MSB threshold bits 14:8
    SSPBUF = $36           ' Transmit register address
    ' Load INT1_THS_ZL: 10010100, Interrupt LSB threshold bits 7:0
    SSPBUF = $37           ' Transmit register address
    '|||||||||||||||| end XYZ Interrupt threshold settings ||||||||||||||||||
    '////////////////// Duration set value //////////////////////////////////
    ' The ODR sets the LSB; 1/190Hz = 5.26ms
    ' The maximum Duration time is 6 bit or 128, Max = 128 * 5.26ms = 673ms
    ' The bit value = Duration/5.26ms
    ' Load INT1_Duration: 10000001, Wait enabled, Duration set to 1.3ms
    SSPBUF = $38           ' Transmit register address
    SSPBUF = %10000000     ' Transmit the 8bit data to register
    ' Load INT1_CFG: 00101010, OR combo of INT, not Latched, interrupt request
    ' on measured value HIGHER than preset threshold
    SSPBUF = $30           ' Transmit register address
    SSPBUF = %00101010     ' Transmit the 8bit data to register
    ' Load CTRL_REG5: 00011010, Reboot mem Norm, FIFO disabled, HPen enabled,
    ' Out_SEL = HPF+LPF2, INT1 = HPF+LPF2
    SSPBUF = $24           ' Transmit register address
    SSPBUF = %00011010     ' Transmit the 8bit data to register
    ' Load CTRL_REG1: 00111111, ODR=95Hz, LPF1=12.5Hz, LPF2=50Hz, Norm PWR,
    ' ZYX axes enabled
    SSPBUF = $20           ' Transmit register address
    SSPBUF = %00001111     ' Transmit the 8bit data to register
    '||||||||||||||||||| end Gyroscope configuration ||||||||||||||||||||||||
    Gyro register reading routine:
    '//////////////////// Gyroscope XYZ data reading ////////////////////////
    ' Recommended way of reading sequential registers
    '       Master  Slave           Note
    '   1.  ST              Sends Start condition
    '   2.  SAD+W           Sends Slave Address including Write bit
    '   3.          SAK     Sends Acknowledge
    '   4.  SUB             Sends Sub Address (1st register address to read)
    '   5.          SAK     Sends Acknowledge
    '   6.  SR              Sends a Repeated Start condition
    '   7.  SAD+R           Sends Slave Address including Read bit
    '   8.          SAK     Sends Acknowledge
    '   9.          Data    Sends Data
    '   10. MAK             Sends Acknowledge
    '   11.         Data    Sends Data
    '   12. MAK             Sends Acknowledge
    '   13.         Data    Sends Data  (Process repeated)
    '   14. NMAK            No Acknowledgement sent after last register read
    '   15. SP              Sends Stop condition ending Read process
    ' Reading all XYZ registers and loading the array takes 237us worst case.
    Read_G_REG:
    ' Generate Start condition
    GOSUB Start_Gyr
    ' Send first register to read with bit #1 set indicating READ and bit #7
    ' set indicating multiple reads
    SSPBUF = %10101000             ' Register 28h with 7 set = $A8
    ' Wait for ACK from device
    WHILE SSPCON2.6 : WEND         ' Wait until device sends an ACK
    ' Send Repeated Start condition
    SSPCON2.1 = 1                  ' Send Repeated Start condition
    WHILE SSPCON2.1 = 1: WEND      ' Wait until MSSP module finishes task
    ' Send device address with Read bit set
    SSPBUF = $D7                   ' Transmit device address w/READ bit
    '///////////////////// Read the next 6 registers ////////////////////////
    ' This portion loops through Read sequence 6 times. The Master sends an
    ' ACK after each read indicating "send another" so no ACK is sent after
    ' the 6th data packet, a Stop Condition is sent instead to end the READ.
    FOR e = 6 TO 11
    ' Receive the 8 bit data from gyroscope
        SSPCON2.3 = 1                  ' Enable the Receiver to clock in data
        WHILE !SSPSTAT.0: WEND         ' Wait until Buffer Full bit is set
        XYZ_RAM[e] = SSPBUF            ' Load each XYZ_RAM byte in array
    ' Master sends ACK for first 5 data packets
        IF e != 11 THEN
            SSPCON2.4 = 1               ' Initiate Acknowledge sequence
            WHILE SSPCON2.4 = 1: WEND   ' Wait until Acknowledge sequence Idle
    NEXT e
    ' Send Stop condition to end Read function
    GOSUB Stop_I2C                      ' Complete RX data read
    '||||||||||||||||||| end Gyroscope XYZ data reading |||||||||||||||||||||
    I2C Start and Stop routines:
    '                 Generate Gyroscope Start condition
    Start_Gyr:
    ' Start condition to the transmit device address
    SSPCON2.0 = 1          ' Generate Start condition
    WHILE SSPCON2.0 = 1: WEND  ' Wait until MSSP module ready to TX
    PIR1.3 = 0             ' Clear the Interrupt flag
    SSPBUF = $D6           ' Transmit address that includes WRITE bit
    '                       Stop I2C routine
    Stop_I2C:
        SSPCON2.2 = 1          ' Initiate Stop condition
        WHILE SSPCON2.2: WEND  ' Wait until MSSP module finishes task
    @ nop                       ; Had to slow it down or it didn't work!
    @ Nop                       ; Only 1 was needed but 1 more won't hurt
    Louie
    Louie,
    Thanks big time. I'll post once I get it going......or not.
    Fritz
    Nov 2007
    West Covina, CA
    You're welcome and good luck with your project.
    Louie
  1. am I being rude to ask this. . .ASM code request
    By camcompco in forum mel PIC BASIC Pro
    Last Post: - 11th March 2013, 11:54
  2. 16F877A and Gyro algorithm question
    Last Post: - 22nd February 2012, 22:21
  3. A Defines Request
    By Kirk Fraser in forum mel PIC BASIC Pro
    Last Post: - 31st March 2011, 22:23
  4. How to tell there is a serial request
    By cncmachineguy in forum Serial
    Last Post: - 21st November 2010, 21:14
  5. Code request....18f2550 usb/serial
    By f_lez in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 13:26
