Migrating to 18F4420
Results 1 to 2 of 2
    Apr 2011
    Welches, Oregon
    Default Migrating to 18F4420
    I have a project that threatens to outgrow a 16F877A and so have upgraded to the 16F4420. This is quite a step for me as, I have not done much work with a 40 pin chip prior - and never anything with the 18F. So... I've stripped the board down to the MCU, a 4x20 LCD, an I2C clock (3231 module), and required supporting circuitry.
    Using meCONFIG, I have managed to configure the chip and, the heartbeat LED is blinking merrily; the LCD starts up and displays exactly like the old '877, but the I2C clock is stubborn. I'm wondering if there is anything in the CONFIG causing the problem, or if perhaps there is some difference in the syntax that I have not seen?
    Any help will be appreciated!
    Configuration:
      __config  _CONFIG1H, _OSC_HSPLL_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
      __config  _CONFIG2L, _PWRT_OFF_2L & _BOREN_SBORDIS_2L & _BORV_3_2L
      __config  _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
      __config  _CONFIG3H, _CCP2MX_PORTC_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
      __config  _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
      __config  _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
      __config  _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
      __config  _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
      __config  _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
      __config  _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
      __config  _CONFIG7H, _EBTRB_OFF_7H
    CODE:
    '-----DEFINES------------------------------------------------------------------
    '-----OSC
    '----ADC
    DEFINE ADC_BITS 10       ' Set number of bits in result
    'DEFINE ADC_CLOCK 3     ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 100
    '-----LCD
    DEFINE LCD_DREG  PORTD
    DEFINE LCD_DBIT  4
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG  PORTD
    DEFINE LCD_EBIT  2
    DEFINE LCD_LINES 4
    '-----REGISTERS SET------------------------------------------------------------
    CMCON = %00000111																'DISABLE COMPARITOR
    TRISA = %00011111                                                               ' Set PORTA.OUTPUT; ADC
    TRISB = %00000000                                                               ' Set PORTB OUTPUT
    TRISC = %00000000                                                               ' Set PORTC
    TRISD = %00000000                                                               ' Set PORTD OUTPUT
    TRISE = %00000000
    ADCON0 = %10100001
    ADCON1 = %10000010   								                            ' RIGHT justify; Set AN0 - AN5 ADC
    '-----LED
    LINE1 CON $80
    LINE2 CON $C0
    LINE3 CON $94
    LINE4 CON $D4
    '-----I2C
    SCL VAR PORTE.1
    SDA VAR PORTE.2
    'DEFINE I2C_SLOW 1
    'DEFINE I2C_HOLD 1
    'DEFINE I2C_SCLOUT 1
    '-----INDICATOR LIGHTS
    LIT_ADD CON %01110010
    '-----GAUGES
    REG_CHP1 CON %01011000
    REG_CHP2 CON %01011010
    GAGE VAR BYTE
    '-----CLOCK/ CALENDAR
    REG_VAL VAR Byte[12]
    RTC_ADD CON %11010000
    REG_TIM CON $00
    REG_CTL CON $07
    REG_STS CON $0F
    CURR_MIN VAR WORD
    OLD_MIN VAR byte
    OLD_DAY VAR BYTE
    '-----INITIALIZE---------------------------------------------------------------
    '----SET TIME	                                                            	'Seconds, minutes, hours, day of week, date, month, year
    REG_VAL[0] = 00  'SECONDS
    REG_VAL[1] = 12  'MINUTES
    REG_VAL[2] = 19  'HOURS
    REG_VAL[3] = 03  'DOW
    REG_VAL[4] = 18  'DAY
    REG_VAL[5] = 02  'MONTH
    REG_VAL[6] = 15  'YEAR
    REG_VAL[7] = %01100000 'SPECIAL
    REG_VAL[8] = %00001000 'SPECIAL
    REG_VAL[9] = %00001000 'SPECIAL
    I2CWrite SDA, SCL, REG_CTL, $0E, [REG_VAL[7]]
    GOSUB CLK_WRITE
    '-----MISC        '.6
    D1 VAR BYTE
    LP VAR BYTE
    ADC_VAL VAR WORD[3]
    IND_LIT VAR BYTE
    PAUSE 250
    LCDOUT $FE, $01        ' Bit 7 =
    LCDOUT $FE, LINE1,"--STEGETROLLER--"
    PAUSE 250
    LCDOUT $FE, LINE2,"---START-UP"
    PAUSE 1250
    LCDOUT $FE, $01
    MAIN:
      FOR LP = 1 TO 3
        ADCIN LP, ADC_VAL[LP]
        PAUSE 10
      NEXT LP
      'I2CWrite SDA, SCL, LIT_ADD, $00, [IND_LIT]
      'IND_LIT = IND_LIT + 1
      'I2CWrite SDA, SCL, REG_CHP1, $00, [GAGE, GAGE]   'GUAGE 1 - TEMP
      'pause 100
      'GAGE = GAGE + 10
      PORTA.5 = 1
      PAUSE 100
      PORTA.5 = 0
      PAUSE 100
      GOSUB CLK_READ
      GOSUB UPDATE_DISPLAY
    GOTO MAIN
    UPDATE_DISPLAY:
      'LINE1
      LCDOUT $FE, LINE1, DEC1 REG_VAL[3], "<", DEC2 REG_VAL[5], "/", DEC2 REG_VAL[4]
      LCDOUT $FE, LINE1 + 14, "[", DEC4 CURR_MIN, "]"
      LCDOUT $FE, LINE2, DEC4 ADC_VAL[1], ":", DEC4 ADC_VAL[2], ":", DEC4 ADC_VAL[3]
      LCDOUT $FE, LINE3, DEC2 REG_VAL[2], ":", DEC2 REG_VAL[1], ":", DEC2 REG_VAL[0]
      LCDOUT $FE, LINE4, BIN16 ADC_VAL[1]
    '-----READ CLOCK AND CONVERT TO DECIMAL
    CLK_READ:
      I2CRead SDA, SCL, RTC_ADD, $00, [REG_VAL[0], REG_VAL[1], REG_VAL[2], REG_VAL[3], REG_VAL[4], REG_VAL[5], REG_VAL[6], REG_VAL[7], REG_VAL[8], REG_VAL[9], REG_VAL[10], REG_VAL[11], REG_VAL[12]]
      FOR LP = 0 TO 6
        D1 = REG_VAL[LP]
        D1 = D1 & $70
        D1 = D1 >> 4
        D1 = D1 * 10
        REG_VAL[LP] = D1 + (REG_VAL[LP] & $0F)
      NEXT LP
      CURR_MIN = REG_VAL[2] * 60 + REG_VAL[1]
    '-----CONVERT TO BCD VALUES, WRITE TO CLOCK REGISTERS
    CLK_WRITE:
      FOR LP = 0 TO 6
        D1 = REG_VAL[LP] DIG 1
        D1 = d1 << 4
        D1 = D1 + (REG_VAL[LP] DIG 0)
        REG_VAL[LP] = D1
      NEXT LP
      I2CWrite SDA, SCL, RTC_ADD, $00, [REG_VAL[0], REG_VAL[1], REG_VAL[2], REG_VAL[3], REG_VAL[4], REG_VAL[5], REG_VAL[6], REG_VAL[7]]
      GOSUB CLK_READ
    The code is quite messy as I've been up way too late trying to solve the issue myself and now, as I prepare for work, am admitting defeat. Still, it does work on the 877, just wondering what the problem on the 4420 might be?
    Default Re: Migrating to 18F4420
    Your ADCON1 looks wrong:
    ADCON1 = %10000010
    Bit7 which doesn't do anything, yet you have it set for some reason and the four bottom bits (0010) will leave all the analog pins in analog mode. So PortE.1 and PortE.2 (your I2C pins) are analog.
  1. Migrating PBP3 and MCSPX to a new computer.
    Last Post: - 22nd January 2013, 06:10
  2. Migrating to MPASM
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 14th August 2009, 17:21
  3. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 20:05
  4. migrating to pic18f452 from 16f877a
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 9th June 2007, 08:39
  5. Migrating PIC16F876a to PIC18F252
    By cohenjdc in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 13:55
